Anyone ever replace a BOA system and it still doesn't work?- Mtbr.com
Results 1 to 11 of 11
    Reputation: glorth2's Avatar
    I have some 2012 Specialized S-Works MTB shoes. They've been great until this year. They just unspin. Anyway, got the kits. I replaced both sides. One still unspins. I did everything right. I don't know whether to cry or buy new shoes. Anyone?
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Yep, did it with my Lakes when the cleat receptacle rusted out and I had to remove it, which required removing the BOA. Worked just fine. Guy at the bike shop was kind of an expert at it and offered some guidance. Some of the online stuff wasn't super helpful because the exact system didn't seem to be depicted, but BOA does have a lot of online resources. I suggest checking those. Worked out fine though, heck, works better than new IMO.
    Reputation: Lone Rager's Avatar
    Dec 2013
    No. I've done it a few times and know others who have and they all worked well after replacement. There seems to be many different types and different fasting of the mechanism to the shoe so it is possible some may be more problematic.
    What, me worry?
    Reputation: Fairbanks007's Avatar
    Replaced the BOA on my Specialized Rime shoes about a year ago without any issue. What do you mean by, "unspin?" Any chance Specialized sent you two of the same side?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Has anyone ever ADDED BOA laces to a shoe that was not originally designed for that?
    I.e., some Giro VR90s (lace ups).
    Death from Below.
    Not sure what I did but I went back in on that lace, sprayed some WD-40 under and just remounted it. Seems fine now. Rode today with no issues.
    When I say unspin I mean the ratcheting mechanism doesn't hold, which it seems to now. On the other shoe, I cut the lace a tad too short. Never want to do that again.
    Dec 2013
    Quote Originally Posted by Le Duke View Post
    Has anyone ever ADDED BOA laces to a shoe that was not originally designed for that?...
    Interesting idea. I can imagine a kit they could come up with that would allow that. Perhaps they have?
    What, me worry?
    Ride More - Suffer Less
    Reputation: TraxFactory's Avatar
    Sep 1999
    Not BOA, but I have added Salomon Quicklace System to several pairs of tie ups. Works great.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    Quote Originally Posted by glorth2 View Post
    two types of BOA
    one way ratchet, then pull dial up to unlock. those I never had get loose
    two way ratchet, tighten then loosen a click at a time
    there are a few different models of these with different shapes in the dial guts
    these 2-ways can get loose as microdust crud gets in the teeth. AND the
    little fingers that are the pawls can get weak. I open the boa pull the dial out
    and a) blast the hell with air duster to get all the grime out
    and b) the fingers on mine are pretty tough. I used a small spudger to carefully
    bend the arm just a little bit back toward the outside, so the ratchet is tight again
    reassemble, works great.
    those little pawl arms are tough but I never attempted
    to bend them further than needed.
    like this picture,
    Thank you sir!
    Reputation: Burning Matches's Avatar
    Mar 2011
    Reviving this old thread as I am having the same issue with my Specialized Expert XC shoes, which have the BOA IP1 dial. This is the kind that rotates in both directions, tightening and loosening with each click. If I pull straight up on the dial, it releases all the tension.
    Mine continually loosen up, a click or two at a time, mostly whenever I have to unclip and put a foot down, or walk a few steps through a rock garden, etc. It's usually not immediately noticeable that they have loosened, but once I get going again, they are clearly loose and I have to rotate the dial to tighten them back up. This happens on both shoes. It's really frustrating in competition to have to do this.
    I replaced both sides with the warranty kit I got from BOA. It made no difference. The "click" is more pronounced with the new dials, but they still let go of the tension when they shouldn't. Previously I had an older pair of S-Works shoes and had a similar issue, although not as frequent.
    Has anyone come up with a method to keep these things tight? Adding a shot of WD-40 as suggested above seems like it would have the opposite effect.
    I tried calling BOA earlier this week and wasn't able to get through so I've sent them an email. Waiting on a response.
    My next move, if this issue can't be fixed, is to shop around for a pair of shoes that don't use the BOA system.
  1. Replies: 5
    Last Post: 07-07-2016, 10:32 PM
  2. Boa system on Lake Shoes broke
    By terricksa5 in forum Apparel and Protection
    Last Post: 10-21-2012, 10:24 PM
  3. boa lacing system
    By jekyll2003 in forum Apparel and Protection
    Last Post: 07-03-2012, 06:10 PM
  4. "Contact Seller" link in classifieds still doesn't work
    By Andy FitzGibbon in forum Site Feedback/Issues
    Last Post: 02-02-2012, 10:33 AM
  5. Anyone try the new Scott Boa mountain shoes?
    By madsedan in forum Apparel and Protection
    Last Post: 08-10-2011, 09:11 AM
Members who have read this thread: 20
