Salsa Redpoint Carbon GX1 Eagle, any good?- Mtbr.com
Results 1 to 5 of 5
    Feb 2013
    My LBS has a 2018 model in my size marked down from $5100 to $2900. Obviously the downside is I can't ride it first. This is Northern Utah so lots of big climbs followed by long descents. I can't find many reviews on this bike.
    This is around the price range I was looking at so how does it compare to other bikes in the same range (Stumpjumper, Fuel EX, YT/Canyon offerings)?
    Specs
    Frame Redpoint carbon
    Fork RockShox Pike RC 160mm
    Headset Cane Creek 40
    Rear Shock RockShox Monarch RT Debonair
    Axles Front: 110 x 15mm
    Rear: 148 x 12mm
    Rims/Wheels DT Swiss M 1900
    Tires Maxxis Minion DHF 27.5 x 2.5 WT, 60 tpi, EXO/TR
    Crankset Truvativ Descendant 6k, Boost
    Chainrings 32t direct mount
    Chain SRAM GX Eagle
    Rear Derailleur SRAM GX Eagle
    Cassette/Rear Cogs SRAM XG 1275 Eagle, 10-50t
    Shifters SRAM GX Eagle
    Handlebars Salsa Rustler
    Tape/Grips Salsa File Tread Lock-on
    Stem Salsa Guide Trail
    Brake Levers SRAM Guide R
    Brakes SRAM Guide R, Centerline 180mm rotors
    Saddle WTB Volt Race
    Seat Post RockShox Reverb Stealth
    Reputation: Curveball's Avatar
    Aug 2015
    That's a great deal for a very well-respected bike.
    Good parts list aside, I've read some reviews of that bike that were extremely positive.
    Riding Washington State singletrack since 1986
    Apr 2014
    Seems like a decent price on a pretty good all around package. It's somewhat conservative for a bike with that amount of travel and the only review I read (Pinkbike's) said that the climb switch was necessary. If I were you I'd probably hold out and see if you can try the offerings at the same price range from the makers you list. As you're in Utah, I'd see if you can try a Fezzari La Sal Peak. Most reviews seem to love it as an all around bike and you can get a built (with NX admittedly) for not much more.
    Reputation: vernondozier's Avatar
    i have 2016 horse thief, my first carbon bike, I love it. Have no idea about the comparison to redpoint, but mine is great climber, fast, plenty of travel, easy to pedal, good downhill, love my salsa...
    Aug 2013
    I have a '17 Redpoint that has been lot's of fun,even raced a few enduros with it. Swapped out the rear shock to a Cane Creek DB Coil IL and a Push ACS3 coil kit for the Pike.With a few light parts it comes in at 28.4# with pedals.
    I do use the climb switch on the DBcoil on the steeper pitches to keep the seattube angle upright as it is on the slacker side of what is considered optimal.If you use the stock Monarch I would set the sag at 25% and run a 30t chainring to get a bit more anti-squat.
    I'm not sure if I would call the bike "conservative" as my small frame has has a longer reach than some medium "modern" bikes and 66.5 head angle is not steep by any means.
  1. Replies: 40
    Last Post: 03-03-2019, 03:34 PM
  2. Salsa Redpoint
    By fitz3641 in forum Salsa
    Last Post: 04-03-2018, 10:07 AM
  3. Pony Rustler Alloy GX1 vs Carbon GX1
    By velcipede in forum Salsa
    Last Post: 12-03-2017, 04:24 PM
  4. Salsa Redpoint Carbon vs SC Bronson AL (2017 both)
    By fjonzo in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 01-08-2017, 12:54 PM
  5. GX1 10 speed vs. GX1 11 speed derailluer
    By Bos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2016, 09:16 AM
Members who have read this thread: 47
