Helmet cam ???s- Mtbr.com
Results 1 to 7 of 7
Thread: Helmet cam ???s
    Helmet cam ???s
    Looking to get a Helmet camera in the near future. I was looking at Viosport, and Helmet Camera Extreme. The Extreme has 480 lines of resolution while the Viosport has 380 lines. What exactly does that mean??? Is there that big of a difference??? What company would you recommend? Any other advice/comments/suggestions/ input. is welcome!!!
    L8R
    Buck
    Reputation: phil.'s Avatar
    Quote Originally Posted by Buck
    L8R
    Buck
    You can pick up a 480line lipstick cam kit for abou $200 including shipping from www.rfconcepts.com.
    Not sure on the how much of a quality difference between 380 and 480 except about 25% more lines.
    more lines= better
    L8R
    Buck
    get the 480 line kit.. more lines of resolution gives a clearer image.
    Don't even consider the low res camera. Check out sportzshot.com. I have been abusing one for almost 2 years now. Get the wide angle and the remote.
    Its only 1" on the map!
    Reputation: mtbbill's Avatar
    Quote Originally Posted by phil.
    I'll second the 480 line model from RF Concepts. I bought the 380 line model from helmetcamera.com (before the 480 was available). If I had to do it over again I would go with RFconcepts strictly based on price. Another poster talked about a remote.
    If I was going to buy any accessory for the lipstick setup, it would be the LANC remote cable. The biggest pain of the lipstick is digging in and out of your pack to start and stop recording. And because it is in your pack, an IR remote (if your camcorder came with one) will not "reach". Additionally you always have to orchestrate taking off your helmet and pack at the same time just to stop an start recording. The remote cable gives you both control of the camcorder and and visual indication of you recording. One common thing folks also have to do is devise something to keep the record button on the camcorder from being pressed with it is in your pack. Simply things like weight shifts and bumps can cause stuff in your pack to press the button. You just have to be imaginative there.
    the link rfconcepts.com doesn't work, thanks for the info. Keep it coming.
    L8R
    Buck
    L8R
    Buck
    Try this one RF Concepts
  1. Giro Gila Helmet $25, reg. $70
    By CraigH in forum Apparel and Protection
    Last Post: 02-06-2004, 04:30 PM
  2. new helmet?
    By gary in forum Apparel and Protection
    Last Post: 02-03-2004, 07:31 PM
  3. Looking into a Helmet Camera, but am uneducated.
    By Burpethead in forum Apparel and Protection
    Last Post: 01-22-2004, 07:48 AM
  4. $50 helmet for $6, Bell Aquila, small only...
    Last Post: 01-19-2004, 05:19 PM
  5. Moto clothing / helmet use?
    By spacetrucking in forum Apparel and Protection
    Last Post: 01-19-2004, 06:37 AM
