• 01-05-2014
    madsedan
    Input on five.tens I recently bought, not crazy about them...
    OK, been riding clipless for a couple years but recently got some light platforms for a product review and decided to get some 5.10's and see what all the hypes about. I picked up a pair of older freerider's on clearance during the holidays, less than $50 delivered if I remember right.
    So far I've been on a couple rides and wore them a couple days shopping with the wife and kids to try and break them in but I'm still not sure if I like them.
    I am going to try an insert, to add some comfort when walking as well as to take up a little room as they are a little roomier than was expecting.
    They certainly grip, I mean almost to a fault lol. The thing I struggle with is having to think about foot placement, I hadn't had to worry about that for a couple years.
    The questions I was wondering about was does anyone have a recommendation on an insole, maybe one of the nice Specialized BG inserts if they fit?
    Also, is there a trick to breaking them in to make them slightly "less" grippy?
  • 01-06-2014
    bad andy
    no comments an an insole. As for grip - what pedals are you running?
  • 01-06-2014
    smilinsteve
    I think the grip is something you get used to. At first you expect to be able to slide your foot around to whatever position you want, but you can't.
    You get in the habit of unweighting your foot to move it. Its not a big deal after a while.
    For me its just nice to be able vary the pressure points under your foot compared to clipless where your foot stays in one spot.
  • 01-06-2014
    fsrxc
    same here, just had to get used to lifting foot to reposition (if that's what you mean).
    One option is to shorten the pedal pins (if set screws - screw them down to stick up less)
  • 01-06-2014
    SmittyPDX
    You're right about them being uncomfortable to walk in. When I'm pushing up the hill I can feel every little pebble I step on. Obviously this soft rubber is what makes them so rad. I always told myself I'd get some insert, but still haven't to this day. I'm sure any kind/type will improve comfort.
  • 01-06-2014
    smilinsteve
    They must be different than the 5.10 impact lows. Those things have a really thick sole, and thick padding all around. They are good for walking IMO. My problem with them is that they get hot, and they are a bit ugly.
  • 01-06-2014
    madsedan
    I'm using Xpedo Spry pedals, not sure why I didn't think about backing the pins down but that's a great idea, I'll give that a shot.
    I guess comfort is really all relative, I run occasionally and wear pretty nice running shoes, I'm used to having some serious cushion, these just don't have it. The model I picked up were the spirfires, not the freeriders, I was mistaken.
  • 01-06-2014
    fsrxc
    Like Smilinsteve I have Impacts, and I don't feel pedal pins or small rocks through the soles. You might be happier in Impacts.
  • 01-07-2014
    Bigb2000
    I've got those pedals and free riders. Back the pins down. I wear mine all the time, couldn't be more comfortable. The styling is not preference, but they were on clearance.
  • 01-07-2014
    kickhorse
    Yeah, takes getting used to. Used to think they were bulky and heavy, but don't notice them at all now when riding. Put some superfeet insoles in them, but mostly cause they were a bit loose on me, 9.5 was too tight so went up to a 10. Play around with pin height and placement on your pedals to tailor it to your grip preference.
  • 01-08-2014
    69tr6r
    I have the Spitfire as well. It's a completely different shoe than the Impact. It has a thin sole, and not much arch support. I don't wear them off the bike at all, too uncomfortable. But if I was going to suggest an insert I would say Superfeet. But I've also had good luck with a cheaper insole from the big box stores. It takes some getting used to as far as the grip, which is sometimes too much, but maybe play around with the length of the pins you're pedals have.
  • 01-08-2014
    sherpaxc
    Spank Spikes and Freeriders for me. I switched to them a month ago after 15 years of riding/racing on clipless pedals. I love them. It took me about 3 weeks to learn the technique but I think I've got it down. I'm climbing just as fast, descending even faster, and my feet are happy. I read for hours on mtbr about other peoples experience. In the end I just had to try them for myself. So happy I did. Good luck with you decision. I'd give the Freeriders a try.
  • 01-09-2014
    blaklabl
    Originally Posted by MostChillin View Post
    I ordered the Freerider XVi's yesterday after much research and agonizing...
    I have been using these with Deity Decoy LT pedals and I love the combo. So much so that I use them for XC riding on my 29"er as well, not just my trailbike. I'm to the point now I am going to have to buy a 2nd set of platforms, LOL
  • 01-09-2014
    rogbie
    I'm still suspect on 5.10s offering too much grip (for my preference) but time will tell.
    There is no such thing as too much grip with flat pedals. It's a different technique to moving the foot on the pedal. Also, try changing the pin height on the pedals. Set the pins up in a concave manner; lower pins closer to the pedal body and axle; higher pins on the outside of the pedal.
  • 01-09-2014
    fsrxc
    Wellgo MG-1s are good-light-cheap trail/XC platforms
  • 01-09-2014
    sherpaxc
    All I own is a XC bike and use flat pedals for them. I'm not much of a dirt jumper at all. I thought it would look funny with flats on my hardtail, but my good buddy told me, "dude, nobody looks cool wearing spandex, so don't worry about flat pedals." Good point.
  • 01-16-2014
    Kiwi_GR_Biker
    I have Impact low and whilst the grip is great I agree with others that they feel like you are in an orthotic boot. Not comfortable at all. I have tried a couple of different sizes but still no joy. My feet actually go numb in them whilst riding which is a bit disconcerting. I have tried to give them a decent chance to break in but they don't seem to be getting any more comfortable. Disappointing because the grip of the sole is fantastic. I also own another pair of Fiveten walking/hiking shoes and they are great. Very solid and comfortable for hiking but no good for biking as the sole has too much tread.
    May start to look into alternative, cheap skate shoes. Anything for a bit more comfort.
    Five Ten Impact 2 Low MTB Shoes | Chain Reaction Cycles
  • 01-18-2014
    H6NVGce
    I am using freeriders VXI and azionic 420 flats. I love the grip and feel of this combination. It did take some getting used to having to lift my foot to reposition, but its worth it. They arent bad to walk in. My only complant is the amount of dirt that ends up inside my shoes during a ride.
  • 01-18-2014
    vikb
    I love the Impact Lows. I'm using my custom insoles [I use 'em in every shoe I wear] in them and find them super comfy on and off the bike. I can wear them 12hrs+ without a second thought.
    I got a pair of the Freerider Elements as a lighter duty shoe to wear mountain bike touring and around town.
