Helmet Replacement- Mtbr.com
Results 1 to 5 of 5
    May 2017
    Helmet Replacement
    Hi, I hit my helmet on a low tree today. It has a small dent. The helmet got hit pretty hard on the top of it. Do I need to replace it?
    Thank you
    Attached Thumbnails Attached Thumbnails Helmet Replacement-20180323_213608.jpg
    Helmets are designed to absorb AN impact not impacts. Only you know how hard it hit but if it truly was a substantial impact like you say, I would replace it. After all, what’s your head worth?
    Reputation: Lone Rager's Avatar
    Dec 2013
    Personally, I wouldn't replace a helmet with little dings that haven't significantly crushed or cracked the foam, but my head isn't worth much. Of course you can't truly know how compromised a helmet might be just by looking at it so it's a judgment call, and judging from that pic, I'd keep using it. A ding might be just what you need to justify that new helmet you've been lusting after.
    Do the math.
    Reputation: LyNx's Avatar
    Look inside the helmet at the EPS foam, see if you see any cracks, if you see any, then for sure replace, if not, it's your call, only you know how hard you hit. Personally, this is how my helmet gets used most of the time, I've hit so hard (got "grounded off") under a low branch and came to a stop so hard it cracked the helmet in several places, but it saved my neck taking the impact. I've taken other hits and got small dings/dents and have not replaced because foam showed no cracks.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Reputation: natas1321's Avatar
    Nov 2017
    Like the others I would not replace the helmet unless you are able to see some cracks or if you feel that the helmet's structurally compromised. My current helmet had saved my melon on a half dozen low branch impacts and one or two other impacts and still seems fine but I am looking at replacing it here soon.
    Sent from my HTC6535LVW using Tapatalk
  1. Trade Mountain bike helmet for Road bike helmet?
    By Drummerboy1975 in forum Apparel and Protection
    Last Post: 04-15-2012, 04:50 PM
  2. Replies: 9
    Last Post: 11-08-2011, 09:42 AM
  3. Replies: 36
    Last Post: 07-08-2011, 09:45 AM
  4. Convertible Full Face Helmet / XC helmet
    By Pimpride in forum Apparel and Protection
    Last Post: 04-15-2011, 08:42 PM
  5. GoPro helmet placement/mounting tips? (on FF helmet)
    By kdiff in forum Downhill - Freeride
    Last Post: 01-11-2011, 09:53 AM
