GPS/Helmet Cam/Google Earth synch?- Mtbr.com
Results 1 to 37 of 37
    Reputation: D-Town's Avatar
    I borrowed a friend's helmet cam on my last ride to test the quality of the camera. Needless to say, I was impressed. It also happened that I had my Garmin 500 recording at the same time as well. Is it possible to synch these two togther on one screen? I'm interested in having some type of dot or symbol follow my track around in google earth (or similar software) while watching the video from the helmet cam.
    Suggestions?
    Nothing but style!
    The Punk Hucker
    Reputation: PissedOffCil's Avatar
    Oct 2007
    I think there's a SportTracks plugin that allows to set images to points on a trail. If I remember correctly an idea was obviously to add video support but I can't tell if it's been done or not.
    Edit : Out of curiosity, I checked. It does supprot video : http://www.zonefivesoftware.com/Spor...tail.php?id=62
    Not sure how it can really "sync" both tracks...
    Beware the hucking bear!
    since 4/10/2009
    Reputation: Harold's Avatar
    I have seen the sort of thing you are asking about. I have not even been able to find a cheap (or let alone free) solution to this.
    http://www.geology.smu.edu/~dpa-www/...deo/index.html
    http://www.itsamerica.com/Files/vidsync.htm
    http://rlcracing.com/synchronized-vi...FQ1N5QodMEZMWg
    The capability is there, but I can't find anything suggesting it's available for the consumer market yet.
    Reputation: Nathan Cloud's Avatar
    This is something I have been wanting to try myself. I have been trying to get my race team to strap on a helmet cam and pack a gps, but never had any luck.
    My plan is this:
    1) Load up my track in Topofusion or Google Earth.
    2) Load up the video in another window so they are side by side or at least arranged nice enough
    3) Play the track at real time and start the video
    4) Use http://camstudio.org/ to capture everything that is going on
    5) Clean up the video
    Unless I can video capture each window separately then smoosh them together in some sort of video program. Video editing is not my strong point!
    Does not seem overly complicated?
    I dunno.
    Would love some software to do it though!
    Crankfire.com / New Englandish Mountain Biking Community
    since 4/10/2009
    Quote Originally Posted by Nathan Cloud
    My plan is this:
    I dunno.
    That seems like it would work...but yeah, way complicated.
    I would really like to see an elegant solution to this, where you could say, manually sync your GPS clock with the video clock and do a dot race on the map while the video plays.
    However, one serious limitation I see is how you'd manage video editing. say, you wanted to cut a really long uphill grunt or you wanted to splice a helmet cam video with some stationary video shots your bud did, or a slow-mo replay or something like that. You'd basically need to use raw unedited video. It would also be a real pain if you had to swap memory cards or tapes or batteries mid-ride.
    mtbr dismember
    Reputation: Wherewolf's Avatar
    Perhaps this?
    Gobandit HD Action Camcorder a new POV camera with built in GPS so you can overlay information on the video. Sounds interesting but the quality of the video they posted is terrible! Info here: http://www.geeky-gadgets.com/gobandi...der-17-2-2010/
    Even the video on Vimeo is terrible:
    I do remember seeing a video of this sort on Topofusions site a while back - I can't find the exact one I am thinking of, but I did find these:
    http://www.topofusion.com/forum/index.php?topic=3810.0
    http://www.youtube.com/watch?v=Kjw-2uz1KdE
    I imagine they took a similar approach to what I outlined?
    I dunno.
    since 4/10/2009
    Quote Originally Posted by Wherewolf
    You aren't kidding...that vid is terrible. And it doesn't appear to be due to compression from uploading, either.
    I dunno.
    So does this one, though the problems here are typical to youtube compression.
    This is the original movie that has sparked my interst. I'm still searching for some solution but like others have said, it will not be straight forward.
    http://www.youtube.com/watch?v=_OFQW93Zm4U
    Nothing but style!
    since 4/10/2009
    Quote Originally Posted by D-Town
    You know, I thought that guy was going too fast with so many walkers around. LOL.
    Yeah, I am not sure how folks pull that off.
    Dec 2009
    I was amazed when I synched the GPS data to the riding track to see the speed I was going at.
    You will also note a couple of meters before crashing at the 1:53 I block my front wheel - and had not much control over my bike after that. I guess that was my main mistake. A final word to the crash - Gopro camera has a large FOV (in the 960p setting) so everything appears narrower. Anyway the remarks from the walker was that I should have warned before passing - I bought a bell since so now I'll be sure to use it well ahead before passing anyone.
    Dec 2009
    As to how I synchronized the GPS google earth map.
    Load your GPX data into Active GPX Route Player.
    http://www.hybridgeotools.com/
    Use a screen recording capture software (camstudio, fraps etc) to record the google earth playback . Be sure to record using same frame rate as your helmet cam video.
    Go in your video editing software and synch the two tracks.
    If you do not know how to synch video make a search in youtube on
    "multi camera editing" or the likes.
    Thats about it.
    Dec 2009
    Here's a video experimenting with a dashboard.
    http://www.youtube.com/watch?v=gdqSw7BQvYo
    Used Dashware http://www.chasecam.com/catalog/25/dashware which allows you to create your own dashboards and feed it any .csv (GPX converted) data. Very nice piece of software. But expensive.
    I am searching for a cheaper alternative. Anyone know of similar software let me know!!
    Reputation: diver160651's Avatar
    I used my 705 to produce trail maps see the link below
    Jt
    Here are a few Video Trail Guides I shot - just for fun:
    http://destinationproductions.com/cu...PassionTrails/
    since 4/10/2009
    lol, so you're the guy who crashed in the vid? That was funny, IMO, more than anything else. The path looked like it was icy (the ice that forms when snow gets packed), so that's why I thought you were going a bit fast. Were you running any studded tires or basic knobbies?
    I don't think bells really do anything. A verbal warning gets their attention better, but a lot of people tend to react to "on your left" by moving left into your path. Might try something like "bicycle back" or something along those lines. Or you could go gross overkill and get an air horn to blow their eardrums.
    Yeah, what you describe sounds a lot like what the rest of us seem to have expected. I think the OP was after a single program that could do it, like with geotagging static photos. Thanks for actually saying what programs you used, though.
    Scott in Tucson
    Reputation: Krein's Avatar
    I dunno.
    Maybe you are thinking of this one?
    <object width="640" height="480"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=2739750&amp;server=vimeo.com &amp;show_title=1&amp;show_byline=1&amp;show_portr ait=0&amp;color=&amp;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=2739750&amp;server=vimeo.com &amp;show_title=1&amp;show_byline=1&amp;show_portr ait=0&amp;color=&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="640" height="480"></embed></object><p><a href="http://vimeo.com/2739750">GPS playback + Helmet Cam</a> from <a href="http://vimeo.com/user344663">Scott Morris</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
    Didn't take too long to put it together, but I did have to capture the TF replay using Camstudio, then combine in corel video studio.
    I think keeping either the map or helmet cam video taking up the full frame (and the other in the corner) would have been better. The stats are hard to read, even on vimeo.
    I'd like to do more of this, and perhaps add more support in TF, but I still don't have a helmet cam.
    Author of TopoFusion GPS Software. MTB+backpacking = bikepacking.net. Ride Diary.
    Quote Originally Posted by Krein
    Yup, that's the one!
    Dec 2009
    I like Dashware, have been using it for a couple of months. Dashware will give you a moving map, but without the google maps presentation.
    I'm going to try some of the suggestions you guys have made to overlay google maps to my videos.
    Just wish I had a power meter on my mountain bike...
    race telemetry without moving map: <object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/pjq10IcAaWU&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/pjq10IcAaWU&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
    ride with GPS moving map:
    <object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/PGdyp6Is_6s&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/PGdyp6Is_6s&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
    since 4/10/2009
    Hey, that Dashware is the best option I've seen yet. Surprising it won't let you choose a background for the GPS map, however.
    Dec 2009
    Quote Originally Posted by NateHawk
    actually, you can choose a background and color but i chose to make it transparent. i think it would be easier to see if i had used a background.
    Dec 2009
    SteelerHoo, thats a great dashboard design you made.
    Is there a way to add a altitude versus time graph? My trial version expired and couldn't find out a way.
    since 4/10/2009
    Quote Originally Posted by SteelerHoo
    I meant an actual map for a background.
    Dec 2009
    Quote Originally Posted by luap
    a guy on the Dashware forum was able to add one. i haven't tried it yet, but will get to it sometime.
    Dec 2009
    gotcha
    Here's my approach to merging video, GPS and power data:
    <object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/tmvQD1Xg6jk&hl=en_US&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/tmvQD1Xg6jk&hl=en_US&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
    The application has all the features that I want, so now I'm working on the user interface.
    And Going Nowhere Fast
    Reputation: jroar's Avatar
    Awesome. Any plans to sell your application or distribute via shareware / freeware? If the solution exists, I'd rather spend my time doing something else - like riding my bike.
    Dead Last Doesn't Mean Loser
    Reputation: LoIQ's Avatar
    Check out this site http://www.gpvsystems.com/index.htm The only way I can find to get this software is to buy a helmet cam from this company
    http://hoyttech.com/
    Hi UKB, I like your interface. If you would like to sell a copy, I'm your boy. I'm very impressed with your HR and power out. I would like to see cadence also.
    trail rat
    Reputation: slocaus's Avatar
    Quote Originally Posted by LoIQ
    There is a "Buy Now" button on the lower right.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Quote Originally Posted by OldMTBfreak
    Thanks for the compliments! Cadence is already there - it is the RPM number and bar chart, next to power.
    I'm working on the product version now. My partner is going to work on the business side. I'll post back when we have something to announce.
    govt kontrakt projkt mgr
    Reputation: ArmySlowRdr's Avatar
    Quote Originally Posted by slocaus
    But it is just a scheme to get you to the hoyt's site where you must buy a cam i gather to get the software. I think i saw this whole setup reviewed somewhere else--and the image quality received about half a star as i recall--hard to say if the software, if it could be procured somehow separately, is proprietary to work only with Hoyt cams or not.
    Dec 2009
    Here's a link to a free ap that adds telemetry. doesn't have a moving map though, but i'm sure people can figure out how to add that functionality.
    pretty cool, in the span of several months, there are at least 4 guys that I know of that are writing (and already using) overlay software.
    hopefully it's only a short amount of time until we see footage like this on live broadcasts of pro events.
    http://sites.google.com/site/verymadmart/cyclecam
    Thanks for the link !
    Dec 2009
    Haven't had the time to try it yet but seems google has just added the gps synch feature in google earth.
    Hope to have some time to try it out soon!
    Any one tried it yet?
    http://google-latlong.blogspot.com/2...-earth-52.html
    The Punk Hucker
    Oct 2007
    That looks cool!
    since 4/10/2009
    Quote Originally Posted by PissedOffCil
    That looks cool!
    indeed, looks like there are some nice add-on features there.
    Dec 2009
    Tried it and its nice event hough has not all the functions I was hoping for.
    In case anyone is interested there is a site showing live telemetry data of racers in google earth of the Tour de Suisse race. 2 stages left today and tomorrow.
    http://www.athlosoft.com/tds/
