Clothing Question: Stain removal.- Mtbr.com
Results 1 to 10 of 10
    IPAs make me wanna puke.
    Dec 2004
    I recently (I have NO IDEA HOW) got chewing gum on the outside, i.e. non-liner part of my mountain biking shorts, so I'm wondering if anyone has ever had to remove that kind of stain from their gear.
    I called Fox and they said they would "research it" for me and get back to me, but I haven't heard back yet from them.
    Input would be appreciated.
    Thanks,
    Michael
    My presence would be the equivalent of painting lamb's blood on your frame, causing the "angel of crash" to nail me instead.
    organically fed
    Reputation: w00t!'s Avatar
    So are you talking about a stain left behind by the gum or is it the actual gum you're having a hard time removing? If it's the gum, try rubbing ice on it to harden it up, then you can pick it off.
    Dec 2004
    I think it may be more of the gum. I've run it through the wash once, but the remaining gum seems to be almost sublimated.
    Oct 2007
    My grandmother used to use peanut butter to get gum off of things, but you may be trading one type of stain for another.
    Oldest daughter doesn't ride.
    Powered by Buko Juice
    Reputation: JEFROX's Avatar
    Try rubbing it with oil - baby oil, cooking oil, olive oil, etc. It's a slow process but it usually works.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Have gone through the washer
    the gum could be permeated into the nylon fabric. You might try using dry heat. Then use a paper towel as a sponge to pull the gum out of one side of the nylon.
    My spoon is too big!
    Reputation: medieval's Avatar
    Oct 2007
    I picked up a wad of gum once when I ran over it on a road ride. It got flung up on my backpack, shorts, and shirt. I had good luck with either "Goof Off" or "Goo Gone". I can't remember which it was.
    "If more of us valued food and cheer and song above hoarded gold, it would be a merrier world."
    J. R. R. Tolkien
    CHOCOLATE NASTIES Baker
    Reputation: tsimbu's Avatar
    Jan 2005
    Motsenbocker's Lift Off #2 formula
    You should be able to find it at Home Depot (usually) in the paint isle.
    Good luck.
    Master of the unintentional track stand.
    Dec 2004
    Excellent. Thanks Travis!
    011100000110111101101111
    Reputation: unfluid one's Avatar
    Aug 2005
    i got gum all over my jeans and packing tape did the trick.. or any sticky tape. just press on, and rip off couple hundred times, using a clean side of the tape each time.
