Home made helmet light- Mtbr.com
Results 1 to 11 of 11
    Couple of pictures of my homemade setup.
    2 x Cree XRE R2 LEDs
    2 x 1amp driver boards (7135 based constant current at 1amp)
    Switchable between high and low (1amp or 2 amps)
    Total weight is about 400g
    Weight of head unit is 120g
    Runs on 8AA batteries (2x4 serial/parrallel) which is about 4.8 volts.
    Burn time is 2 hours on high or 4 on low approx
    Cost around $40 in parts from dealextreme and local hardware shop (not including batteries mount and wire which are re-used)
    Still have to seal up the front with silicon but other than that I am very happy with it. I also have built a 3 LED version for the bar also running at 2 amps, minus the heatsink fins.
    Reputation: piesoup's Avatar
    Cant see any pictures bud!
    My bad! Didnt have images enabled in my browser!
    The heatsink looks like a funky hair cut!
    Reputation: Southern Adventurer's Avatar
    Jan 2009
    It looks like the Bart Simpson of bike lights! Very cool and imaginative..
    It was the best i could do with the limited Aluminium sections available from my hardware store.
    aka RossC
    Reputation: ocean breathes salty's Avatar
    Quote Originally Posted by Southern Adventurer
    I was thinking something similar....
    Quote Originally Posted by gbowen444
    Hey, I bet it has way more light output than a light of the same cost that has a brand name! Is this your first? If it is, welcome to the world of constantly making a newer, smaller, brighter light!
    I use the same optics you do and I am really impressed with them. Have you got any beam shots yet?
    OOHH dear another (Victim) stroke enthusiast heading down the lumen hunting slope
    Nice one Gbowen sounds like you have had fun doing the builds thats good diy
    using what you can get for a great light .
    and the nice smug feeling when you use it on the trails
    Jan 2009
    I like the pop-rivits too. I started using those to attach a mounting bracket to the underside on some of my versions for trail running. Very stong.
    Reputation: zen bicycle's Avatar
    We have another victim..I mean enthusiast
    weird with the double post
    good job though
