cleaning pads- Mtbr.com
Results 1 to 11 of 11
Thread: cleaning pads
    meow meow
    Reputation: b-kul's Avatar
    cleaning pads
    sorry if this has been brought up a lot, i googled but just wanted to see if anyone had any good remedies. i read about hot water and vinegar. how well does that work? i have done the wash vital posted with some detergent and mouth wash on my knee pads and that worked okay but they were still a little funky. also my camelpak reeks, can i remove the bladder and hose and throw that in with my knee pads? thanks!
    Wanderer
    Reputation: Toff's Avatar
    Sep 2004
    I throw my Camelbak in the washing machine from time to time. Hasn't hurt it yet.
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    I wash my pads and hydration pack both in the washer, have for years with no ill effects. Make sure to fully attach all velcro straps so they won't hook on each other and shorten all the pack straps as much as possible. You also have to have a front loader washer or the pads will just float on top and not get clean.
    meow meow
    just an update, water and axe body wash seemed to work good. filled a 5 gallon pale and put in 1 good squirt of wash. worked it in to my pads and camelpak with my hands for about a minute and then let it sit for around half a hour. pulled it out, rinsed it off real good, and hung it outside to dry. the initial sniff test was good, to my surprise my stuff had almost no smell, certainly no strong axe smell, just a good clean scent.
    T.W.O.
    Reputation: mimi1885's Avatar
    Yeah, that's a good idea. I usually soak mine first before wash, if not I'd ended up washing them twice because there's still a lot of dirt. I've not try Axe but it's sound like a good alternative to detergents.
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    I wash my bike gear with regular unscented Tide at half the recommended amount than regular clothes AND add a scoop or two of Oxy Clean. For really muddy/dirty stuff, I soak them in a tub of water Oxy Clean solution before throwing in the washing machine.
    Amolan
    The key is to kill the bacteria that cause the smell. Add Borax to the wash, and put vinegar in the fabric softener port. They are both natural bacteria killers.
    Old Fart, Crank Warrior
    Reputation: AllisonWunderland's Avatar
    CamelBak products are warranted for LIFE.
    Vinegar will cut grease and kill bacteria -- fairly benign to fabrics. At the risk of impropriety, the trick to getting the funky out of stuff is to not let it get funky in the first place.
    Si vis pacem, para bellum.
    meow meow
    lol, i dont think i can get camblebak to warrant a pack because it stinks.
    Don't worry, be happy!
    Reputation: formica's Avatar
    Quote Originally Posted by b-kul View Post
    wash it, then send it in.
    Quote Originally Posted by ranier View Post
    Great ideas for gear cleaning. Just don't put this stuff in the dryer, the heat is what will really mess things up.
  1. Cleaning calipers and decontaminating pads
    By juan pablo in forum Downhill - Freeride
    Last Post: 03-03-2010, 02:39 PM
  2. Cleaning Disks and Pads
    By zoovegroover in forum Brake Time
    Last Post: 12-14-2007, 05:11 AM
  3. Cleaning Brake Pads
    By doanster in forum Beginner's Corner
    Last Post: 05-09-2004, 08:04 PM
  4. Cleaning Disc Brake Pads?
    By richardchen in forum Brake Time
    Last Post: 03-23-2004, 10:53 AM
  5. Replies: 1
    Last Post: 02-16-2004, 09:12 PM
