Helmet mount for digital camera- Mtbr.com
Results 1 to 26 of 26
    I have a Canon A550 digital camera which has video capture. I wanted to either buy or make a helmet mount for the camera. I've looked online but most mounts focus on the handlebar. Which would introduce too much vibration for off road biking.
    Any ideas or links for making a decent helmet mount for digital cameras?
    Here's the camera I have:
    <image src="https://www.itreviews.co.uk/graphics/normal/hardware/h1221.jpg">
    I cant see the picture but I assume it has a threaded hole for a tripod so an easy way would be a flat piece of aluminium and a velcro strap bolt the camera to the ali after cutting a couple of slots for the velcro strap and fix to your helmet .
    you may need to bend the ali plate to suit the curve of the helmet
    I thought about using the tripod mount.
    The problem is that the mount is not centered and is more to the side which would add more stress on it since the camera is not that light. Plus the threads are made out of a plastic piece that can pop out.
    Reputation: HEY HEY ITS HENDO's Avatar
    i would suggest the same as troutie
    with the addition of some strong double sided sticky stuff
    good luck with the setting up!! its a pain lol
    ...Scun.thorpe, UK
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I've seen some videos done with chest mounts. Seems to work great: perhaps more stable than helmet mount. One used a small tripod rigged to attach to the camelbak straps.
    Quote Originally Posted by perttime
    I considered a chest strap. But I'd like the camera to point where I'm looking.
    local trails rider
    Aug 2005
    Found a pic of the cardboard and duct tape chest mount.
    And a couple of videos shot using that rig:
    http://www.youtube.com/profile?user=...yUsersHere#g/u
    I think the chest rig tends to point where the trail is.
    Attached Thumbnails Attached Thumbnails Helmet mount for digital camera-user21233_pic3048_1264181076.jpg
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Here you go...
    Reputation: neilt's Avatar
    Or get one of these.
    Light freak
    Jun 2005
    Origially posted by neilt
    For what?? Taking pictures/movies of the stars??
    Quote Originally Posted by scar
    It is actually facing forward - just looks weird because of the angle from which I took the photo. There are loads of videos on YouTube if you want to check it out. Just search for Muvi or MD80.
    I looked at the Muvi camera and I'm not really looking to spend $80 on a camera. Basically wanted to utilize the one I have using either a helmet or chest mount.
    Quote Originally Posted by Dictatorsaurus
    The exact same camera costs $20 on eBay & DX
    Quote Originally Posted by zemike
    Model or sku?
    But the lowlight video quality is utterly disgusting.
    https://www.dealextreme.com/details.dx/sku.32022
    There's a short video on youtube and the camera seems ok. Do you have one? If so how do you like it?
    $20 is pretty darn cheap.
    Light freak
    Jun 2005
    Don't know what more you could ask for - it slices, it dices!
    stripped the thread in my lumix, not happy!
    was pretty sturdy however.
    Rabid Lana Fan
    Lowes and Hope Depot sell a kit for pretty cheap.
    Attached Thumbnails Attached Thumbnails Helmet mount for digital camera-duct-tape-zip-ties.jpg
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Quote Originally Posted by troutie-mtb
    That's exactly what I did. Home Depot sells aluminum flashing in the roofing section for about $0.50 a sheet. Get a piece, and fold it in half or thirds. Drill a 1/4" hole in the middle. Bend it to match the curvature of your helmet, and attach with zip ties or velcro straps (they sell them for organizing cables; Microcenter has a pack of them for cheap). After that I added some form rubber weather stripping I had lying around to keep the camera from spinning. I attach the camera with a short piece of allthread and a nut to lock it, but a short 1/4"-20 machine screw would be better. You might have to cut it down yourself.
    I've used my setup skiing and mountain biking. The mountain biking video is not bad, but the skiing video is not really watchable because of all the turning, even if I tried to look in a straight line all the time. To me it always looks better to record someone else doing the sport rather than just a first person point of view.
    For aiming, connect your camera to your TV with an AV out cable, and ideally sit on your bike in the living room so you can check the alignment while in riding position. I adjust it by adjusting where the helmet sits on my head then cinching down the adjustment knob in the back.
    Matt
    Oct 2010
    Quote Originally Posted by scar View Post
    i have this one but found the velcro to be really shoddy, couldn't get it to attach well. thus haven't tried it on the trail.
    i think the chest mount for a panasonic lumix is the way to go, if i could ever rig it up. does anyone know if the go pro mounts work with the standard thread size in digi cams?
    Mar 2011
    Quote Originally Posted by donkeykong0 View Post
    Ordered one a week ago. Waiting. From what you and some of the comments about the straps loosening the velcro is probably crap. Should be easy enough to replace with some decent velcro from a craft store.
    Oct 2010
    Quote Originally Posted by geraldatwork View Post
    true but you will see that it is kind of soldered together at the joint, it would be hard to replicate that with a DIY version without stitching or something.
    FnG
    this is mine:
    using this camera:
    https://www.amazon.com/Midland-XTC10...7&sr=8-1-spell
    quality is pretty good. Comes with 5 different mount types.
    Mar 2011
    Received mine yesterday. You are basically right. The velcro doesn't stick together well and would be hard to replace. Mostly disappointed in the device as it is hard to get the platform snug on the helmet. I have a spare lid and wound up using duct tape to secure it. Hopefully I have the right angle. It was inexpensive under $9 delivered and at the end of the day the tripod mount is secure to the device and should be doable.
    Look into Ram Mounts, they offer all kinds of solutions.
