Helmets (Max Air Flow)- Mtbr.com
Results 1 to 2 of 2
    Can anyone recommend an XC helmet? Max air flow and light weight are prefered.
    Also, what;s the difference between a road and MTB (XC) helmet?
    Cheers
    Mountain helmets typically provide more protection in the rear. All higher end and most mid-range helmets will provide good ventilation and light weight. Given that all helmets are basically Styrofoam they are all fairly light. If your looking for good ventilation you'll probably want to stay away from the department store varieties.
