Specialized Epic Evo 2019 Pivot Bearing Size- Mtbr.com
Results 1 to 2 of 2
    Nov 2018
    Hi.
    Does anyone know the sizes for the pivot bearings on the Specialized Epic Evo 2019. Cant find much info online.
    Any info would be great.
    Also what tools you guys use for removing installing them.
    Craig
    https://www.endurobearings.com/home/
    Contact them if you can't find what you need. If you don't already own digital cailpers you can pick one up off ebay for cheap. Measure and buy individual bearings from wherever you can source them. Also, if you haven't popped the outer seals to clean and re grease that might be all you need? Often times you can rehab pivot bearings for the life of the frame without ever removing them. As far as tools go, it depends. One of the cheapest options for removal are woodruff keys and a punch. A slide hammer is nice to have for certain applications. Drifts and a vice, clamp, or hammer will handle most installations. I've used a socket and hammer many times without issues. Over the years I've accrued bearing specific tools, but often times I end up having to use random tools. It would be nice if you could buy one tool for removal, one for installation, but that's not the way it works. You can buy expensive bike specific bearings tools just to find they won't work for your needs.
  1. Replies: 5
    Last Post: 11-12-2019, 05:50 AM
  2. Replies: 6
    Last Post: 04-09-2019, 01:38 AM
  3. Replies: 4
    Last Post: 03-18-2019, 11:55 AM
  4. Replies: 3
    Last Post: 10-30-2018, 04:46 PM
  5. 2012 specialized epic s works 29er pivot bearing size?
    By vtwinracersp2 in forum Specialized
    Last Post: 04-21-2015, 05:02 AM
Members who have read this thread: 7
