Bib shorts with leggings or long johns for colder temps- Mtbr.com
Results 1 to 11 of 11
    Jul 2016
    New question here. Bib shorts with leggings or long johns for colder temps
    Hi,
    I'd like to ask how do you wear bib shorts with pad or normal bicycle shorts with pad combined with leggins for colder temps?
    Is it good idea to wear normal leggins for running or thermal long johns under bib shorts?
    Please note that I do not have winter cycling shorts, only have thermal merino long johns and under armour heat gear leggins.
    How do you wear bottom in colder temps?
    Reputation: blacksheep5150's Avatar
    Oct 2014
    I switch to baggy shorts in winter and wear my under armor over bibs or padded liner .then mtb shorts
    Jul 2016
    Great idea I have windproof Warmpeace Spring pants
    Bib shorts with leggings or long johns for colder temps-warmpeace-spodnie-spring_12342.jpg
    So long johns/leggins over bib shorts with pad and over that Warmpeace Spring pants.
    I guess long johns/leggins under bib shorts with pad isn't good idea, right?
    Reputation: d365's Avatar
    chamois always goes next to the skin.
    Oct 2014
    Anything under the chamois will produced major saddle sores , I learned that the hard way .. Lol
    Reputation: Legbacon's Avatar
    Bibs, knee or leg warmers, and outer baggies. Cycling tights over the bigs and leg warmers if it's quite cold. knee and leg warmers are very versatile and can even be worn together.
    Formerly Travis Bickle
    Team Robot. "modulation is code for “I suck at brake control.” Here’s a free tip: get better."
    Reputation: MSU Alum's Avatar
    Also, if you can keep your core temp up by insulating your torso more, you don't need leg covering as much.
    Keep your knees warm, they will age better.
    Jul 2016
    I've already have Rogelli softshell knee warmers ( Kniestukken, Softshell ) will try when it will be colder to check if I really need thermo long johns or running leggins over the bib shorts with pad.
    MSU Alum I have tendency to overheating and I've almost always sweat back, but with colder tems even if I'm sweat my fingers and toes are cold, have to look at warm pair of gloves and maybe merino socks.
    Wear knee pads or the newer pedal armour which is pretty close to a pair of knee warmers with some soft armour attached to it. Or get a pair of thermal bibs or thermal knicker bibs.
    I picked up a pair of Icebreaker knickers on clear-out and without the bibs, them and my outer shorts are in a constant race to see which one can expose my ass crack the fastest...
    since 4/10/2009
    Reputation: Harold's Avatar
    My kit when cold depends a lot on the specifics of the weather.
    #1 rule: Layer!
    I always start with my summer shorts for the chamois. Next layer might be just knee warmers (I need a new pair, as my current ones are pretty stretched out). The next layer might be just a pair of baselayer pants. It might be both. Or it might be a pair of softshell cycling tights, or some combination of the above. I usually finish by wearing baggies. Basically, they provide extra wind protection over the crotch and for where the femoral artery comes close to the surface on the inner thigh. I consider my "core" to start at the inner thigh and go up to the neck.
  1. Shorts that aren't so long...any suggestions?
    By mxracer394 in forum Apparel and Protection
    Last Post: 03-14-2015, 10:20 AM
  2. Compression shorts/full leggings...
    By m5161968 in forum Apparel and Protection
    Last Post: 03-24-2013, 07:36 PM
  3. Looking for some LONG shorts for Downhill
    By QuenteK25 in forum Apparel and Protection
    Last Post: 09-28-2012, 06:09 PM
  4. Long-cut shorts, faves?
    By Eric. in forum Apparel and Protection
    Last Post: 07-29-2012, 09:47 AM
  5. Replies: 62
    Last Post: 01-09-2011, 08:12 PM
