Light & Motion helmet mount help- Mtbr.com
Results 1 to 2 of 2
    BBW
    BBW is offline
    Reputation: BBW's Avatar
    New question here. Light & Motion helmet mount help
    Hi guys, I just received my new ARC Lithium Ion
    I wanted to attach the light using the helmet mount but the design seems weak and I can't make it to feel secure and not move
    My helmet is a Bell Ray with a "rib" in the middle and if I try to attach it off center, the same thing. This little velcro doesn't stretch so it's difficult to make it stay put
    Any proven ideas?????
    Thanks!!!
    It's raining every day here in Dallas/Ft
    When you pull tight the Velcro, stick your thumb on the slot on the base that it comes out of. This will let you pull it super tight and allow you to get it secured. I've had no problems getting my L&M secure on any helmet, even ones with a little less than flat centers. Not really the mounts fault that helmets have weird surfaces. Just pull it as tight as you can.
    Niner Jet 9 RDO XX1 Build
    2015 Niner Bikes Ambassador; Chattanooga, TN
