Chafing--thoughts- Mtbr.com
Results 1 to 5 of 5
    Chafing--thoughts
    I have been getting some chafing right where the chamois ends, on the back of my legs. Kind of in the fold where my hamstrings meet the glutes.
    I went wider with my saddle (155mm) after measuring on the Bontrager and Specialized seat thing, and having some numbness/prostate issues. All that has resolved.
    I generally use chamois butt'r and it does not seem to matter which shorts (De Soto, Bontrager, and some Salsa ones). To be fair, I only notice it on rides over 6 hours.
    Any thoughts?
    Save Jesus
    Reputation: beanbag's Avatar
    Its possible the inner liner is too loose? Is it removable? If so, try some of the regular lycra roadie shorts underneath.
    Oct 2011
    I was turned on to Under Armour HeatGear compression shorts a few months back:
    - Men's HeatGearŪ Compression 7" Shorts | 1201164 | Under Armour US
    I had been getting chafing after about 2 hrs. of riding in hotter weather, now have been good up to 5 hrs. of riding, which has been my longest to date. You wan them to fit really snug
    Regarding fit:
    I prefer wearing road bibs (i've tried several makes and models and found some I like) underneath some boardshorts/riding shorts. It's nice that it's more common that companies are making shorts with removable liners these days; so you can still use the shell if you don't like the liner. I'd keep experimenting a bit with different brands, sure it can be expensive; but totally worth it if you're riding that much.
    Chamois butter:
    Me and chamois butter never got along; it was like throwing fuel on the fire. I'd say stay away but to each their own.
    Ride duration:
    Did you just recently up your riding time a lot? Perhaps, your body simply needs to adapt to the wear and tear of long rides?
    Hygeine:
    It's been a while since I was doing rides of that length; but when I was I found that being extra fastidious in cleaning those regions of the body went a long way to minimizing any discomfort.
    Reputation: pascale27's Avatar
    Make sure your seat is at the proper height. If the seat is too high, even a little. This could be the cause.
    Salsa Timberjack 27+
    Niner Jet 9
    Misfit diSSent 1x11
