Gloves for MTB- Mtbr.com
Results 1 to 10 of 10
Thread: Gloves for MTB
    Gloves for MTB
    I recently built up a new bike and my hand grips are little to none. On top of that i had a bad fall recently and my palm is bruised up pretty badly. I was wondering if anyone has any recommendations for gloves that have a huge amount of cushioning on the hands and are very grippy.
    Jun 2010
    Just go to your local motorcycle dealership or motorcycle gear shop (such as Cycle Gear if you live in a metro area) and pick up some light-weight dirt bike riding gloves.
    You should be able to find a pair for 10-15 dollars on sale.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Go to your local bike shop (LBS) and have a look at padded cycling gloves , you might also want to look at grips while your there . Grips can and will make a huge difference for you .
    Reputation: Gasp4Air's Avatar
    I recently bruised the heel of my right hand in a fall. Riding became painful. I tried a set of Ergons and found them very helpful. The only drawback is on downhill techy stuff I can't get my palm behind the grip as well and have to grab it really tightly for control. However, the grips still made it possible for me to keep riding with minimum discomfort. I've healed enough to switch to a comfy pair of WTB foam grips, and after a while I'll likely be back to my ODIs.
    Use it, use it, use it while you still have it.
    Reputation: Bobby12many's Avatar
    The Bont. Satellite Fusion GelFoam glove is the cushiest/most padded glove I have ever seen that was intended for MTB use. Might wanna check them out...
    http://bontrager.com/model/07759
    I got these last season and they hold up very well. Plus you can just throw them in the washer and mine still look brand new! I got mine on ebay.
    http://www.mechanix.com/m-pact-glove
    Reputation: wave180's Avatar
    May 2010
    I got these http://cgi.ebay.com/ebaymotors/SNAP-...#ht_500wt_1182 for $7 at Biglots today.
    Reputation: bloodyknee's Avatar
    I prefer really good grips and lightly padded gloves. I have less problems that way. Current set up is: Yeti Grips with Pearl Izumi Elite Full Finger gloves. The carbon bar probably doesn't hurt either.
    SSolo, on your left!
    Fox Digit or Incline....check Nashbar for a smokin deal on the Inclines.
    Get off the couch and ride! :)
    Reputation: salpic's Avatar
    Jun 2010
    How do these hold up in hot and humid weather?
