• 12-16-2006
    Asbury
    Crank Brothers Mallet - Shoes?
    What shoes are you using w/ your Mallets? I just bought a set and had to grind away several millimeters of sole on my current shoe to get them to clip in easily. Anybody have a set of shoes that will work right out of the box?
  • 12-16-2006
    shiggy
    I use 3-4 different types. No sole grinding needed on any though I did use the shims under the cleat.
  • 12-19-2006
    Barkdog
    No problems with '05 Specialized BG Comp, unaltered (but slightly worn in).
  • 12-19-2006
    Guyechka
    A pair of 661 Launch shoes and a pair of 661 Tiburons. Didn't need to grind away sole or use shims.
  • 12-19-2006
    PrincipalRider
    Sidi Dominators. No shims. No grinding. Works fine.
  • 12-20-2006
    RaD
    Oakley Radar in size 11-shoes are to wide and rubing at the crankarm(XT).
    I needed to shim out the pedal with a washer and the shoe just barely passed.
    With my old smaller shaped NorthWave shoes I had no problems and I now actually use Lake MX101 shoes with zero issues using the Mallets.
    Later
    RaD
  • 12-20-2006
    Strafer
    I had to with Performance brand shoes, but not for Diadora or 661 shoes.
  • 12-20-2006
    mtnkiwi
    Shimano shoes, shimming and grinding. Guess they are spd friendly. Much easier with regular eggs
  • 12-21-2006
    Mike Oxmells
    Lakes, no problems
