Cleat Receptacle Plate Movable on S-Works 6 XC MTB Shoe?- Mtbr.com
Results 1 to 7 of 7
    Reputation: Pegleg81's Avatar
    Aug 2014
    Does anybody know? It seems that the cleat receptacle is fixed. Although the receptacle has two sets of holes, is the cleat receptacle supposed to be able to slide fore-aft of the shoe? Thanks.
    The product page says the following but not sure what it means:
    • Titanium alloy cleat nuts can rotate to position pedal/cleats 5mm rearward.
    '15 Spesh Epic World Cup
    '16 Spesh Crux
    '17 Spesh Epic HT
    Reputation: Lone Rager's Avatar
    Dec 2013
    My interpretation of that bullet point is that you spin the plate 180 degrees to move the bolt holes back or forward and that the plate is otherwise fixed...but I don't know that for a fact.
    Do the math.
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Quote Originally Posted by Pegleg81 View Post
    I have those exact shoes.
    On mine, the plate is fixed and has two sets of holes, as you have described. It does not move fore and aft. It seems to be affixed quite solidly to the inside of the sole.
    I have absolutely no idea what the excerpt above from the product page means. None. Mine have no titanium alloy cleat nuts, let alone ones that can rotate to position pedals/cleats 5mm rearward. That is some serious marketing bullshit right there.
    Reputation: MSU Alum's Avatar
    Are the holes offset? If so, reversing the plate would reposition the holes.
    Mar 2015
    Quote Originally Posted by MSU Alum View Post
    Unlike other shoes I have owned, the plates appear to be fixed in place. In terms of a cross section, it goes in this order...sole, plate, an inner sole that is stitched in place over top of the plate, and a removable sole. I donít know how you could reverse the plate without doing major surgery on the shoe ó something I am not about to do. I am scared shitless to wear them, let alone take a knife to them.
    Reputation: life behind bars's Avatar
    May 2014
    Try contacting Specialized.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    Quote Originally Posted by mtnbkrmike View Post
    Oh. Well, that won't work!
  1. Spacer/pad for cleat plate in clipless shoes?
    By Christopher Robin in forum Apparel and Protection
    Last Post: 09-28-2018, 11:15 AM
  2. Where to buy hellcat pro cleat plate cover??
    By BicBoy in forum General Discussion
    Last Post: 03-31-2018, 08:11 PM
  3. The movable veil
    By Maadjurguer in forum Arizona
    Last Post: 01-07-2014, 10:27 PM
  4. Soft polish steel balls for post mount receptacle
    By MDEnvEngr in forum Frame Building
    Last Post: 03-09-2013, 02:30 PM
  5. clipless cleat position / Shoe issue / wrong shoe / ?
    By J Hartman in forum Beginner's Corner
    Last Post: 02-06-2013, 05:19 PM
