GoPro mounting on THE Helmet 真how??- Mtbr.com
Results 1 to 2 of 2
    Reputation: ritopc's Avatar
    Hi,
    I have a GoPro which I want to install on my Fullface Helmet. The helmet its a THE composite, and has no vents to attach the helmet mount provided with the camera. I also tried to use the 3M stick-ons mounts, but the shape of the helmets is weird and found no other place to attach them but at the side of the helmets where the google straps pass by. Does anyone have the same combo; The Helmet/GoPro? Did you find an alternative helmet mount?
    Thanks in advance.
    Quote Originally Posted by Warp
    ...es como acomodarte los calzones, seguro lo puede hacer alguien pero es mejor que lo haga uno mismo
    Try a chin mount on the full face, in my experience it offers the best perspective and smoothest video (your head is the most isolated part of your body). You can usually use plastic ties on the chin area if it doesn't have enough of a flat surface.
