Steep HA w/ low BB?- Mtbr.com
Results 1 to 13 of 13
    Reputation: eauxgod's Avatar
    Steep HA w/ low BB?
    I am looking for a 6" FS to go with my long A to C 160mm fork (Vengeance HLR) so I thought I would ask around to help narrow the field. Any 170 AM frames or is that moving into heavy FR stuff?
    Wēk Ss
    Reputation: IAmHolland's Avatar
    Why would you want a steep HA?
    I don't know of any 170 AM bikes, that's into the FR category, you'll find lots in that area. The Canfield "the One" frame in AM config is 6.5". It doesn't meet your requirement of a steep HA though.
    Quote Originally Posted by IAmHolland View Post
    After a tapered fork with a 560mm a to c is added it will not be steep anymore.
    Wēk Ss
    Quote Originally Posted by eauxgod View Post
    Eh, that's only 15mm over a Fox 36 160mm, less than 1 degree difference in HA. 160mm bikes can handle that just fine, like the Knolly Chilcotin, Mojo HD, etc.
    Also consider it's tapered, so it will require a EC lower headset which adds another 12mm bringing a 67.5 frame closer to 66 and the BB height up another third of an inch'r so.
    Any bike designed for a 160mm fork will be just fine.
    I am not so much worried about the frame's ability to handle the fork but rather the fork further slackening a bike to the point of throwing the geo off...
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    Pivot Firebird. I use a 160mm fork on mine and looooooove it.
    MTBP
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
    It wont, non issue completely.
    Te mortuo heres tibi sim?
    Quote Originally Posted by One Pivot View Post
    What he said. Most bikes with that much rear travel are intended to be run with forks in that travel range, and shouldn't mess with anything. It's a non-issue, unless you find yourself looking at older frames with that much travel, but still steep angles.
    The better question is: what is the head angle you are looking to achieve in the end? Define too steep/too slack for us? Tough to help if you don't give more info. Lots of variety out there.
    Mr. Knowitall
    Reputation: hssp's Avatar
    This depends on the frame. For example Yeti SB-66 has a ZS56 lower headset cup for tapered forks. Same with Mojo HD. Other bikes have standard EC49 lower headset cup.
    Wēk Ss
    +3, non issue
    Quote Originally Posted by scrublover View Post
    >/= 67 HA and <14" BB...so with 27mm added to a 68 frame the angle will drop to around 66.5. The problem is that most 6" AM frames are 66 to 67.5 with a 545 a2c....
