Which helmet cam is best? Viosport or helmetcam.com- Mtbr.com
Results 1 to 11 of 11
    I like air!
    Reputation: milhouse's Avatar
    I just ordered a Sony HC42 camcorder now Im trying to figure which remote helmet cam to get. I was originaly looking at the Viosport Adventure Cam 3 because additional lens attachments (wide angle-telephoto). After doing a search I found people were having fogging issues with Viosport cams. Then I was looking at the helmetcam.com which looks good because it has a more rugged casing and is water proof so I figure it shouldnt have fogging issues. But then again Im not sure. Anyone have any experience with them and what works best.
    Dec 2004
    Quote Originally Posted by milhouse
    on ebay they have helmet cams for about 110, with 1/4 ccd i think, 420 lines, mic, battery, camera, and a helmet mount. oh yeah, 30 fps
    I like air!
    Quote Originally Posted by freerider167
    Thanks man. I'm looking at 520 lines or better. Im not so concerned about cost as I am about quality of video.
    Reputation: zachdank's Avatar
    Jun 2005
    I have been using a viosport for years. It rocks
    Rocket Scientist
    Reputation: bpatterson6's Avatar
    I have the Adventure cam 3 with the Optional Wide angle Lens.
    It's super nice. I have had 1 minor issue with it so far. The cable that connects the Camera, Power to the CamCorder got a short in it and wouldnt function correctly, I got a new one and it works great again. Other than that, the Video has been super!
    Dec 2004
    nm, but to others who want one ebay is a good place. if you want to save money i'd see if you could get it off ebay, it's just an idea.
    How are they achieving the 30fps???
    L8Rz
    Buck
    I like air!
    Quote Originally Posted by zachdank
    zachdank and bpatterson6. Either of you guys ever have fogging issues? Does the UV filter do anything? Can the helmet mount be removed and installed on another helmet? Thanks.
    N* Bomber Crew
    Reputation: Raptordude's Avatar
    I don't use either, I use a HoytTech HC-Pro...and its absolutley amazing.
    Its better than the competition...it has 580 lines of TV Resolution, a GREAT lens (Pretty wide, but not rediculous) comes with a lot of stuff, and is just very high quality. I reccomend it. On top of all that, its very affordable.
    www.hoyttech.com
    (Model: HC Pro)
    Did I mention Sony Ex-View?
    Big Edit: I run a Sony HC-42, and the HoytTech cam as well. I strongly suggest the helmet cam I got. Its a GREAT product, I can get indepth with it and give you some samples or pictures if you would like. One thing you will want to purchase for your helmet cam setup is a LANC remote control.
    Northstar 2008 Riding Crew
    paparazzi tee
    Reputation: alloutprodux's Avatar
    Dec 2004
    i've got a vio3, got rid of the fogging issue with a nofog cloth,
    havent had any problems since...
    the vio3 & the hoyttech cam both use the same chip,
    hoyttech claims 580, vio claims its 520...
    same thing tho.
    the UV filters definately help the camera from geeking out
    going from sun to shadows, i'd get em.
    I like air!
    Quote Originally Posted by Raptordude
    www.hoyttech.com
    (Model: HC Pro)
    Hey Raptordude, thanks for the info. Looks like a good option. Only reason I would stil choose the Viosport is because of the optional lenses. I would be interested in seeing a shot or a video clip from the helmet mount if you have one.
