helmet strap causing ingrown hairs- Mtbr.com
Results 1 to 27 of 27
    My helmet strap is giving me some painful ingrown hairs. Anyone had any experience with this? Not sure whether to grow a beard - preferrably not in the summer - or to shave more often. I currently shave every other day. Any advice is appreciated.
    Do NOT wear you helmet all day or to bed. I found that out the hard way. Just wear it when riding, then take it off when you're done.
    since 4/10/2009
    Reputation: Harold's Avatar
    helmet strap too tight?
    Mine is tight enough to keep the helmet from falling off, but it doesn't even touch my skin normally.
    Shave WITH the grain not against.
    Reputation: Eddie Mudster's Avatar
    A few products that can help control ingrown hairs are Tend Skin and Bump Patrol.
    Reputation: Steeljaws's Avatar
    May 2010
    You probably need this....
    Reputation: worthy_4242's Avatar
    try washing your helmet and straps work often. That seems to work for me
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    Simple , just never wear a helmet again and hope you dont fall on your head, I would try shaving down on the neck .....just shave down everywhere
    "If women don't find handsome , they should at least find you handy."-Red Green
    What you should be asking yourself is: Are men without beards really men?
    Quote Originally Posted by Schlitz Domino
    +1 (loosten your strapys)
    Aug 2005
    I just stopped shaving, solved that problem.
    Vermonter - bikes, beers and skis.
    You're welcome.
    Would the Jonas brothers endorse anything less than the best?
    http://www.rollingrazor.com/home/fd2010
    The jonas brothers can grow facial hair?
    Reputation: Singlespeed McGee's Avatar
    Quote Originally Posted by ecosse
    +1
    I'd just try loosening your straps.
    "So do me a favor. Find your bike, whatever kind of bike it is. And RIDE it." -Gary Fisher
    May 2010
    Loosen your straps as everyone else as said. They are rubbing your skin as hair is growing after you shave and causing the ingrown hairs.
    If you still have issues, use a "sensitive" shave gel/cream, shave with the grain (usually down and forward on face and straight down on your neck above the Adam's apple, then switches to upward from bottom neck to Adam's apple), shave regularly (everyday or every other day) and try a razor bump product of some kind (I used Bump Stop 2 for a long time and liked it but just this week saw Bump Patrol while I was at Target and picked it up and i already like it 10x more).
    Just $.02 worth of input from a guy with terrible ingrown hair and razor burn problems.
    ride the moment
    Reputation: Dogbrain's Avatar
    I quit shaving about 8 years ago and really can't go back. I just take a pair of clippers with no guard to my face and head every 2-3 weeks. I've gotten really attached to the scruff and the couple times I actually shaved it felt really really strange. As an added bonus, all that haircut money goes to bike parts.
    Hey Butthead, are we gonna die? - Beavis
    Quote Originally Posted by DoubleBat
    You're welcome.
    I'm sold.
    all good suggestions
    All good suggestions. I haven't washed my helmet in 5 years, so that might help. Can't loosen the strap too much without the helmet slipping around with pressure - i.e. if I took a fall, helmet would move a bit much.
    I'm gunna try to scruff approach. Maybe I'll shave everything but the neck, grow a neck beard.
    I used to get ingrown hairs all the time. Like others have said, I grew a beard and solved that problem.
    Also, the op said that he hadnt washed his helmet in five years. Arent helmets supposed to be replaced every 4 years or so? I dont mean to sound critical. I just thought I had heard that..
    Jun 2010
    Man up and grow the flavor saver.
    Quote Originally Posted by Jnthomps08
    I fall on the cynical side of things - tend to believe that the helmet manufacturers are trying to boost revenue (or cover their a$$) by saying that helmets should be replaced every 3 years. I just don't see the sense in it. If I were to buy a three year old model brand new, and use that for three years, than how is that any different than a six year old helmet?
    The Pain Train
    Jun 2010
    I am required to shave from work and used to suffer from bad razor burn, rashes, and bumps (not even from helmet straps, just very sensitive skin I guess) and have recently switched to L'Oreal MenExpert Comfort Max Anti-Irritation Shave Gel, and L'Oreal MenExpert Hydra-Energetic After-Shave Balm. I shave almost every day, and after only a couple uses it has made a huge difference. I definitely recommend giving it a shot.
    Nick Armstrong
    -Windsor Cliff 4900
    RockShox Dart2, Deore FD, Deore XT RD, TruVativ 5D, Alex DP17, WTB Velociraptors
    Reputation: CarolinaLL6's Avatar
    Quote Originally Posted by kenzen410
    My guess is the manufacturer has some loopy algorithm that takes into consideration the average wear and tear plus UV exposure then some inverse proportional liability factor combined with what you said about a little revenue in their pocket = cha-ching $
    Mike
    2011 Moto Fly Pro
    I just figured that sweat, over a period of time, would break down the components in the foam of the helmet. I thought maybe that degradation compromised the safety of the helmet.
    follow up
    Just wanted to follow up with everyone, as I'm sure you were on the edge of your seats in anticipation regarding my ingrown neck hair problems.
    I tried several of the recommendations, and so far things have cleared up a bit. I washed my helmet, loosened the chin strap, and began using some aftershave to keep the skin nice and soft. In the winter, with my wife's permission, I'll give a beard a try.
    So far so good, and thanks everyone for the suggestions.
    Reputation: bloodyknee's Avatar
    Best follow up post of the year. And yes, we were ALL on the edge of our seats on this one. Now we can enjoy our 4th of July weekend a little more.
    Ride ON...
