How to avoid swallowing gnats?!?- Mtbr.com
Results 1 to 41 of 41
    Aug 2018
    Ok please don't laugh. But in my rides, I have to sometimes do uphills in some woods in California, in proximity of torrents. Those woods are in tested by gnats, who I think are trying to get a sip of my sweat, perhaps in search of salt. So I am occasionally biking in a cloud of gnats, and as it's hot and uphill, I breath with the mouth open, and uhhrg ackkc cough cough spit bleaaargh spit rinse spit again, I occasionally swallow one of them.
    I am tempted to fashion a sort of face mask made of gauze or window screen material to keep them out. Anyone has some good suggestion? I must not be the only one, am I?
    Reputation: ocnLogan's Avatar
    Aug 2018
    Quote Originally Posted by lucapcp View Post
    I used to live in CA by the coast, and commuted to and from to work by some local greenbelt style bike paths (paved, but next to a creek). If I was unfortunate enough to return home at dusk, there would occasionally be clouds of gnats that were almost impossible to avoid. I never swallowed one, but have gotten my fair share in my eyes.
    They also would get in my hair/beard, and I'd get to work/home from work, and I'd look a bit like Beetlejuice/the grinch (bugs crawling out...).
    I make my own camping gear (hammocks, etc), and normal gnats/noseeums are small enough that normal window screen won't work. You need a finer mesh, like what you'd find on a mosquito net. Probably cheapest to scrounge some from a mosquito head net, or go buy a yard of it at a fabric store. I've never tried breathing intensely through my hammock bug net though, so not sure if it would be stifling or not.
    If I was to make something for it, I'd maybe modify a bandana with a square of netting, or make something similar to an old motocross roost guard, but with mesh/netting for gnats instead of plastic for deflecting clods of dirt.
    Something like this.
    Good luck .
    Aug 2018
    From reading other threads, they are called 5mph flies as that's the speed you need to lose them.
    I will try with window screen fabric and elastics,
    Today I did a 1000ft climb in their company, not fun.
    Aug 2016
    No laughter here. I'm deep in the southeast US, and night rides are super-hairy. Or, well, it's the spiders and bees that are hairy...in your throat. Gnats around twilight pose similar problems.
    I generally just have to back off a bit so I can breathe in through my nose. Or just be very aware and willing to risk putting my head down in certain spots.
    I thought about some kind of mask, but it seems like it may compound the issue.
    I not much for safety glasses or goggles, either, so I guess I've just decided to try to be alert and ride smart. Dropping your head to avoid bugs or tree branches isn't optimal, but it works for me.
    Aug 2018
    I ordered a "Sea to Summit Head Net" from REI, which I found advised in an old net.
    I will report how it works.
    Mar 2011
    i've seen people riding with cycling face masks but no idea how they would affect your heat/breathing.
    Reputation: Mr Pig's Avatar
    I have swallowed a lot of flies. As yet, I have not died. Not saying I enjoy it but I can live with it.
    Feb 2017
    Quote Originally Posted by phuchmileif View Post
    Yes, I've had more issues with spiders, yellow jackets and mosquitoes. Seems like a bandanna would be enough to keep the gnats out of your mouth. Although, not ideal when it is 90 degrees and 1,001% humidity.
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Quote Originally Posted by Mr Pig View Post
    :nono: :thumbsup:
    Reputation: Lone Rager's Avatar
    Dec 2013
    Why not just swallow them? What the point in trying to avoid it?
    Do the math.
    Reputation: Tim-ti's Avatar
    +1 on the head net. I sometimes use these nets, have used a few brands and they're similar.
    When you ride into an occasional solo fly, swallowing it is fine; however if you're struggling to climb in a clouds of bugs, the head net makes life better.
    "...DirtBaggies may also be the best baggy mountain bike shorts on the market." Velonews - Click to check out other reviews.
    Aug 2016
    Quote Originally Posted by Lone Rager View Post
    It feels like they get stuck in the back of your throat, and you start hacking like a cat.
    My feeling is that any measure you take which will be effective in stopping flies will be more annoying than the flies.
    Reputation: sturge's Avatar
    Hate that...In New England we have various varieties as well. Deer flies circle around you like fighter jets, black flies swarm in front of your face on a climb, and mosquito's attack when stationary. I try to focus on keeping mouth closed during climbs when the swarm appears. Not uncommon to suck a black fly in. More than once I've pulled one all the way into my freakin' lung. Can sort of feel it in there until hours later it finally gets coughed out.
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...:thumbsup:
    Feb 2017
    In Virginia we have clouds of gnats (midges I think) around bodies of fresh water for a few weeks in the fall. The most annoying thing about them is the way they seem to crush on impact and plaster glasses, skin, clothes, bike, etc. by the hundreds. All you can do is try to keep your mouth shut and blow your nose thoroughly after the ride. Fortunately, no black flies, they are the worst. Yet another reason why late fall to early spring is the best time to ride.
    Reputation: WHALENARD's Avatar
    Feb 2010
    Bacardi 151 and mount some kind of pilot light to your helmet or chin strap. Incinerate them until you've swallowed enough rum at which point you will no longer care. Works for a light in a pinch as well.
    It is no measure of health to be well adjusted to a profoundly sick society.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Close your mouth, breath through your nose
    Quote Originally Posted by WHALENARD View Post
    I'm going night riding with you!
    :nono: :thumbsup:
    Snow Dog
    Reputation: str8edgMTBMXer's Avatar
    Apr 2015
    I mostly ride in the winter/cold. Everything like that is dead, so I never have to worry about it.
    CAn't remember it happening when I do ride in the summer though, and I live in Central Ohio...lots of annoying flying things in the warm months
    Go practice. Figure it out. - Fleas
    15 Surly Krampus - King Amongst Bikes
    LET IT SNOW!
    May 2017
    Quote Originally Posted by noapathy View Post
    like riding behind ghostrider
    Reputation: Sage of the Sage's Avatar
    Embrace them as mid-climb recovery fuel...
    Salsa Timberjack SS
    -Gears give me headaches
    Reputation: GKelley's Avatar
    Sep 2018
    More protein right?
    Breathing in through the nose, and out of the mouth is my best defense.
    Reputation: azimiut's Avatar
    Feb 2014
    pure protein! I chew gum when I ride with bugs. keeps my mouth shut. somewhere there was a pic of me blowing a bubble at a 24h event. as far as the nose goes? well thats a different story. In the valley in AZ we have white flies. they are kinda sweet tasting.
    I remember my dad telling me about riding his bike to the dentist to have his braces cleaned when he was a kid. He would take the canal into town. dentist told him next time ride with your mouth shut.
    Dont make me go all Jonathan Winters on this gas station.
    Aug 2018
    I am happy to report that the nets like the "Sea to Summit" of REI work wonders.
    If the sun is strong, they even shade me a bit, and I can breath perfectly and even feel the breeze, they do not feel hot at all.
    Haha, if I were able to do hard uphills breating with my nose I would be a much better biker than I am!
    And, you know, at some point, I like cooking and choosing the food I eat. Plus it's really hard to swallow those small flies that stick right into the back of the throat and refuse to go anywhere. :-) I am like Billy The Cat when I swallow one, if you know what I am referring to :-)
    Aug 2018
    Bill the cat, Bill the cat, not Billy! Big difference.How to avoid swallowing gnats?!?-screen-shot-2018-09-14-4.13.30-pm.png
    Reputation: R_Pierce's Avatar
    May 2017
    Im not sure if you guys have it there or not, but a local company here makes a spray that is called bug soother. Its the best bug spray for gnats Ive ever encountered. Stuff is amazing!
    https://simplysoothing.net/collections/bug-soother
    Aug 2018
    Thanks, R_Pierce, I am sure the bugs would be happy and well soothed, but it is my welfare that I was actually worrying about... but if I will feel generous one day, I'll go and give those poor bugs a spray of bug soother. They must have a stressful life after all.
    May 2017
    My post wasn't sarcastic at all.. it's the best bug spray I've ever used for gnats. Read some reviews.....
    It's actually the only spray that I have found to keep the gnats away. They are terrible here in the Midwest during late spring/early summer.
    Sent from my LG-H931 using Tapatalk
    Aug 2018
    Sorry sorry, it was just me feeling silly after a long day at work :-) I may try that spray, but the net is incredibly light to carry with me, so for the moment I am happy. I didn't get too many strange looks either while riding with it.
    Snow Dog
    Apr 2015
    what net are you talking about?
    LET IT SNOW!
    Aug 2018
    Snow Dog
    Apr 2015
    ah ha...so does it sit over your head, snd not cling to you vis your helmet...like do you put it on over your helmet?
    LET IT SNOW!
    Upcyclist
    Get one of those veils belly dancers wear.
    Berms and transitions may apply
    Snow Dog
    Apr 2015
    Quote Originally Posted by Cornfield View Post
    oooh yeah..with the little jingles. No need for a bell then
    LET IT SNOW!
    9 lives
    I don't like swallowing flies either but I bet the flies hate it more
    F*ck Cancer
    Eat your veggies
    Aug 2018
    Yes, I put it over the helmet and the helmet visor keeps it off my face. When the uphill is over, or the flies are gone, I put it in my pocket, takes no space at all.
    Snow Dog
    Apr 2015
    hmmm...might try that
    LET IT SNOW!
    Jun 2018
    Get one of those Buff things, from any fly fishing shop. They're intended to keep the sun off but they keep the bugs out too.
    i cut up some panty hose (just enough to cover mouth and nose), pulled up around my mouth...and worked well for the time being when i rode out in the north west during the spring.
    Quote Originally Posted by jesse101 View Post
    i cut up some panty hose pulled up around my mouth..
    Just don't forget you have it on when you go to the bank.
    Reputation: wgscott's Avatar
    Jul 2013
    or the 7-11
  1. Gnats
    By Phillbo in forum Arizona
    Last Post: 07-18-2013, 11:37 AM
  2. Auburn gnats pushed me today!
    By Wherewolf in forum California - Norcal
    Last Post: 09-06-2011, 12:12 PM
  3. Replies: 16
    Last Post: 04-10-2011, 06:39 PM
  4. Bug swallowing = bad
    By kiva in forum Riding Passion
    Last Post: 05-09-2005, 09:40 AM
  5. is it just me, or are roadies swallowing mtb'ers
    By tmccrohon in forum General Discussion
    Last Post: 05-18-2004, 08:41 PM
