Mount for Maglite on Helmet- Mtbr.com
Results 1 to 5 of 5
    Reputation: bgfthntr's Avatar
    Where can I get / make a strong maglite mount for my helmet?
    thanks
    TwoFish Lockblocks or similar mounts are a common method and are available in several styles. Google them for many sources.
    Here's some photos to give you the idea.
    Quote Originally Posted by bgfthntr
    thanks
    You're using a Maglite to ride by? Is it modded in some way?
    ... and if we just ...
    Quote Originally Posted by fightnut
    It's actually a LED Flash Light with the dimensions of a mag-lite. I want to use it on my helmet as secondary light.
    TwoFish BikeBlock perhaps:
    If it's a AA-powered [email protected], you could probably just rubber-band it to your helmet, though. That's what I usually do with my Fenix L2D. I do have a helmet with a good vent layout to accomodate that, however (in fact, the L2D will fit inside a vent on a Giro E2 if you don't mind having a hard metal tube running through your helmet).
