Results 1 to 7 of 7
Thread: Tire Widths
    "That's what." -She
    Reputation: nathan_van's Avatar
    Jan 2019
    Tire Widths
    Hello, I have a 2011 Specialized Stumpjumper FSR Expert 29. I am running a 2.5 WTB tire in the rear and a S-works 2.2 up front. I am wondering how much bigger I can get the tires to be before it interferes with the frame. Stock fork and stock frame.
    My bike:
    https://www.specialized.com/us/en/st...t-29er/p/23342
    Before you criticize someone, walk a mile in their shoes. That way you're a mile away, and you have their shoes too.
    WillWorkForTrail
    Jun 2012
    I'd say the answer to your question depends a lot on how wide your current tires actually measure and how much space is left between them and the frame. Otherwise, unless someone else happens to have exactly the same bike and rims as you, it's going to be tough to answer.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Another consideration is the internal width of your rims. Wider tires work better on wider rims. I believe those rims are 26mm outer width, which is pretty narrow by today's standards.
    Do the math.
    Reputation: Mr Pig's Avatar
    Be aware that the stated width on many tyres is a work of fiction. Maxxis for instance seem to always be narrower than stated.
    Also be aware that if you ride aggressively and the tyre hits the frame it can go down to the metal in one short ride.
    Jun 2014
    I'm running just the opposite. 2.4 front/2.25 rear. Can't get anything bigger on the back.
    Reputation: d365's Avatar
    Quote Originally Posted by nathan_van View Post
    *I would caution against running a wider tire in the rear, than you have up front. Tread patterns aside, your front end is going to lose traction before your rear, which is the opposite of what you want. I use 2.4F/2.3R
    Don't forget to leave some space for tire deformation upon hard compressions.
    You should be able to fit a WTB 2.5 on the front. But performance is tied to inner rim width and tire pressure. If you have a 30-35mm inner rim you can run lower pressure because the wider rim supports the sidewall. It doesn't fold over when you lower the pressure. The sidewall wrinkles. You get a bigger footprint for more traction and more controlled slide-outs.
  1. Winter tire widths
    By visser in forum Wheels and Tires
    Last Post: 12-13-2012, 07:58 PM
  2. Tire widths - what combo
    By kikoraa in forum Singlespeed
    Last Post: 11-13-2011, 11:03 AM
  3. Choosing Tire Widths
    By Sundragon in forum Wheels and Tires
    Last Post: 05-26-2011, 01:57 PM
  4. Hand-wringing over tire widths?
    By Lule in forum Wheels and Tires
    Last Post: 04-18-2011, 05:25 AM
  5. Stupid question for tire widths
    By mustangous in forum Wheels and Tires
    Last Post: 02-27-2011, 10:44 AM
Members who have read this thread: 111
