Little XPE Helmet Light- Mtbr.com
Results 1 to 14 of 14
    One Gear
    Reputation: .40AET's Avatar
    As usual, that to everyone for all of the help. The lights are certainly getting easier to build. I wanted something small so I tried the 4 of the little XPE lights with the 10mm square optics. They are running on a buckpuck @ 700mA with a 14.8v battery. The 4 XPE's don't appear to be as bright as 3 standard R2's, but the light is 1/2 of the size. I'm looking forward to trying the 3x XPE's and building a double of some sort. Soldering and mounting the optics is a royal pain. Thanks guys!
    Attached Thumbnails Attached Thumbnails Little XPE Helmet Light-p1010008.jpg
    That is a nice little light , what are the optics the narrow tight.
    we now need tiny drivers for these things
    they may be a tad easier to mount with the new square boards
    and come on where is it
    One Gear
    It's the middle of the afternoon here. The optics are the narrow spot. I was looking to get as much throw out of the lights as possible. A micro driver would be sweet. The tube could be considerable shorter.
    My 4 up XPE is 46 mm long. Not too bad.
    The Fatman does take up less room than the Buckpuck. Could shave another 5 or 6 mm off if I wanted to compared to my buckpuck version.
    Are you running your 4 XPE in series? So each is getting 700 mA?
    I ran one of mine as 2S2P with the 1000 mA buckpuck, so 500 per emitter. It is very bright.
    One Gear
    Yes, all 4 XPE's are in series so each one is getting 700mA. It could be shorter if I used a flat piece of aluminum for a end plate. It's got one of those black furniture tubing caps on the back end and it takes up a bit of room. odtexas: I like the look of the light on the left. Where did the channel pieces on the side come from?
    The light on the left is 3/8's by 1 inch flat bar stock with grooves cut into it with the table saw.
    One Gear
    Sorry to take so long. MTBR camera settings:
    first photo is control
    2nd is standard 3x Cree R2 light
    3rd is the 4x XPE light
    Reputation: yetibetty's Avatar
    Vey nice, it does look a bit brighter than the triple R2, amazing how much light can be projected from such small optics.
    How is the 14.8v battery coping with the extra LED?
    And is that a MC-E build going on in the background in you first pics?
    One Gear
    So far the batteries haven't had much of a workout. We've had a long warm spell so the trails are soup. I have a lot of hopes for the little light as a replacement helmet light. I'm more concerned about the 4400mA battery that will run the 2x MCE that is in the background. I haven't had a lot of free time to do a good comparison between the optics. So far the ledil square optics have the best punch. I took pics of the MCE but couldn't get them resized in order to post.
    Try emailing the pics to yourself, the ones you receve should be smaller and you can post them on here.
    Mad but that's what I do.
    Nice shots there.
    For pics you can also open a free account at photobucket.com. When uploading you have the option of having your file resized. Comes in handy once you know its there.
    One Gear
    Quote Originally Posted by yetibetty
    Everything else that I tried was mad, so what the hell.
    if you are using mr gates software then you can use
    micro soft image resizer even I can use it
    One Gear
    Troutie- Thanks for the image resizer link. It's super easy!!!
    Dual MCE light in the same setting.
