Gloves to protect against palm blisters- Mtbr.com
Results 1 to 21 of 21
    Any recommendations?
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    I'd think any glove should do. Sounds counter intuitive, but maybe a thinner glove that dries faster.
    The best way to toughen up hands, trail work.
    You grip the bar too tightly
    Gloves, grips, technique , could be a few different things
    Reputation: targnik's Avatar
    Jan 2014
    K.Y??
    #1 resolution... Ride it like I stole it!!
    "Mountain biking: the under-rated and drug-free antidepressant"
    Oct 2015
    Try some Lizard Skin DSP grips. I had ODI lock on's of all types and always got bad calluses, not anymore with the DSP grips.
    Finally!
    Reputation: Terranaut's Avatar
    Jun 2014
    I don't think your gloves are the issue. Sounds to me like you put too much weight/grip on your bars. As stated above I would look at technique first before spending money to fix this. Or maybe even grips first before gloves.
    Guest
    Quote Originally Posted by bank5 View Post
    What part of the palm is blistering and under what conditions? Are you currently wearing any gloves? What grips do you use?
    9 lives
    To add to Forster's question, "Where on the palm are the blisters forming"?
    If your experiencing prolonged severe friction, maybe you need to back down the intensity and allow your hands to develop callouses. Callouses are a good thing because they protect the softer skin underneath.
    I wear gloves when I ride but I don't wear gloves for weight lifting, so I've developed a nice little row of callouses.
    F*ck Cancer
    Eat your veggies
    Bannėd
    Reputation: Trevor Ochmonek's Avatar
    May 2015
    Silly teenagers! You've got to switch up the hand you are using. Also known as the stranger.
    That's more than Catfish would do.
    Dec 2013
    I'd look at grips first gloves don't change much. Esi chunkies are the best 20 bucks Iv put into my bike.
    Reputation: armii's Avatar
    Jan 2016
    I really like these and donít wear any of my other gloves anymore. The Merican - Stars n Bars USA ? Handup Gloves
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    As others stated I would start with your bike fit. If you are putting too much pressure on your hands this will cause pain and blisters. Additionally if you bar is too low this can also contribute.
    The other thing to consider is the bar sweep. If you have a very straight bar or a very bent bar these could contribute to pain on your hands.
    I also find that the more technical the trails for me, the more calluses I get. Lots of pulling up on the bar greatly contributes to this. For me very thin gloves that fit tightly but perfectly work best. For my hand size Fox gloves work great but everyone has different hand sizes. I also have a Giro pair that are really nice. Additional padding on the gloves will, counterintuitively, add all kinds blister points. Thin fast drying palms, snug fit and look for a grip diameter that works for you.
    MTBR Posting Guidelines
    calories>electrons
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by armii View Post
    I just got a pair of handup gloves, and found I liked them better than I expected. They fit really nice, and the lack of padding in the palm isn't a problem at all. I use ODI Rogue grips, fwiw.
    I agree with the other folks suggesting the problem might not even be the gloves (or lack thereof).
    Jan 2016
    Quote Originally Posted by Harold View Post
    . . . I use ODI Rogue grips, fwiw. . .
    Actually I use ODI Rogue grips also.
    Give Rosie and her five sisters a break!
    @njcshreds
    Reputation: GoingNowhere's Avatar
    Oct 2014
    I have better luck when I wash my gloves after a few rides. When I hit the bike park in the summer time I'll switch up gloves at lunch time and wash them when I get home.
    Instagram = @njcshreds
    '17 Kona Big Kahuna
    '08 Kona Cowan
    '05 Kona Cowan
    '05 Kona Stab Supreme
    '06 Kona Lisa HT (hers)
    I use these and like em!
    How do the gloves fit ? If they are to big, they can cause blisters
    Apr 2016
    Hi,
    Make sure you have a sport or task-specific glove. Donít wear anything under your gloves, like rings.
    And make sure your gloves fit. You donít want the glove to be too loose since loose gloves will just rub your skin more.
    And you donít want your glove to be too tight. You want it to fit like, well, like a glove snug.
    And make sure there are no seams where pressure is being applied or between areas of high friction, such as the curve between your thumb and forefinger.
    Yeah!
    Reputation: Flamingtaco's Avatar
    Mar 2012
    Blisters on the hands are largely a result of friction, not weight. At 375Lbs I don't get blisters on a 25 mile trail ride or 50 mile road ride. My palms hurt like hell when I first started riding again, but never a blister.
    I have Cannondale D3 grips and Lizardskins tape on the bar ends. Pearl Izumi Elite Gel gloves do a good job of reducing hand pain/fatigue on long rides. I have yet to develop visible callouses.
    I will suffer no butt-hurt fools!
  1. Gloves with palm padding
    By myke2241 in forum Apparel and Protection
    Last Post: 07-14-2015, 12:39 PM
  2. Palm blisters, what to do?
    By NWS in forum Downhill - Freeride
    Last Post: 06-13-2015, 10:17 PM
  3. gloves without blisters?
    By IamtheYeti in forum Apparel and Protection
    Last Post: 09-13-2013, 10:46 PM
  4. Gloves you use that have done a good job of protecting your palm?
    By uneek78 in forum Apparel and Protection
    Last Post: 01-16-2013, 02:13 PM
  5. Gloves with Palm Protection???
    By ironbike1 in forum Apparel and Protection
    Last Post: 03-07-2012, 07:16 AM
