lake winter shoes- Mtbr.com
Results 1 to 6 of 6
    Sep 2004
    lake winter shoes
    the bolt to hold the ratchet together keeps loosening up,its a goofy bolt does anyone know where to get a wrench to fit it, thanks
    DynoDon
    Reputation: manabiker's Avatar
    Have you tried Snap On Tools, or Matco Tools without a picture, it hard to say.
    Never trust a fart
    Reputation: frdfandc's Avatar
    Can you post a pick of said bolt? Not familiar with the bolt design, but I have a crap load of professional tools from my days as an auto tech. I might be able to help out.
    Tool
    Reputation: Pedalphile's Avatar
    I believe a tool is supposed to ship with the shoes. Try Lake CS if you haven't already.
    -Pete
    I can barely get my mouth around it.
    Reputation: Legbacon's Avatar
    I used a cork screw put in one hole to turn it. Worked quite well. Put some blue locktight on the threads or it will keep backing out. I learned too late and lost one screw. I solved the problem by gettin a shoe repair shop to install old fashioned eyelets.
    Formerly Travis Bickle
    Team Robot. "modulation is code for “I suck at brake control.” Here’s a free tip: get better."
    Quote Originally Posted by Pedalphile
    -Pete
    Correct...the tool comes with the shoes.
    Small snap ring pliers will work.
