Camelbak Crux hose on Antidote bladder?- Mtbr.com
Results 1 to 6 of 6
    Reputation: MikenIke's Avatar
    May 2013
    Anyone know if the quick-links on the Crux and Antidote bladders are the same size?
    If so I can keep my old pack and just get a new hose kit.
    Ride it like you stole it!
    Reputation: huckleberry hound's Avatar
    Feb 2015
    Can't you just replace the hose using the same connector? I use a Camelback insulated hose on my Platypus bladder. It is very easy to install on the connector. Just run very hot water over the hose to soften it up then run a little bit inside to act as a lubricant and slide it on.
    Change begins by doing something different.
    May 2013
    Yes you can, but It would be cool to use the crux hose though, as it has a larger inner diameter. More water in my belly with one sip!
    May 2013
    I'm just not sure if the crux QR connector fits into the QR on my older bladder.
    Feb 2015
    According to REI it should fit.
    Rusty Lift 6 months ago
    Will the crux insulated tube fit on the rogue model? Is there any other insulating sleeve available to go over the original tube? What does crux mean?
    answer
    Answer the question
    REIservice 2 months ago
    If your Rogue came with the Antidote reservoir with a quick connect fitting where the tube meets the reservoir, then this insulated tube is compatible. Crux tubing has a larger diameter than previous hydration tubes, so it offers 20% more hydration per sip. You can buy the regular style tube with insulation. Here's the link:
    https://www.rei.com/product/812021/c...-tube-director
    Source:https://www.rei.com/product/108373/c...insulated-tube
    May 2013
    Got the new Crux hose on my old Rogue Camelbak, works great!
  1. Camelbak Crux bladder review?
    By Streetdoctor in forum Apparel and Protection
    Last Post: 11-22-2016, 02:00 AM
  2. Replies: 18
    Last Post: 11-20-2015, 06:15 PM
  3. Specy Crux E5 Sport Evo vs. Crux E5 Sport?
    By TiGeo in forum Cyclocross
    Last Post: 03-15-2015, 05:15 AM
  4. Camelbak hose on an osprey bladder?
    By 007 in forum Nutrition and Hydration
    Last Post: 08-15-2014, 08:19 AM
  5. Camelbak Antidote hose o-ring
    By PissedOffCil in forum Apparel and Protection
    Last Post: 07-11-2013, 07:48 AM
