Scott Genius bent shock mount bolts- Mtbr.com
Results 1 to 3 of 3
    I have a 2016 Scott Genius 720 (carbon front triangle, aluminum rear triangle). I got the bike new 'old stock' April 2017 ( just over 1 year). I've put about 600 miles of Trial / All Mountain riding on the bike. I get some air but no large jumps or drops, mostly technical climbing and downhills.
    I had a strange noise from rear pivot/shock. Was kinda of a 'clunk' or 'knock' on every compression then a creak would develop as well. Though it might be shock bushing, replaced but did not fix. Thought it was loose or dirty pivots, not it either. Took me forever to track it down.
    Turns out I have bent shock mount bolts?!?! Hard to tell when looking at them but easy when you rotate the bolt:
    Has anyone experienced this before? I have to order new bolts from Germany. Should I expect this annually?
    Thanks,
    Keith
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    It'd usually a design flaw where the bolts are too small or too long for the application. Falling rate bikes make it worse. The bike should not have this problem.
  1. Scott Genius 720 rear pivot bolts broke
    By bagley in forum Scott Sports
    Last Post: 10-08-2018, 03:09 PM
  2. '16 Genius 940 - Bent Rear Shock Mounting Bolt
    By FowlerWheels in forum Scott Sports
    Last Post: 04-17-2017, 11:02 PM
  3. Using disk rotor bolts instead of SRAM direct mount chainring bolts
    By agu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-08-2016, 07:13 AM
  4. Replies: 9
    Last Post: 05-17-2014, 02:59 PM
  5. Scott Spark or Scott Genius 2012 wanted...
    By LiquidSpin in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 06-12-2012, 03:04 PM
Members who have read this thread: 4
