First MTB shorts- Mtbr.com
Results 1 to 22 of 22
    Aug 2010
    First MTB shorts
    I just bought my first pair of MTB shorts, the Fox Men's Ranger 12 Short, which comes with a removable chamois. Based on the tight fit of the chamois, I'm assuming that you wear the chamois as underwear and do not wear any underwear underneath it?
    Granny gear lover
    Based on the tight fit of the chamois, I'm assuming that you wear the chamois as underwear and do not wear any underwear underneath it? And thank you for having me in this community.
    Correct. No undies.
    Reputation: sgtjim57's Avatar
    Yes.
    2017 Cannondale Scalpel Si Carbon 3 (27.5)
    Jan 2011
    correct no undies and buy some cream it will help alot
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Quote Originally Posted by trdspectacoma View Post
    X2.. chammy creme helps a lot especially if you ride long trips... there are plenty out there and most are good and help, but I have found this stuff works just as good and is WAY cheaper..
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    insert blank disk
    Reputation: bikesordeath's Avatar
    Ok here's a newb question: where are you guys rubbing that exactly? I can think of a couple of places. Not sure if you can answer on a public forum. This should be fun
    Oct 2007
    Quote Originally Posted by down2ride View Post
    anywhere it chafes, too much is better than not enough,.. well to a point anyway
    Dec 2011
    as nasty as it may sound, you don't wear underwear when biking. xD I learned the uncomfortable way.
    Jan 2011
    usually where the skins meet that is the point of the cream where it should be. once you start riding loonger and using the shorts you will start knowing where to put it
    Reputation: rogbie's Avatar
    You wear undies, but only banana hammocks under tight fitting clothes. No one likes "panty lines".
    In seriousness, chamois cream is a savior. Rub chamois cream over the entire chamois then ride in comfort.
    I use shea butter with tea tree oil added as an anti-bacterial.
    Why dont you guys just wear some under armour compression shorts(or anything like it)? You wont be uncomfortable at all no matter what type of short/pant you ride in. Seems kind of silly to have to lather up just to wear a pair of "bike shorts" lol.
    Quote Originally Posted by JCP281 View Post
    I'm with you lol, took one look at the liner my Enduro's came with, literally had cushioning for a set of balls and a penis, It even had the head cut into it. I think I wore them on one quick loop around my neighborhood and than never again.
    Aug 2010
    Does the Under Armour compression shorts come with some type of padding or a chamois?
    Granny gear lover
    No, it's just for compression. I would suggest wearing padded short with your choice of chamois cream at first. Once your butt gets used to riding wear whatever you want. I will always wear a padded short of some type, with or without baggy shorts. Do what is most comfy for you.
    "Your opinion may vary, but it's stupid." -Rich Dillen
    Reputation: broncojd78's Avatar
    Feb 2010
    no chaffing for me but no long rides either. however, when i used to work as a cook i would chaff time to time. i found that a couple swipes of deodorant/anti-antiperspirant under the boys would solve any and all problems.
    it's fun to do bad things
    Reputation: db09jku's Avatar
    Quote Originally Posted by John K. View Post
    How is the padding in those shorts?
    Aug 2010
    Since this is my first pair, I do not have anything to compare it against. Before when I just wore regular boxers and shorts, my groin area used to get numb on long extended climbs. The numbing seems to have disappeared with the chamois, so I think I'll stick with the chamois from now on all rides.
    Granny gear lover
    I'm new as well, got a liner with chamois and padding, from Dicks sporting goods, was hoping to have a little more padding! Not bad, but not like my easy chair either! I hope to get use to it.
    Aug 2010
    What's probably more important than the padding on the chamois is the saddle itself. I haven't had any major discomfort problems with the WTB Speed V saddle which came included with my bike. You should make sure the seatpost isn't too high, and I noticed it also helps to have the nose, or forward end of the saddle pointing slightly downward to relieve some pressure.
    Granny gear lover
    My bike, that is coming in tomorrow, has that exact seat! Hopefully it will be fine.
    Dec 2011
    The ranger with the fox M chamois has been my favorite out of my past 4 pairs of bike shorts. I think several things are really important to not get chaffing in the first place.
    1) make sure you seat is the right size (i.e. width). Specialized and some others have ways for the bike shop to actually measure the width of your sit bones. You want to make sure your sit bones are doing the work - not the soft stuff in-between!!
    2) An important corollary to this is having the seat in the right location - this is vertically (too high and you have hip tilt, too low any you tend to move back and forth a little much) and fore-aft. Just a really small adjustment fore-and aft makes a huge deal. Just think about where your sit bones are on the seat and adjust the seat on the rails to make it work. Also, your saddle should be very close to level (no tilt of the nose). I used to think I want that saddle away from my boys, but that is wrong! If the nose is pointed down (too much), you load your arms. As your arms tire, you slide forward on the seat and this results in some soft part loading and subsequent chaffing.
    3) Another reason (especially for new riders) mt bikers get chaffing is because they are in the seat too much. If you have a chance to watch a really good rider they are out of the seat a ton. They are positioning their weight fore and aft. Also they are loading the pedals which are much lower than the seat. Being out of the seat has the nice byproduct of letting the blood flow in your soft parts and keeps the chaffing down.
    4) No underwear (unless you are talking something that is seamless). Some people like a jock to hold the boys out of the way a little.
  1. Voler elite fs shorts and bib shorts b1g1 plus 10% off ships free.
    By texas in forum Where are the Best Deals?
    Last Post: 10-27-2011, 03:45 PM
  2. Cycling shorts / Mountain bike shorts
    By mightymouse in forum Where are the Best Deals?
    Last Post: 04-26-2010, 02:01 PM
  3. Replies: 13
    Last Post: 03-23-2010, 04:36 AM
  4. Compression Shorts, Padded Shorts . . . ah who cares?
    By eclane78 in forum Beginner's Corner
    Last Post: 12-06-2007, 08:17 PM
  5. armor cushion shorts / spandex shorts?
    By Picard in forum Apparel and Protection
    Last Post: 09-04-2007, 07:31 PM
