Will this Bottom Bracket Work?- Mtbr.com
    Jul 2020
    I am removing what I am pretty sure is a BB-LP30 73 shell width and 118 axle length from a trek bike from 1993.
    My intention is to build everything back with Deore XT 8100 2X12
    The question is will the new BB-MT800 fit this frame or do I need a different Bottom Bracket? If a different Bottom Bracket is needed, will it work with the same Deore line?
    Reputation: huckleberry hound's Avatar
    Feb 2015
    If you are talking about the BSA one not the Press Fit one then yes it will fit. One like this: https://www.universalcycles.com/shop...s.php?id=75080
    What are you doing for the rear wheel?
    Change begins by doing something different.
    Jul 2020
    Quote Originally Posted by huckleberry hound View Post
    Thanks! The cassette is Shinamo XT CS-M8100Cassette 10-45T and I am purchasing new wheels but haven't picked them out yet. I need to find ones that are v brake compatible.
    Feb 2015
    You will have to have a custom wheelset built up because that cassette requires a Microspline freehub body. This is going to get quite expensive. You could use a hub like this but not install the disc. https://www.treefortbikes.com/Shiman...32224373389138
  1. Threaded bottom bracket (2019 Stumpjumper): Want carbon crank with bottom bracket
    By rakerdeal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-27-2020, 08:03 AM
  2. Replies: 3
    Last Post: 12-16-2016, 11:49 AM
  3. Using Bottom Bracket Wrench vs. Bottom Bracket Socket
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2016, 10:36 PM
  4. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  5. Hole in bottom of frame on bottom bracket?
    By concrete sledge in forum General Discussion
    Last Post: 05-03-2007, 11:45 PM
Members who have read this thread: 20
