Spec Comparison--Translation Please?!?!- Mtbr.com
Results 1 to 3 of 3
    Jun 2020
    Long story short--
    I'm a noob. I recently ordered a Polygon Siskiu T8 from bikesonline.com based on a bunch of reviews I read. After looking into it a little more, I realized I had ordered the Anniversary Edition (it's not identified as such on bikesonline), which has what seems to be significantly different specs than the Regular Edition. I can't find any reviews online for the Anniversary Edition. If anyone is knowledgeable and bored enough to help me understand the substantial differences between the two bikes (as general or specific as you're willing!), a translation for dummies would be greatly appreciated. I'll give you one million points (works for my kids...).
    Thanks in advance. Specs copy-pasted below:
    ANNIVERSARY EDITION:
    Frame ALX TRAIL 150MM TRAVEL (27.5) / 140MM TRAVEL (29), TAPER H/T TA BOOST
    Fork ROCKSHOX REVELATION RC SOLO AIR BOOST 15X110MM, 150MM (27.5) / 140MM (29) TRAVEL
    Rear Shock ROCKSHOX DELUXE RT3 DEBONAIR SPECIAL TUNING E2E:210X55MM, HARDWARE:8MMX25MM
    Head Set ZS 44/28.6 | ZS 56/40
    Stem ENTITY XPERT, ALLOY E:45MM R:7DEG BB:35MM
    Handlebar ENTITY XPERT, ALLOY W:780MM R:20MM BB:35MM
    Rear Derailleur SHIMANO SLX RD-M7100 12-SPEED DA
    Shifter SHIMANO SLX SL-M7100 12-SPEED
    Bottom Bracket BSA THREADED
    Crank Set PROWHEEL MPX-32T-TT-B BOOST 12SP 32T 170MM (S-M) 175MM (L-XL)
    Cassette SHIMANO SLX CSM7100 12-SPEED 10-51T
    Chain SHIMANO 12SP
    Pedal -
    Brake TEKTRO HD-M745 4 PISTON
    Wheel Set ENTITY XL2 DISC 35-584 (27.5) / 35-622 (29)
    Tire WTB TRAILL BOSS 27.5X2.6 / 29X2.6(front) / 29X2.4(rear)
    Saddle ENTITY XTENT
    Seat Post EXA FORM RAGEI 125MM (S-M)/150MM (L-XL), ZERO OFFSET, 30.9MM
    Wheel Size 27.5" / 29er
    Color BLACK
    Weight 13.6 KG (27.5 M)
    STANDARD EDITION:
    Rear Shock ROCKSHOX DELUXE RT3 DEBONAIR SPECIAL TUNING (210x55mm, 8x25mm hardwares)
    Stem ENTITY XPERT, ALLOY E:45MM R:7DEG BB:31.8MM
    Handlebar ENTITY XPERT, ALLOY W:780MM R:12MM BB:31.8MM
    Rear Derailleur SHIMANO XT RD-M8000 GS
    Shifter SHIMANO SLX SL-M7000 I-SPEC II
    Crank Set PROWHEEL CHARM-32T-TT-B 32T BOOST 2-PIECE-CRANK
    Cassette SUNRACE CSMX8 EAZ 11-SPEED 11-46T
    Chain KMC X-11
    Pedal ALLOY
    Brake SHIMANO BR-M615
    Wheel Set ENTITY XL2 DISC 35-584 (27.5) / 29-622 (29)
    Tire SCHWALBE NOBBY NIC, 27.5X2.60 / 29X2.35
    Saddle ENTITY ASSAULT
    Seat Post ADJUSTABLE HEIGHT, ZERO OFFSET, 30.9MM
    Wheel Size 27.5 S & M, 29 M, L, & XL
    Color BLACK MATTE / TOSCA
    Apr 2019
    It looks like you got a better drivetrain (and associated hub to accommodate the 10 tooth cog), different (presumably better) brakes, and a dropper post.
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by looks easy from here View Post
    Yup. A dropper post, debateably better brakes (m615 punch above their weight), and a proper microspline shimano 12sp drivetrain (heck yeah!). He got the better version, but it's not a massive difference.
    The tires and RD are downgrades, but nothing worth thinking twice about.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
  1. Shimano i-spec mashup (i-spec B brakes with i-spec a shifters)
    By FM in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2014, 09:40 AM
  2. Translation please!
    By Cedarbranchbiker1 in forum General Discussion
    Last Post: 07-15-2011, 06:08 PM
  3. I need a TRUE ITALIAN Translation...Please!
    By dhbomber in forum Europe
    Last Post: 06-24-2011, 06:34 AM
  4. Translation?..or.. I dont speak your language.
    By Lone Wolf8634 in forum Beginner's Corner
    Last Post: 03-09-2011, 07:40 PM
  5. Homers, I need some translation, please...
    By PizzaMan in forum Turner
    Last Post: 12-06-2005, 11:45 AM
Members who have read this thread: 62
