Dinotte Ultra 5w on helmet...need a little help.- Mtbr.com
Results 1 to 10 of 10
    Reputation: llama's Avatar
    Ok, so I just got my Dinotte Ultra 5w and I plan to use it on my helmet. It came with a helmet mount, but the chord to the battery is only 12 inches (a detail I neglected to notice in doing research, but I probably would have bought it anyway). Anyway, I have to put the battery pack on my helmet. Only problem is that the nylon battery case is kind of loose, so it's going to bounce around a bit. Has anybody had this problem? Should I just wrap another strap around it?
    Thanks.
    DiNotte has an extension cable that you can order if you want to carry the battery in your pack or jersey pocket. If you want to try the battery on the helmet just use a wide velcro strap and snug down tight.
    Eat Food. Chop Wood. Ride Bike.
    Quote Originally Posted by Dave in Driggs
    I thought I had seen an extension cable on their website in the past, but cannot find one now.
    Can you direct us to it?
    I emailed DiNotte in the past and never received a reply.
    Reputation: crank1979's Avatar
    Feb 2006
    I haven't had any problems with the battery pack bouncing around or moving while mounted on the helmet. I also had an extra length of velcro included that i was going to use to warp around the battery pack again in case it did move around a bit but i haven't had to use it.
    Quote Originally Posted by [email protected]
    Really? It doesn't bounce around? I haven't ridden with it yet (just got it yesterday) but the nylon case is loose and the velcro strap attaches through a belt loop on the back of the case, so it seem like it would bounce a bit. I guess if it does it's no problem to wrap another strap around it.
    Reputation: James@GearReview's Avatar
    I'm assuming that you purchased the AA version. If so, you can make your own extension cord using THESE connectors from Radio Shack.
    Feb 2006
    Quote Originally Posted by llama
    Yeah mine is the little AA version and mounts through the belt loop. I also thought initially that it would move around a bit and i'd ntice it because it was helmt mounted, but so far no problems.
    Thanks. I bought the connectors a month ago. I'm just being lazy and haven't soldered them up yet.
    Reputation: antonio's Avatar
    Jan 2005
    Can someone explain what needs to be soldered in order to make the 9v cord from radioshack work? I'm not one to mess with electronics much, so I'd appreciate the help.
    Ant
    Reputation: Wombat's Avatar
    I mount my AA battery pack on the helmet and found it works best if the belt loop faces away from the helmet, that way the velcro strap gets to grab more of the battery pack. If I mount it the other way round it is loose, but this way it doesn't move.
    Tim
