Lycra- Mtbr.com
Results 1 to 34 of 34
Thread: Lycra
    Smile Lycra
    Noob here. Can i ride in shorts and a t-shirt or do i have to wear lycra?
    Reputation: Timon's Avatar
    the police will take your bicycle license away if you ride a bike without lycra on. and you can be ticketed if its not tight enough.
    believe it. its happened to me.
    Reputation: Adim_X's Avatar
    You can ride in whatever you want. Just be careful of what your clothes can snag on.
    Thats exactly what i thought nomit.You have to watch those bears in the woods.
    Peace bro
    Reputation: Nubster's Avatar
    What you probably want to do is get some padded bike shorts and just wear whatever you want over top. The bike shorts can literally save your ass on long rides. But otherwise...there are no rules saying you have to wear lycra....unless you ride a carbon fiber bike. Riding carbon fiber with less than 75% lycra coverage will cause your frame to explode...or is it implode...I can never remember.
    Jul 2003
    Your call dude....
    I personally let where I ride determine the whole thing. I've ridden trails where nice skin tight cycling shorts were almost a must. Tight trails with brambles and wait a minute vines and the like made anything baggy almost impossible to ride in. Otherwise, baggies with a good padded liner work well and are a bit more modest if that worries you. I usually switch over to lycra when the dog days hit. Baggies, even very good ones, are just too hot when the humidity and temps start topping the 80s and 90s. As for should you wear just regular shorts etc. Only if your butt, taint and neuticals are made of cast iron!, or you only ride short distances. The longer the ride the worse beating that region of your body will take. Padded lycra shorts and baggies with padded liners have the much welcome property of being mouisture wicking. The move persperation from the skin to the outer layers of the material to keep your butt drier and greatly reduce chaffing.
    Like I said, your call. But if you ride an hour or more at a time, I'd highly recommend a good pair of padded cycling shorts. Lycra, baggy, or lycra with the shorts of your choice over them, all work fine. But regular shorts with regular underwear or commando! I shudder just at the thought!
    Good Dirt
    Reputation: scoutcat's Avatar
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Quote Originally Posted by Nubster
    A tshirt is fine, but as Nubster said, I would highly recommend getting some lycra riding shorts to wear under whatever baggy shorts you choose. The close fitting synthetic material prevents a lot of chafing that would occur riding in regular shorts and underwear, and the padding adds additional protection from chafing, some comfort from simply being padded, and it makes a smoother transition downtown to prevent dangly bits from getting snagged or stuffing from getting stuffed by the nose of the saddle. It also disguises sharts better.
    Awww CRAP!
    I was riding in reg shorts and a t-shirt up until this week. I'm a new rider as well and after 3-4 rides in baggy shorts I opted to go for some tighter padded ones. Not only am I tired of having a sore ass after riding the rocky, root infested trails in New England but their were several occasions when I needed to shift my weight to the rear coming down a rock face or steep hill and the crotch of my baggy shorts snagged on the front of my saddle. One time it ripped my shorts and another it caused me to almost take a trip over the bars..
    I bought lycra shorts but i may try to find some shorts to wear over them that are less baggy than the ones I was wearing... Cotton shorts are also not very durable. As far as the T-shirt I've ripped two of mine when they snagged trees as I was passing, so I'll be buying some tighter shirts too....
    2010 Stumpjumper FSR Expert
    meow meow
    Reputation: b-kul's Avatar
    what if its a mojo hd?
    Quote Originally Posted by b-kul
    In that case it requires 85% Lycra to prevent implosion. I remembered that lack of Lycra causes implosion and getting water on a carbon bike causes explosion.
    Quote Originally Posted by FacePlantinNewB
    I have been wear Starter brand running shorts from Wal-Mart. They are short and not too baggy, very light and made from a wicking material and have been working great as riding shorts over my biking shorts and they are not too bad looking so that if you need to stop someplace on the way to or from riding you don't need to change your shorts first.
    Awww CRAP!
    I'll have to check those out.
    Permanent Noob
    Reputation: JCullen's Avatar
    Give these a try - they should keep you from getting caught on stuff.
    I'm beginning to overcome my "momentum issues" but even that is happening slowly.
    MTB Name - Crustius Maximus
    meow meow
    do you know what a mojo hd is? hint: brian lopes rides one.
    Yeah...it is a carbon FS frame made by Ibis that costs about $2500.
    meow meow
    then you get why this is a carbon frame that calls for baggies not lycra.
    Nah...he is just wearing lycra under his baggies.
    meow meow
    well yeah but thats a given.
    BBW
    BBW is offline
    Reputation: BBW's Avatar
    Baggy and FF helmet; there's no other way
    Reputation: chas_martel's Avatar
    Quote Originally Posted by yorkn
    Normal shorts and baggies are good alternatives for those lacking "down there". They are also good for those that care what other people think.
    And about t-shirts, cotton is good if you like to be drenched in sweat.
    Nobody cares...........
    Quote Originally Posted by chas_martel
    think
    I, personally, wear whatever the hell I want. It greatly depends on your tolerance for physical misery though I suppose, as well as duration of the ride. I stand up a LOT and thus find wearing Dickies on a two hour ride isn't so bad. For something like road bicyling where you're basically in one position the whole time proper apparel is essential.
    You leave it on the roof of your late model BMW so your buddies at the law office can scope it out.
    What's odd about this is you seem awfully indignant and concerned with what others think.
    Quote Originally Posted by bad news
    Actually I don't give a "f u c k" what people think.
    I wear lycra because I don't like getting hung up on the rear of the saddle when I get over the back wheel.
    PS: Where was I indignant?
    And another thing, I am amused at the most typical reasons for asking this question.
    Looks!
    I know one guy that is so hung up on what helmets and lycra "look" like. Yet, this guy shaves his head and is all tatted up. What the hell does he care what people think?
    OP, correct me if I am wrong, but are looks one of your concerns?
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    I know one guy that is so hung up on what helmets and lycra "look" like. Yet, this guy shaves his head and is all tatted up. What the hell does he care what people think?...
    why are you picking on me? ...i shave my melon 'cause i'm going bald....and i really only have 1 tattoo.....besides...i sometimes ride nekkid.....screw the lycra baggie debate....
    don't make me post pics
    Click Here for Forum Rules
    Quote Originally Posted by CHUM
    I'm not picking on you. I did not say everyone.
    I was just pointing out an often cited reason for abhorring Lycra.
    I don't think indignant is the correct word....douche is more fitting. I wear shorts over my biking shorts because that is what I am comfortable in...not because I care what others think or because I am lacking anything. To think otherwise is just asinine.
    If you go back and carefully read what I've typed you will find I did not say this is true of everyone.
    What's wrong, did I hit a nerve? You projecting?
    Just because I am hung like a hamster does not mean I am projecting.
    Now see, you go talking like that and everyone will think, hey guy is being modest, must be hung like a horse.
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    Would you swim in a coat and tie? Get lycra. A full body suit is recommended.
    Reputation: 006_007's Avatar
    Wear whatever you want. Personally I am a fan of a$$less chaps
    MTB skillz = NADA
    Reputation: GrayBeard Pirate's Avatar
    Dec 2009
    This thread is funny!
    Since I don't like writing, I don't have a blog to pimp. This space for rent.
