X-post...Kona Five-O build specs- Mtbr.com
    Reputation: mtskibum16's Avatar
    Here's the 2009 - it's probably the same. Front der. clamp size of 34.9 (should be same as seat tube clamp since it's the same tube) and BB width of 73mm. It should be a zero stack headset. Cane Creek headset finder spits out this: SHIS:ZS44/28.6|ZS44/30 (1-1/8" Zero Stack ZS Standard). No idea on dropouts - google.
    http://www.konaworld.com/09/09_fiveo_en.cfm
    Reputation: badgermtb's Avatar
    Hi folks. I just bought a 2008 Five-O frame from Cambria, and I need a few info items from you...I emailed Kona's tech center and have yet to hear.
    What kind of headset does this frame take? Integrated? Cambria wasn't really sure...they said 1.5? I thought that was off a bit. I have a 1 and 1/8th fork that I'd like to use.
    Seatpost size?
    Seat clamp size? I'm not sure the frame comes with one.
    BB width?
    Can i swap those dropout plates and run this SS?
    Here are my build plans:
    Rev fork at 150.
    XT cranks
    Charger Pro wheels
    XO bits
    I'm thinking it will be a sweet build. I like the fact that the frame is longer and lower...and it seems to be somehwat oriented to trail ridiing, not just heavy freeriding. I need a bike that can pedal to the trail reasonably well.
    Let me know what you know! Thanks.
    Attached Files Attached Files
    Thanks for the info. I did find some "Z" dropouts for the 2009 Cowan and Five-o frames. High Intensity bike shop has them...or had them...I need to call as they are slow on the email responses.
    That headset info you sent is helpful. I wil go to the Cane creek site and see what I come up with.
    Reputation: lew242's Avatar
    The 2009 5.0 has a 30.0 seat post size, which is very inconvenient, especially if you were thinking of using a Reverb or something.
  1. Replies: 24
    Last Post: 10-23-2009, 07:58 PM
  2. Post Your TransAM Build Specs: Components/Price/Weight
    By FlippinSweet in forum Transition Bikes
    Last Post: 07-23-2009, 12:39 AM
  3. First Post, Kona HeiHei Build, and a Hub Question
    By Lugboot in forum 29er Bikes
    Last Post: 06-18-2008, 06:47 AM
  4. RE:post plus build specs
    By rjpstoked in forum Ventana
    Last Post: 03-09-2006, 09:52 AM
  5. Kona paint specs...
    By top_ring in forum Kona
    Last Post: 09-01-2005, 11:12 AM
