Full Face Helmet Question
Printable View
  • 03-29-2006
    gkler
    I got a new full face helmet and I am wondering if it is too big for me. How tight should the fit be. Is it supposed to be tight. This is my first one so I can't tell if I got it right.
  • 03-29-2006
    fred.r
    Put it and and buckle the chin strap, see if you can get it too block your vision pretty easily, and see if you can pull it off your head too. If you can do either of these pretty easily I'd say it's too big.
  • 03-29-2006
    fiddy_ryder
    you want it snug when new.. you should feel a bit of pressure on your cheeks. the helmet should not twist/spin at all. it will break in and loosen up a bit to the shape of you head after wearing it a bit.
  • 03-29-2006
    BJ-
    when shaking your head side to side it should move no more than an inch, if so its to big and youll need to use your spacers. what helmet is it?
  • 03-29-2006
    gkler
    Giro
    Giro Remedy size medium.
  • 03-29-2006
    ICanDigIt
    Hey...
    I bought a M Remedy based mainly on the Giro sizing specs. I did try it on in the store and my initial gut feeling was that it felt to big. I went with it anyway...not having used a full face before, I just figured thats how it should feel. Later, I went out and tried on a S Remedy just to see...BIG difference. It felt a little snug around the cheeks, but so much better overall. There was very little movement, if any, when I moved my head, compared to the M, which would slide around noticably. I ended buying the S. Also remember that a helmet will loosen up a little as you break it in.
    In other words, just what fiddy said...
  • 03-30-2006
    5$Milkshake
    With the chin strap comfortably tightened the helmet should feel snug everywhere. The real test though is pulling/twisting/turning the helmet with your hands, don't just shake your head back and forth - a properly fitting full-face will move very little in any direction. Pull up on the chin guard, if it turns in to a nose or forehead guard you have a full-face helmet that won't protect your full face. Also, helmets simply don't fit all heads equally well. Your head may fit one brand better than another. My Troy Lee D2 and the Giro Remedy fit me perfectly while the Specialized Deviant, even with the chin strap stangling tight is an absolute joke - I can pretty much pull the helmet up/back and almost completely off my head. A helmet can only do it's job if it fits properly.
  • 04-02-2006
    Ace1
    After reading this I'm now a little concerned about which size helmet to order.
    (As I posted in another thread) I'm going with a Troy Lee.
    The sizing chart says 56 - 59cm = Medium/Large
    My head is 57cm... :p
    Anyone had any experience with TL sizing?
    Should I go for the large or the medium?
    thanks,
