Full Face XC helmet
Printable View
  • 01-07-2010
    singlespeedrider
    Full Face XC helmet
    I have looked high and low on the internet but still looking for something with a little more coverage than the standard mushroom top helmet. I watched my brother go down a week and a half ago and spend 5 days in the hospital putting his face back together. Is there any options other than the MET Parachute and the Casco Viper (both only available in europe) that somewhat bridge the gap between downhill and XC. If any of you have modded a full face for better cooling how does that work and what model helmet. I am a SS rider and love to climb but also like the downhill reward.
    Any advise would be great,
  • 01-07-2010
    JimC.
    Advice? Sure...
    I assume you carry a pack. Take 2 helmets, and use the normal type FF for the descent. Problem solved.
    (similarly those riding FR or DH suffer going up carrying all their gear, because on the descent, one dresses for the crash, not the ride. Sort of similar too, to car seat belts...nobody ever needs wear one, until involved in a crash, and then you better be wearing one).
    There's no "XC" FF helmet for a reason.
    Jim
  • 01-07-2010
    singlespeedrider
    JimC.
    That is the answer I am expecting but with hopes that there is another answer. I do not want the protection just for the steep downhill but all the time cause you never know when you are going to crash.
    Thanks for the info
  • 01-07-2010
    jjange68
    I too have been down this road I ride SS and was thinking I would like some extra protection but would a fullface be overkill I know where you're coming from SSrider. I will probably pull the trigger on a FF just looking for a good deal.
  • 01-07-2010
    JimC.
    other sources...
    http://reviews.mtbr.com/blog/full-fa...-guide-charts/
    Expensive but maybe your only choice, bear in mind that Giro Switchblades (XC-FF early 2000s) cost a lot, if not more, than some FF FR helmets.
    The Troy Lee D2 carbon is only 937 grams, or 2.07 lbs. An XC one is usually ~ 300 grams or 2/3 of a lb.
    Not ideal, but there you have it.
    Jim
  • 01-07-2010
    womble
    FF XC helmets have had several threads dedicated to them in the past. On the convertible front, there's nothing more out there than the Viper and the Parachute unless you find an ancient Switchblade from somwhere.
    The usual recommendation for a well ventilated and light-ish FF is the Deviant.
    I've owned both the Deviant and the Viper, and the Deviant is actually the cooler of the two, especially with the cheek pads removed.
  • 01-08-2010
    wreckedrex
    I've got a deviant and like it, but it sucks to climb in. All the vents help the top of my head, but breathing into the chin bar heats up my face and gets uncomfy pretty quickly.
  • 01-08-2010
    singlespeedrider
    are you leaving the cheek pads in our removing them?
  • 01-08-2010
    JayTee
    I have yet to purchase a mountain bike-specific full face helmet but I do have experience with FF helmets in my motocross days and my experience is that you are going to have that warm air from your breathing going back into your face due to the chin bar and there just really is no way around that, no matter what helmet you get.
  • 01-09-2010
    Shredr
    Go Old School
    YOUR SOLUTION: The old Troy Lee TL COMP = screw on/off removable face guard, excellent head coverage, great protection. A little warm though.Much better protection than the Giro Switchblade.
    I still have one from the old downhill days, sorry no pic. Do a search for pics.
  • 01-09-2010
    singlespeedrider
    I am getting all answers I thought I would get. I was just hoping there was something somebody knows about that I did not. Thank you everyone for all your input looks like the best bet is to learn to tuck and roll or get the deviant and pull some of the padding out of it.
  • 01-11-2010
    wreckedrex
    I haven't tried removing them, never really crossed my mind before. I'll give it a shot the next time I dig it out.
  • 01-11-2010
    sanjuro
    FYI, the problem is liability.
    If there was a XC full-face helmet available in the US, some fool would use it at the local jump/DH park, and then sue when the dentist bill comes in.
  • 01-11-2010
    singlespeedrider
    Sounds like there is quite a few people doing this with good results. I think I am going to go this route but wanted to check with a few different people before I drop all that money on a helmet. I am in So. Cal and it was close to 80 over the weekend in January so I need the cooling but want to protect the face.
  • 01-11-2010
    qkenuf4u
    https://images.google.com/imgres?img...a%3DN%26um%3D1
    heres a link to an old ad from back in 96... couple pics of the helmet and how it was built...
  • 01-14-2010
    macdaddyg2006
    How about the Deviant II?
    Anyone have the 2010 Deviant II and can comment? Thanks.
  • 01-14-2010
    davyb123
    Poc
    I would check out the 2010 POC Cortex Flow. The faceguard is angled down a little bit so it looks like the breathability it high.
    Great pictures and a full review.......
    http://www.competitivecyclist.com/za...RODUCT.ID=5619
  • 02-12-2010
    singlespeedrider
    Thoughts
    what do people think about something like this. I can not see breathing bing an issue still might be a little warm
  • 02-13-2010
    dwyooaj
    that's a nascar pit helmet, the opening is there to fit a 2 way radio. I wouldn't use that, probably still very hot and no mouth/dental protection so then why bother with a ff.
  • 02-13-2010
    Bent Wheel
    Have you checked out the Bell Bellistic?
  • 02-13-2010
    singlespeedrider
    I do not see this being a good helmet for downhill riding but think it would add more protection for XC. You are right not much mouth or dental but more than we are all wearing now.
    Just looking at options.
  • 02-13-2010
    dwyooaj
    No worthwhile compromise really exists. I use my ff for my gnarlier "AM" rides, and just strap it to my pack when climbing if it's hot. Its a pro-tec auger, fairly light and well-vented.
  • 02-13-2010
    jhandy
    Have you looked at FF kayaking helmets?
