How long should a helmet last?- Mtbr.com
Results 1 to 7 of 7
    Reputation: NoVA_JB's Avatar
    I haven't ridden in several years and now I'm back into it. I have a Specialized helmet that has a build date of 2000, it has never had any damage and looks good.
    Do helmets expire?
    Vaginatarian
    if it was stored in the sun or a hot invironment , its prob no good, otherwise its foam & plastic and should last forever. unless its been dropped
    basicly its a cooler shaped to fit your head
    i also unicycle
    every 3-5 years you should replace it. UV degrades the foam and bonding agents, plus you'll get a better helmet for the same money as trickle down happens fairly quickly in helmets.
    mtbr says you should know: i work in a bike shop.
    bikes & beers (on my blog) http://idontrideenough.blogspot.com/
    Reputation: Fairchild's Avatar
    I'd say 3-5 years of normal use.
    The major exception being if you have been in a wreck with it. The material is designed to be destroyed instead of your melon, so obviously it's not reusable afterwards.
    I guess it's better safe than sorry, I would hate to crash and find out that it had damage that I didn't see.
    I'm looking at the Bell Deleruim. Anyone else use this helment and do you like it?
    Reputation: Joules's Avatar
    Quote Originally Posted by NoVA_JB
    Do helmets expire?
    helmets last until you break them. Photo-degradation of the helmet is a myth.
    that said, fitting systems have gotten a lot better in recent years; helmets are better at staying where they belong in a crash than they used to be. also, I personally have never gone more than a few years without dropping my helmet, or dropping something on it... IME there's a chance you've done something to compromise the helmet, without realizing or maybe remembering it.
    Derailleurless
    My last Specialized helmet (actually, my wife's) had a nice "replacement required" indicator built right in to the shell. Maybe yours has one. It looks like this:
    <img src="https://www.booboodog.net/images/annescrackedhelmet.jpg">
    speedub.nate
    MTBR Hiatus UFN
