New mondraker foxy carbon 29 - Page 3- Mtbr.com
Page 3 of 3 FirstFirst 123
Results 401 to 564 of 564
  1. #401
    Reputation: GearTech's Avatar
    Quote Originally Posted by Demorider8 View Post
    Hello, do you guys also get scratches in your chainstay because of the rocks that come with the back tire? The tire clearance is very smalI and I am running the stock 2.3 maxxis agressor. This is worrying my a lot, I have only a few hundred km and it is already scratched a lot! Thank you!
    Yes, many scratches. They're superficial, I'm not worried about them at all. I've seen this on many other bikes as well. Santa Cruz for example.
  2. #402
    Dec 2013
    I rode for a period of time with a stick stuck in between the tire and chain stay and when I pulled it out it had rubbed a significant notch into the chainstay.
    It's not that I don't care, it's just, what can I do?
    The nice thing is that I just love this bike and might well not replace it for half a decade or longer which makes wear and tear a bit irrelevant.
    Sent from my SM-G892A using Tapatalk
  3. #403
    Mar 2018
    Demo Ride Mondraker Foxy RR 29
    Wow! Just had the chance to demo ride the Foxy RR. Fun bike.
    Here is a video I did of the demo ride:
    https://youtu.be/I6MbxHLq64Y
    I did NOT want to demo this bike.
    It has a reputation of being long and downhill focused.
    But I spoke with the rep and found out that while the bike is long, the head angle is reasonable at 66 degrees.
    So I went for it.
    Glad I did.
    Bike climbed way better than I thought it would ... as well or better than the other bikes in this size category (with modern geo).
    Descending was limited, but a blast. Felt like bike "glided" over serveral tech sections.
    I've demoed 16 bikes in the last 3 weeks.
    The Foxy was a big surprise. I'd put it in the Top 5.
    Note: I did a video about HOW I demoed 16 bikes for $105 here:
    https://youtu.be/T_hpTAe5jPI
    Hope this helps.
  4. #404
    Dec 2013
    Thanks for the review although few that ride/ review the Foxy 29 think it's only a DH rig. It just so happens to be a really good hard trail/ light enduro bike and can do anything other trail bikes (i.e. Ripmo, SB130, etc...) can do in a trail riding situation while also being superior in the steeps.
    They can take a ride or 2 to come to terms with the need to move more fore and aft to properly turn the thing but once you adapt, it's a manueverable trail bike.
  5. #405
    Reputation: Professed's Avatar
    Its actually taken me almost a year to fully dial the bike in. Tips for anyone interested in shortcuts: 1) run loads of sag in the rear shock. Ie: 33% or more. 2) Raise the stack. The short Head Tube is way to short for those who fit the sizes. 3) throw out the rubber and get as Assegai front. Gives you confidence to ride the bike as intended!
    Pivot Firebird 29 (M)
    Ibis Mojo3 (L)
    Grove R.A.D
    Lynskey R230
  6. #406
    Dec 2013
    Thanks for the suggestions. Here is my input.
    1) Qerv recommended 35% sag but I ended up at 31-32%. Avy told me that at 35% sag some bleed hole in the shock doesn't get exposed right and an air shock doesn't work correctly but I ended up at these numbers mostly using Shockwiz.
    2) I've been running a 40mm rise bar for years as it gets the handlebar height right while keeping reach long as I can slam the bars. The used forks I bought for this bike, the steer tube was cut pretty short so I have no where to go. But I'm happy anyways.
    3) I kill tires often, rears every 6 weeks or so and fronts every 2-2.5 months. I've yet to try the Ass-Guy, but I'm certain it has mad traction. I don't go for the most traction however, I go for the least rolling resistance that I can get, with passable traction. This results in me riding the fastest over the entire trail. Now that it is 95 degrees in TX it's even more important to have an easy rolling bike.
  7. #407
    Gigantic Hawk
    Reputation: dubthang's Avatar
    I also agree on running a 40mm riser bar. I have about an 1" of spacers below the stem too. The riser bar not only increases the stack, but it moves your hands away from the steering axis which makes the bike more stable.
    I think I'm around 32% sag, but getting the rebound dialed correctly makes a big difference on this bike too.
    If you have an R build like mine, ditch the Sram brakes before they kill you. They are not strong enough for epic descents.
  8. #408
    Apr 2019
    I've put some enduro style stickers in the inner chainstay to avoid the scratches, it's working so far! What I need to figure out is what's the "normal" play that fox claims their bushings should have. The evol leg seems like it has more play than the damper one.. Also I notice a little oil in the station when it sinks more into its travel. Probably I will contact fox about this.
    About rear suspension, I'm also using around 30% sag and I really like the feeling of it!
  9. #409
    40mm rise bar is a great tip! Must try that. What sweep are you guys using?
    And yes, the guide Ts are rubbish. Only the RCT are of any value . Im currently on XT 4 pots and happy (swisstop e-pads), but hear great things about the formula curas and new Trps.
    Final tip - I also placed a strip of 3M self moulding rubber over the chainstay protector and it got rid of the high speed chatter noise. Bike is quiet and feels smoother just because of me not hearing anything!
    Ps: the MSC tires which may not be available in the USA are fast rolling. Try a Gripper in 2C compound. Great dry weather ‘Enduro’ tyre. They run big. Don’t let sizing fool. A 2.3 MSC Gripper is bigger than a 2.5 WT Maxxis.
    Ibis Mojo3 (L)
    Grove R.A.D
    Lynskey R230
  10. #410
    Dec 2013
    I wonder if that MSC rolls as fast as the Eliminator I've been on?
    I really only ride dry rocky conditions so that aspect sounds ideal.
  11. #411
    Dec 2016
    40mm riser. Awesome.
    Deluxe R rear shock no spacers. Awesome.
    Angleset headset to 65°. Awesome.
    30mm headset spacer (1.91m tall so necessary).
    Anyone managed to fit a 200mm rear rotor? If so which brand caliper?
  12. #412
    Gigantic Hawk
    Quote Originally Posted by Professed View Post
    I have a Renthal Fatbar Lite. 7 degrees back, 5 up. My hardtail has a Spank Oozy which is 6 and 4, and that also feels good. It pulls the rider a bit more forward due to wrist placement.
    Quote Originally Posted by danlovesbikes View Post
    Currently running Hope V4's, 200 front and 180 back. I currently don't have a need for a 200 out back, but would like to see some pics if you do it.
  13. #413
    Dec 2013
    Do you also run the Tractive in the rear? How does it compare to other top tires in the category?
    Thx
  14. #414
    Havnt compared the two directly but the MSC is a harder compound in 2C and Supershield casing is much stronger. Knobs a tad shorter as well so expect it would roll quicker.
    Ibis Mojo3 (L)
    Grove R.A.D
    Lynskey R230
  15. #415
    Tractor isn’t much good for anything but XC in my view. Side knobs too small. Rolls great and terrific straight line grip.
    Ibis Mojo3 (L)
    Grove R.A.D
    Lynskey R230
  16. #416
    Just bought the geometry kit to slacken HA. Keen to see how things improve ( if they do!) hope it doesn’t take away the bikes amazing all round abilities.
    Ibis Mojo3 (L)
    Grove R.A.D
    Lynskey R230
  17. #417
    Dec 2013
    You are going to dig the -1 headset.
    I did order the MSC Gripper but it'll be a month or so before I ride it. I'm actually building a new set of wheels so I might just save it for them.
  18. #418
    Soooo.... Anyone try a 27.5 rear yet? I know some of the guys from the distributor are running it.
  19. #419
    Dec 2013
    Mulleting my Fozy 29 occurred to me. In fact my wife's Foxy 27.5 has a rear wheel that would just bolt on in 1 minute, albeit with a much tamer rear tire set up.
    I've blown the idea off just because for my purposes (pedal heavy trail riding) it would slacken and lower the thing more than I want to. Currently having new wheels built for the Foxy so I really thought about it for a moment.
    Mullet bikes are the next big craze and is going to work well, especially for those riding size mediums and smaller.
    Can anyone calculate the exact geo changes?
    So the guys at Qarv are running them?
    Did chat with an acquaintance of mine at Qarv. He is running mullet with the fork at 150mm and loves it. Bb about 13mm lower, slacker head angle. Not sure how much it slackens the STA which is the only part that doesn't sound good.
  20. #420
    Quote Originally Posted by Suns_PSD View Post
    Yep, That's the guy I've chatted with. I'm on a Medium so it's something I'll try eventually. I'd to 150 front with the standard headset most likely.
  21. #421
    I was putzing around in the garage last night and thought I'd try to come up with a solution to debris flinging on to the shock. Introducing the CrapFlap. It is just a small piece of old inner tube and some zip ties. I'm sure someone else has done this. It works well and causes no interference with suspension movement and doesn't rub the frame weird in any way.
    Sent from my SM-N960U using Tapatalk
  22. #422
    Gigantic Hawk
    I like it. I'm wondering if one of those flexible fork fenders will work back there. Need to pick one up to try it.
  23. #423
    Quote Originally Posted by dubthang View Post
    I thought of that too. I't might work, the only issue would be it hitting the frame on full compression.
  24. #424
    Sep 2018
    Debating on going air but need some input. I have the DHX2 and have tried SLS spring, MRP 500 and 550 progressive spring. I weigh 230-235 no gear. Each time it got better but im still not 100 percent happy with how its tracking and handling. Im faster on everything and it gets me out of some trouble, but it just doesnt feel like i think it should. On landings it feel supportive, but tracking on berms and repeated hits it feels harsh and traction is lost. I have it HSC fully open and i have played with HSR and LSC and LSR. It gets better but not to what i think it should. I called Craig over at Avalanche and got a lecture from him about sending my DHX2 and how it would basically be a waste of time and air is a better option, even over the CR Bomber. Only problem is, im on the upper limits for weight and will have to get it serviced sooner or might feel harsh due to high PSI.
    It blew my mind when i set a PR on my buddies Giant Reign on a trail i have ridden 20 time on my own bike the FIRST time on his. His bike just absorbed the trail chatter and railed corners and was composed and had grips for days. My foxy doesn't feel as composed on repeated hits and berms as a coil should IMO. Straight line is fine, still harsh, but its the back to back hits and small bump fast hits that is throwing off traction for me. So im looking at the Super Deluxe RC3 205x65. Is this what some of you have? What mods do i need to do to mount to our 62.5?
    FWIW, here is what i have done so far to make a huge improvement on my bike...
    I have the headset spacers maxed out to increase stack
    tried 30, 35, and 40 mm stem. 40mm worked best for me.
    Im changing my DHF/DHR2 (both exo) to Vigilante and Trail Boss combo. Exo sidewalls are to squirmy for me and if i pump them up to get them supportive the less traction i have. The WTB combo has stiffer sidewalls that will be more supportive in cornering.
    The Slacker cups are on order from Quarv, just waiting to get them in.
    Thanks for input.
  25. #425
    Gigantic Hawk
    Don't think this will help much, but I'm around 165 kitted up. I run the stock Fox DPX2 at about 150 psi. I don't remember what the rebound is set too, but it is per Fox's recommendations. To me, the rear of the bike feels very planted, and very supple. The trick for me is getting the correct amount of sag, and keeping the rebound soft enough to prevent bucking.
  26. #426
    Dec 2013
    Quote Originally Posted by RSparkVB4 View Post
    Thanks for input.
    If you have been able to locate the correct length Super Deluxe Shock that is the correct answer. Then just send it straight to Craig. He will just place a little spacer inside to reduce travel, which is the same way the manufacturers do it.
    The other reasonable option if you just prefer coil is contact Extoria regarding their coil with the hydraulic bottom out control as they will custom build that thing to your application.
    I predicted all of these shock shortcomings before ordering my Foxy 29 and in fact located and purchased a used Superdeluxe RT3 before committing to the bike and sold off the stock coil when the frame was brand new. I wish I had bought the back up RT3 I located on ebay for $183.
    Good luck.
  27. #427
    Has anybody tried a DVO Topaz on the Mondraker?
  28. #428
    Dec 2013
    Quote Originally Posted by kongkers View Post
    My understanding is that is a good product. The issue I have is it is small production and therefore Craig has not built any parts for it. Therefore you will never be able to tune it specifically for this bike.
  29. #429
    Dec 2013
    Just mounted up this Spanish tire to go on my Spanish bike (both manufactured in Tiawan no doubt). I'll give it a go soon although with it being 100 degrees and often 80% humidity, low RR is really most important currently.
    MSC Gripper 2.3 which has an identical width to the 2.6 Eliminator I just removed.
  30. #430
    Hey all. I'm moving to another bike due to a partnership with my LBS. I have this sick Avalanche modded and tuned Bomber CR shock that fits the Foxy available. I'm going to list it in the classifieds but I thought I'd give you all the first shot at it. With a 450lb MRP progressive spring it would work perfectly for someone who weighs 185-210. It transforms the Foxy into a small bump eating machine and the progressive spring counteracts the falling rate of the Foxy's LR. PM me if you want first shot at it before it gets listed.
  31. #431
    Dec 2013
    Quote Originally Posted by GearTech View Post
    Sorry to see you go.
    I might be interested in the Bomber, however the spring rate isn't correct for me.
    If you want to discuss PM me.
  32. #432
    Dec 2013
    I've had 2 'off' days on the MSC.
    The first day I was riding with my 7 year old so it's not really riding but more like stopping every 40'. But it felt draggy and high traction. Also new tires always feel real draggy for the first 8 miles or so.
    The 2nd day was at a lift assisted bike park but it's a small one in TX. Mad traction on the rocks, like really good. A bit sketchy on the sandy bits, and still felt a bit slow rolling even when not peddaling.
    For me, so far I'd prefer the MSC on lift assist or maybe in the dead of winter when i'm really strong, but I'd definitely take the Eliminator for general trail riding as the rock traction is like 85% as good, the other traction is notably better, and the rolling resistance is notably better as well. The MSC does have the advantage of working well with no tire noodle where the Eliminator can fold without.
    I'm hoping to have a spare set of rims soon and for bike park days I'd have the MSC mounted but not sure I'd choose it over the DHF or Assegia.
  33. #433
    Dec 2013
    The new Super Foxy 29. 160/ 170mm travel. New LR with less AS and more progressive for coil shocks. 65 degree head angle, 440/ 450 adjustable chainstay length, Superboost, AND a new softer retrofittable ribbed chainstay protector!
    https://www.mondraker.com/es/en/new-...tfkG2CzRXOQEDw
    The new Super Foxy looks super rad and if I played in this category it would be the one for me. But for the riding I do the Foxy 29 I already have is absolutely perfect. Pedals the heck out of everything, and offers enough travel for the jumps, drops, and terrain I prefer.
  34. #434
    Gigantic Hawk
    I don't know if I'd buy the Super over my current Foxy, but it looks sweet. I want that chain stay protector! Also, I really like the idea of easier internal cable routing. Not a fan of the current internal routing.
    Video for those that don't want to click through the website.
  35. #435
    Reputation: cheezwhip's Avatar
    More progressive too
    "Suspension kinematics for a more supple beginning stroke off the top and a more progressive leverage ratio ideal for coil and big volume air shocks,..."
    https://m.vitalmtb.com/news/press-re...Carbon-29,2961
    ¡Geaux Tigers! - ¡Visca el Barça!
    "Finer than frog hair!" - Lumberjack
  36. #436
    Gigantic Hawk
    Looks like it has better rear tire clearance too.
  37. #437
    Dec 2016
    And whilst I commend the change to a more progressive leverage curve for a coil, I can't help feeling misled that I paid top dollar for the XR with a coil and it was awful. Only felt good when I changed to an air can.
  38. #438
    Hopefully they retrofit the XR with these updates.
    (E.g. Orbea Rallon)
  39. #439
    Sep 2018
    I was just thinking of the new Orbea linkage upgrade. https://bikerumor.com/2019/07/05/new...ds-compatible/
    Was very interesting to me. I doubt mondraker will do this though or if its even possible on the linkage we have.
  40. #440
    Dec 2013
    The Super Foxy linkage is designed with a different goal in mind then the Foxy 29. Wouldn't make sense to apply that linkage to the Foxy 29, it would ruin the bike's trail bike manners.
  41. #441
    A lot of the front triangle geo measurements look the same, it also says optional 0deg headset cups so wonder if it ships with the angle set to give it 65deg head angle. If the front triangle is the same it would be interesting if you can fit the links to a regular Foxy 29 to change the leverage curve. Also the shock is 210x65 to get the 160mm travel.
    It's also Super Boost 157 and looks like longer adjustable chainstay as well 440-450.
  42. #442
    Gigantic Hawk
    From the pics, one would have to swap the links and the rear triangle to make it work.
  43. #443
    Apr 2019
    Hi! I am thinking about buying the - 1 headset, those of you who have it, how does it feel?
  44. #444
    Nov 2018
    Feels good, hovewer I do not consider it to be game changing. But it works well with Foxy, considering the not-so-slack HA°, not-so-low BB and linear suspension curve.
  45. #445
    Dec 2013
    Agreed. It's a worthwhile change and I prefer the bike this way, but game changing it is not.
  46. #446
    MegNeg Air Can
    I just finished dialing in a Rock Shox Super Deluxe RC3 with MegNeg air can on my Foxy. I was running the Fox DPX2 at 170psi with a .86 volume spacer (yes Fox says not to install it).
    After a few rides I'm really happy with the Super Deluxe with MegNeg, the rear feels much more composed (the shock is noticeably bigger), better traction, more small bump sensitivity and I have yet to bottom it out.
    The shock was a take off from a Giant Reign I think, Medium Compression Low Rebound. I have it set up with full volume spacers which is 1 Gnar Dog (2.5) and 2 additional normal spacers, 1 band in the Negative air chamber and 200 PSI. Rebound is somewhere in the middle (haven't counted clicks) but room both ways for adjustment.
    I'm 185 pounds, probably over 190 with gear. My local trails are loose over hard with some rocks but mostly a lot of braking bumps and chatter, 6-12 foot doubles with transition and a few small drops. As mentioned I haven't bottomed it out yet, ring has about another 4-5mm to go which I'm fine with. If I don't use full travel when I go to a bike park I'll probably remove a spacer.
    Over all super happy with the set up, bike feels so much better. When I bought the bike I knew the rear end set up was going to be a challenge (but I got a great deal on it) and bought the Super Deluxe with plans on sending it to Avalanche but with the MegNeg I think I'm happy enough to run it for the time being. I'll probably still send it to Avalanche when it is ready for a rebuild, would be curious what Craig would think of the MegNeg, I know he is big on dampening control vs air spring ramp.
    Also for reference I ran it initially with 2 bands in the Negative chamber and it felt good but I wanted a little more small bump compliance, I then ran it with no bands and it felt kind of vague off the top and seemed to just slump into the sag. With 1 band it feels really good. I think the upside with the MegNeg is a lot of riders will be able to have room for more adjustment to get the rear feeling how they like it.
  47. #447
    Gigantic Hawk
    Anybody see any info on the 2020 Foxy? I saw a picture, but no info other than they tweaked a few things. Be interesting to see what exactly they changed.
  48. #448
    Info is on their website, looks like same frame just updated colors (thank god), chainstay protector and spec. Also no XR Coil version just an RR SL instead.
    There is the new Super Foxy which is a totally new bike.
    Example
    https://www.mondraker.com/uk/en/2020-foxy-carbon-rr
  49. #449
    Dec 2013
    Quote Originally Posted by badbietz View Post
    So the shock is a 205mm overall length?
    Good stuff right? I love the suspension on my Foxy but then from day one it was on an Avy Superdeluxe.
  50. #450
    Dec 2013
    The Super Foxy is 65mm before the headset.
    I think it's close but technically a different frame.
  51. #451
    Gigantic Hawk
    Example
    Thanks for the link. I didn't see it on their site the last time I looked. It is interesting to see that all the bikes now use the DPX2 rear shock. I know a lot of you have upgraded or complained about the rear shock, but I haven't had any issues with the DPX2 on my R.
  52. #452
    Dec 2013
    There is a place called Amachete Components in Spain that has the 10mm roller bearing for the lower shock mount for the Foxy 29. I just ordered 1, plus the press tool, shipped for about $51 after the Euro conversion.
    I'll let you guys know how it goes. I love my Foxy but was starting to seriously consider the EXT rear shock to try and get a little more rear sensitivity but was not keen on the money spent nor the .7# of gained weight so am trying this first.
  53. #453
    Dec 2013
    Also having some new wheels built utilizing Carbon Fan wheels with an AM layup up front 33mm ID 28 spokes & DH layup rear 29mm ID 32 spoke, using some new Project 321 hubs with ceramic bearings, and black BERD spokes. Lastly I'm trying some of these new Tubo Light 70 gram rim inserts over my current Pepi's inserts.
    All in, using the same hubs my current set up has, I'll save nearly 1# rotating weight so that should be quite noticeable.
  54. #454
    Apr 2019
    Hi guys! Soon I will need to change tires, with my last bike I always used minion dhf 2.5 front and back and usually when the back tire was too slick I would just buy a new one for the front and use the rest of rubber of the front tire in the back. But given the limited tire clearance of the foxy I'm not sure I can fit a 2.5 dhf in there.
    What tire combo are you guys using?
  55. #455
    Dec 2013
    https://r.tapatalk.com/shareLink/top...ink_source=app
  56. #456
    Dec 2013
    Lower shock roller bearing kit is on, shipped from Spain. Heck they included enough spare parts I could do another Foxy from the parts.
    Can't ride the bike because my dropper is removed currently but the bounce test you can certainly feel less stiction. Whether that is better or not for peddaling efficiency, I can't say.
    I'll report back with a ride report next week.
  57. #457
    Dec 2013
    So I finally received a new cable today to repair my dropper and was able to pedal around my Foxy with the Amachete lower link bearing just around the 'hood.
    What I can say was that when I added the bottom and top bearing to my previous Yeti the rear shock really lost all stiction and it felt like I actually lost efficiency. I did prefer it overall but in the same way one prefers a coil shock, with trade offs.
    With this mod on the Foxy at only the lower mount of the shock, the harshness that I use to experience on curb drops is gone and the shock is definitely quicker responding to sharp impacts and the jarring sensation is gone.
    However it doesn't feel wallowy when pedaling. This was the right move for me as opposed to going to an EXT coil shock. It saved a lot of money and a lot of weight and besides the previous feeling of initial stiction I really like my Avy tuned RT3.
  58. #458
    Dec 2013
    Had a good day and was able to ride the shock needle bearing on my air shock. It's a much less extreme difference than it was when I did the same at both ends of the shock on my Yeti.
    All it does is get rid of the initial slap down harshness I use to get on my rear suspension. No other differences that I can tell at all.
    It gave me exactly what I wanted, no more, no less. Worth the $50 for sure. That was all that I wanted out of a coil shock I was considering, just to soften that initial jolt and adding this bearing to my air shock did that with none of the downsides of a coil (i.e. weight, cost, lack of progression).
  59. #459
    Gigantic Hawk
    Good to hear. I will have to look into the bearing this winter when I take the frame apart for maintenance.
  60. #460
    Dec 2013
    I built some sweet wheels with Berd spokes. DH layup rear, wider up front, P321 hubs.
    The cool thing is my large Foxy 29 weighs right at 27.4#s (before pedals, bash guard, and tools are installed) and that includes Avy cartridges and tire inserts front and rear. It weighs exactly 30.1# ready to ride with CO2 cartridges, pump, tools, pedals, etc. The thing pedals like a XC bike and descends like a DH bike. I really like this bike!
  61. #461
    Gigantic Hawk
    27+ is light! I'm hoping to get mine closer to 30 after the winter rebuild.
  62. #462
    Dec 2013
    It took a while for me to really warm up to the MSC Gripper. Due to high summer heat (forecast says 97 degrees tomorrow, right before our 1st cold front of Fall) I wasn't riding as fast for a while there. Lately I've acclimated and my pace is fast and comparing the MSC back to back with the Eliminator it isn't even close, I much prefer the MSC. It has incredible grip, no dead spot, and is a perfectly rounded 2.5" width tire (labeled as a 2.3).
    It rolls pretty slowly however, on par with a DHF 2.5 3c or maybe a bit slower, but is a better all around tire for me.
    I'm going to experiment with the Tioga Edge-22 & the Maxxis Dissector but as of right now, I think the MSC Gripper is my preferred front tire.
    Thanks for the suggestion!
  63. #463
    Dec 2013
    New chain slap thing I just recieved today.
  64. #464
    Gigantic Hawk
    Is that for the Super Foxy? How did you order it?
  65. #465
    Dec 2013
    Qarv sent it to me. They just received them.
  66. #466
    Gigantic Hawk
    For those that are curious, Qarv is selling the chain stay protectors for $25.
  67. #467
    Dec 2013
    The new chain-stay protector definitely quiets things down.
  68. #468
    Apr 2019
    How many/what size of volume spacer/s are you guys using on your suspension and shock?
  69. #469
    Dec 2013
    I don't have stock suspension on my Foxy, but the LR is regressive near the end stroke so if you do any jumps or anything I'd load the shock up with volume spacers.
  70. #470
    Apr 2019
    Yap, I have the stock dpx2 and I find it too easy to bottom out, I don't bottom out often but I do chose the jumps I do.. I avoid doing bigger or rough landing ones because of this
  71. #471
    Dec 2013
    Add volume spacers.
    I use all of my rear travel most rides with an Avy tuned Superdeluxe and 1 volume reducer but have never felt it.
    Max 5' drops and some decent sized but smooth jumps.
  72. #472
    Gigantic Hawk
    I bottom out the stock DPX2, but I never notice that I do it on the trail. I believe the stock shock comes with a preinstalled spacer, but another can be added.
  73. #473
    Apr 2019
    I think that the tuning set contains 5 spacers with the following volumes: 0.2 inch3, 0.4 inch3, 0.6 inch3, 0.86 inch3 and 1.02 inch3.
    The stock one is the 0.6inch3. I'll probably try and change the stock one for the 0.86inch3 and try it. Probably I'll do it in the next maintenance.. Anyone using the 0.86? And the 36 I'll probably add one more spacer too, I like how the suspension feel but I'd like them to me more progressive at the end
  74. #474
    Apr 2019
    Bad news, I just saw in ridefox website that for 205x62.5 trunnion the biggest volume spacer that can be used is the stock one, 0.6inch3. For jumps there is no other option besides pumping some more pressure.. This is a bummer..
  75. #475
    Dec 2013
    If your going to keep the bike, search for a used Superdeluxe RT3 from an '18 Devinci Spartan and send it to Avalanche.
    Or call up RS and concoct a story, it got lost in thise mail or something.
    Maybe a Devinci store can order you one?
    I love my Foxy but dealing with the suspension decisions that Mondraker made was paramount to me.
  76. #476
    Gigantic Hawk
    I'm pretty sure somebody has already added more spacers than recommended with success. It was either in this thread or elsewhere, but it does exist on the interwebs somewhere.
  77. #477
    Apr 2019
    You can add them, but this is what fox says about using them: "WARNING: Never use an air spring volume spacer of a specific size with certain length, travel, and eyelet combinations, as shown by "DNU" in the table below. With these combinations, the resulting compression ratio goes beyond the bounds of safe product usability. With the spike of excessive air pressure the air sleeve can suddenly fail, causing potential property damage, SERIOUS INJURY, OR DEATH"
    I will not risk it..
  78. #478
    I ran a .86 for a couple of months in my Fox before I switched to a Super Deluxe with MegNeg air can (highly recommend).
    I'm 190lbs and think I was running around 175psi or maybe a little more. I spoke to a suspension tuning shop and they said as long as you are not near max PSI it shouldn't be an issue.
    I believe the logic is as follows. For example the Fox site states that a .6 volume spacer gives you a compression ratio of 3.81, if you are are running max PSI which I think is 350 PSI that would come to a fully compressed PSI of 1,333.5 (3.81X350).
    Between the different spacers .4 to .6 you gain a Compression Ration of around .4 but lets go crazy and say the .86 gives you a 4.81 CR, at 200 PSI that would be a fully compressed PSI of 962 (4.81X200) well below the 1,333.5.
    I would assume Fox put this chart together taking into consideration max PSI. If you are not near that I think you have some room to play around, of course you are on your own warranty wise and use at your own risk and all of that. It felt better to me with no issues to report YMMV.
  79. #479
    If anyone is dealing with cable rattle in the down tube I would recommend this TechFlex braided cable sleeve. It is split so you can wrap it around the cable and feed it through the frame holes little by little with no need to remove any cables. I put it on my brake hose, derailleur cable and dropper cable and don't hear them anymore. Best $10 I've spent.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  80. #480
    May 2016
    Quote Originally Posted by Mike2MTB View Post
    So I went for it.
    Glad I did.
    Hope this helps.
    What’s your other top 5 please? Thx
  81. #481
    Dec 2016
    I tried a Forbidden Druid. I'm selling my XL Foxy 29 soon. I'm based in Perth, WA. Any suggestions where to post for sale other than eBay?
  82. #482
    MTBR classifieds, PinkBike, etc.,
    I'm loving my Druid but am in the market for a longer travel bike... I'm a Medium/Large and have been eyeing the new Super Foxy29
  83. #483
    Dec 2016
    Quote Originally Posted by cheezwhip View Post
    Thanks mate, let us know if you pull the trigger on one!
  84. #484
    Dec 2013
    You guys should swap!
    Tell us about what you prefer with the Druid, no hard feelings here and the Druid looks amazing.
    The Foxy is killer but the OEM rear suspension choice lets it down and has to be rectified to get the full potential of the bike.
    There might be marginally better bikes as new models are released, but I like my Foxy enough that I intend to ride it for many years so I took the time (and money) to get it exactly how I wanted.
  85. #485
    Dec 2016
    I know, need an XL though! The Foxy is awesome, I will keep it probably until early next year.
    The Druid had a few interesting ride characteristics that seemed to fit what I was looking for in a bike. So I don't get a lot air but due to the lengthening of the wheelbase it seems to add stability on landings which I liked. Also the same kinematics means it powers through repeated square edged hits and fast rock gardens and holds momentum well.
    It pedals with just about the most stability of any bike I've ridden. It doesn't squirt forward but is efficient and firm. There were so many things I liked it would make it look like I was advertising for Forbidden of I carried on listing them! Needless to say it was a joy to ride for a couple of days.
    Cheers
  86. #486
    Jan 2011
    Interesting!
    I'm a guerrilla Gravity Fanboy, but I'm considering leaving the brand next season, and the Druid is on the top of my list (basically waiting for my revved smash to be sold to get the frame). I also demoed the Foxy 29 last year, and it's second on my list
    How would you compare the acceleration between the Druid and the Foxy, and say, a horst link FSR or 4 bar linkage? That's what shocked me the most on the foxy. It just accelerates by itself, pedaling is super efficient, and pushing on the pedals makes it move forward. Would you say the druid, has a similar snappy feeling? Or feels more average? You say it powers through square edges, which is good! But it could mean it feels a bit sluggish elsewhere (maybe).
    Thanks.
  87. #487
    I'm planning on keeping the Druid - it's going to stay as my uber capable shorter travel trail bike that punches way above its weight class but I'm still wanting a big travel Enduro sled to complement the Druid.
    If Forbidden had a 150-160mm travel bike, I'd already have it. The suspension is Yeti-esque in pedalling efficiency and Knolly-esque in climbing traction. Between the 29r wheels and the rearward axle path, I just don't get hung up on stuff I would've in the past with a 130mm travel bike.
    That Druid efficiency "feels" muted compared to the mini link designs though - does not feel like you're squirting forward but you really are... difficult to describe.
    In any event, the Foxy was on my list for deep travel bike - not keen on the SuperBoost though.
  88. #488
    Dec 2016
    Yeah I would agree with all of that.
  89. #489
    Dec 2013
    The Foxy isn't superboost.
    Maybe the Super Foxy is?
  90. #490
    Jan 2011
    Thanks, both of you guys.
  91. #491
    Dec 2016
    Quote Originally Posted by xavierp View Post
    Interesting!
    Thanks.
    I did write a detailed response but it didn't publish. Basically I feel that you lose no efficiency on the Druid compared to the foxy, but the suspension performance generally is more suited to fast rocky trails, jumps etc.
    I also like the anti-rise because we have steep trails here. It is also handy as I'll often brake into corners (who doesn't..) and this keeps the bike very stable in those situations.
    Cheers
  92. #492
    Gigantic Hawk
    I know many of us have put riser bars on our bikes, and some of us have slacked out the front with the adjustable headset cups...
    Anybody have any thoughts on putting 170mm fork on the front? It seems that it would help to increase the stack, and slack out the front a 1/2 degree while giving 10mm more travel. For me, this is just a hypothetical thought since I hardly use the full 160mm I have now.
  93. #493
    Dec 2013
    I'm finding myself riding really far forward on the saddle on my Foxy, with the seat already slid far forward.
    Just not willing to slack the STA out any more.
    The 27.5" rear end with the fork dropped to 150mm sounds more appealing to me honestly.
  94. #494
    Gigantic Hawk
    Interesting. My saddle is semi forward. I probably should ride farther over the bars than I do currently.
    Don't know if this interests you, but 9point8 makes a dropper post with a 25mm forward offset head.
  95. #495
    Dec 2013
    I think that dropper is a good solution for an old school bike that's maybe 1-2 sizes too large for the rider. But would mess up too much else on the Foxy.
    Also, I'm going to bump up to a 40 or 45mm stem on my Foxy to try and weight the front end a bit more. At 5'11" but with long arms the cockpit actually feels just a hair tight on my Large Foxy.
  96. #496
    Gigantic Hawk
    I'll be interesting to hear your input on the longer stem. The only time that I really feel that I'm not forward enough is on really steep climbs, and when I'm hitting bigger jumps.
  97. #497
    Dec 2013
    This is really a slick cable management idea from the new Foxy E- bike. Maybe it's only possible due to the larger steerer tube on the new e- bikes?
    Would love to incorporate this in to my Foxy 29.
  98. #498
    Dec 2013
    Had a very solid first ride on a 40mm stem on my Foxy 29 (previously on a 35).
    Very noticable difference both in how much more weight I had on my hands, and notably more traction up front.
    For the first time my Foxy truly was balanced for me thru the turns. Was really not touching the brakes entering and thru long fast turns and could completely trust the front end to stick. For the first time the bike didn't understeer or if it did it was very minor.
    Still love my Foxy but I think their super short stems are a flawed idea (along with their coil shocks). Would be fun to try a 45mm stem as well but I'm in a very comfortable place on the bike physically and don't feel like dropping another $80 to test a different stem.
    My best guess is the stem they include on the Foxy builds should perfectly match the fork offset they offer, if they want to truly optimize performance.
  99. #499
    Has anyone tried taking out the spacer from the rear Shock to get the full 65mm and a bit more travel?
  100. #500
    Dec 2013
    Quote Originally Posted by lost it View Post
    I've heard (from Qarv) that it's rear tire size dependent. Because of flex under extreme loads, a large tire might rub, where smaller tire might not.
    You could remove all of the shock air and collapse it and look and see how much clearance it appears that you have to work with. Could probably also just remove the shock and sort of visualize that extra 2.5 mm.
    Report back!
  101. #501
    Dec 2013
    My sole complaint about my Foxy is that limited rear tire clearance means that picking up leaves and them getting stuck between the tire and the chainstays during Fall riding is a constant, and quite annoying.
  102. #502
    wuss
    Reputation: dropadrop's Avatar
    Just picked up a XL yellow RR for a great price. Currently have a flu so just admiring it on the balcony...
    Also this time of the year sun set’s around 2pm and trails are partially frozen (but not enough to justify studded tires) so might wait for proper snow.
  103. #503
    Dec 2013
    Best color for sure.
  104. #504
    wuss
    Has anyone checked what ratchet is in the included E1700 wheelset? Is it the standard 18t model?
  105. #505
    Nov 2018
    On the aluminium model it works just fine, but on the carbon there is not enough space.
    Quote Originally Posted by dropadrop View Post
    Yes 18T is standard for DT350 mounted on DT E1700.
  106. #506
    Nov 2018
    My sole complaint about my Foxy is that limited rear tire clearance...
    That's why i sold it and bought the aluminum version.
  107. #507
    Dec 2013
    Quote Originally Posted by embi View Post
    Eager to know about any all differences that you noticed between these 2 models including:
    1) Weight difference.
    2) Ride feel difference/ Most important!
    3) Clearance and suspension differences.
    4) Anything else you can think of.
    Nov 2018
    Foxy Carbon vs Foxy Aluminum
    1. Weight - the bike is noticeably heavier. Clocks almost 16kg with an air shock.
    2. Ride feel - better than the carbon IMO, the rear end is stiffer due to larger brace connecting the triangles, also the reach is 5mm longer
    3. Clearance - there is much better clearance for larger tyres and mud a reason why the carbon bike is unrideable for me
    4. Suspension - similar feeling, but you can run 65 stroke shock without any issues
    5. Protection - the paint wears more easily than on the carbon version and there is zero protection for lower link and shock (mud and debris). Also no chainstay protection and you can't mount bashguard on the bike.
    I sadly have to say, that the Mondraker Foxy (both AL and carbon), are not a good bikes from a technical standpoint. But once you're on the trail, you forget it, because the bikes just rides amazingly well.
    The SuperFoxy fixes many issues of the Foxy and takes the best from both bikes
  109. #509
    wuss
    When I picked up my 2019 the dealer mentioned that they would have changed the valving of the shock for 2020 so it would work better with the frame.
  110. #510
    Gigantic Hawk
    For those looking for more rear tire clearance, I wonder if the aluminum rear end would swap onto the carbon front?
  111. #511
    wuss
    Did anyone prefer an X2 as shock? Saw one cheap second hand and wondering if I should pick it up... Only had two brief rides up to now so did not finnish tuning the stock shock but likely the X2 will be sold before I know if I like this or not..
  112. #512
    Jan 2014
    My friend taken one from Superfoxy. totally changed suspension from hate to love.
  113. #513
    Dec 2013
    The air shock sizes that the Foxy utilizes are becoming more commonly available as they are oem fitment on several new bikes. A couplel for sale used on PB right now.
    I'm going to be experimenting with a Meg Neg on my RT3 very soon, unfortunately I broke some ribs in a bike crash so I'll be off for a bit and it'll be a bit before I can experiment.
  114. #514
    Gigantic Hawk
    Bummer! Hope you have a fast recovery.
  115. #515
    Dec 2013
    For sure I'll bounce back quick.
    Have a family ski trip in 3 weeks so just managing nutrition well and protecting the injured ribs (2 are fractured) until then.
    Thanks for the kind words.
  116. #516
    Oct 2017
    That sucks. Those XC rides are sneaky bad.
  117. #517
    Dec 2013
    Quote Originally Posted by mrallen View Post
    Got me on a night ride at Travis Country. Was following a guy, was completely turned around and didn't recognize where we were at, he rolled a ledge and I followed, turns out it was a decent vertical drop and over the bars I went! First crash in a long time.
  118. #518
    Dec 2013
    Not shopping, but just curious why the Super Foxy was announced 6 months ago yet has not been reviewed or released yet. Seems like a very large gap to me.
  119. #519
    Jul 2015
    I have been wondering this same thing. Especially when they seem to be showing up in the hands of riders on their social media platform.
  120. #520
    Nov 2018
    What do you mean by released? My mates have been riding the Foxy for 2 months now.
  121. #521
    Oct 2017
    That sucks. Glad it wasn't worse. Same thing happened to Willie over there following me a little while ago. He didn't break anything, but that is just luck when you are falling into rocks.
  122. #522
    Dec 2013
    The Super Foxy? Reports?
  123. #523
    Dec 2013
    I added a Meg-Neg to my RT3. It clears. Because I have broken ribs I won't get a real ride for a month but I can tell you that riding off a curb seated it's notably less harsh than it was before. I pedaled a bit hard on pavement and noticed no bob, however I'm not exactly pounding it at the moment.
    I started with the max number of negative spacers simply because I was weary of losing the pedaling efficiency that I adore so much on this bike.
  124. #524
    Dec 2013
    Hey all, long time lurker first time poster to this thread. I'm selling a brand new 2019 Foxy Carbon 29, RR (yellow and orange) size Large. Might have seen it on a few classifieds lately.
    I have a few options for complete builds (stock and significantly upgraded) and am willing to mix / match parts around a price point within reason. Get in touch if interested, thanks!
  125. #525
    Dec 2013
    I also have two needle bearings from Amachette I need to part with, both brand new never installed. $25 each
  126. #526
    Dec 2013
    Quote Originally Posted by mellymelson View Post
    Sorry to hear you are selling it. Weren't you just collecting parts for this build?
  127. #527
    Dec 2013
    I was, but circumstances have changed for me...Hate to see this beautiful bike go, but hope it finds a good home soon
  128. #528
    Dec 2013
    Well the yellow is my favourite color. Hope it sells for ya. They are rare and not particularly popular bikes but I adore mine.
    Did you get a sponsored ride on another brand or something?
  129. #529
    Dec 2013
    I digg the yellow, too. Perfect match for the Factory orange Fox forks. Yes, I got picked up by another brand for this season. Had some great results with the Foxy in 2019 though.
  130. #530
    Dec 2013
    Am I the only guy running a RS Superdeluxe on a Foxy? I have a spare new take off Superdeluxe from a 2020 E29 by the way if someone is in a pinch, never ridden but it would need to go to Avy to have the stroke adjusted.
    Anyways, I broke 2 ribs and possibly punctured a lung 3 weeks ago so needless to say I have not been riding and had not tested out the Meg-Neg yet.
    I have went on light duty XC short pedal rides 2x this week trying to get my legs back and frankly trying to unseize my back which locks up when I'm stationary for more than a couple of days.
    Basically removed one volume reducer in the positive side down to 2, and used all 4 (the max) bands in the negative chamber which is the setup that makes the Meg-Neg addition as close to how the shock was before by reducing the larger negative chamber as much as possible and keeping the ratio of pos to neg chambers pretty similar as it is with a standard chamber. That said, even like this the Negative chamber is 67% larger than stock! I did this because I either really like, or am just really use to the Foxy's rear suspension and was afraid to make a large change that would negatively effect pedaling performance. It took about 40 psi more shock pressure to get the same sag because of the additional neg volume.
    To reiterate these were light duty rides due to recent injury, however I can clearly feel some, not so subtle changes. Basically the shock is more plush off the top, but it's not like a coil shock. It's just an initial jolt that I'm use to is gone. It's super noticeable just riding off the curb while seated. That said if I removed all 4 negative bands and had the negative chamber 111% larger than stock it would be a lot more like a coil I imagine.
    The even larger difference is in the shock's midrange. The bike seems to sit way higher when just pedaling around, way more supportive. Really, it feels like I now need more sag but since I'm riding XC terrain anyways, it's too soon to make any adjustments until I get back to my usual speed. That said it needs more sag. But then I wasn't riding with my usual Hydration pack and I've actually lost 7# since the accident so this air pressure might be ideal in another month.
    ShockWiz says everything is perfect except HSC is a bit too stiff, which frankly is something that SW always says about Avy tunes (and I mostly agree). But I'm only using 70% of travel so I'll update once I get some harder rides on the bike.
  131. #531
    How did you mount your ShockWiz with the MegNeg can?
    I'm running a Super Deluxe from a Reign with a MegNeg (215 PSI, 1 band in neg chamber, 3.5 in positive)
  132. #532
    Dec 2013
    I'm pretty weight weenie but I won't sacrifice performance to save weight.
    Weighed my large Foxy as I ride it with 1000g tires, inserts, real hubs, 203mm front rotor with 4 piston caliper, Avy cartridges, Meg-Neg, tools/ pump/ CO2, bash guard, SW, water bottle cage and pedals and it's sitting at 30.2#s. Darn that is impressive for a bike this capable.
  133. #533
    Dec 2013
    I'm running 4 bands in the negative chamber at 192 psi @ 180#s, and the rear suspension has a ton of midrange support which I like. It's not bad or anything but any more mid range firmness and I'd think it would feel like a 100mm XC race machine instead of an Enduro bike. Did you try different numbers of bands? Thoughts on different combos?
    If you have a debonair in a RS fork, there's a black rubber bumper in the negative chamber that you can remove and it notably increases the negative chamber volume and has a very similar effect on the forks as you get with the Meg-Neg in the shock and increases mid range support. That I REALLY like. I had to up my fork pressure from like 92psi to 110 with this one change.
  134. #534
    Jul 2016
    Has anyone fitted a 2.4 on the back of the aluminum model? I am thinking Michelin Wild enduro or something similar. Stock 30 mm rims does it roll without any rubs?
  135. #535
    Dec 2013
    Quote Originally Posted by samperg View Post
    I've commonly ran Schwalbe 2.35s which measure about 2.42" on my CF Foxy, and the Al version has additional clearance. I don't see you having a problem here.
  136. #536
    Apr 2019
    I'm using 2.4 dhr2 in my carbon foxy and so far no rub at all.
  137. #537
    Jul 2019
    Hello guys. sorry my english.
    I have a foxy 29 RR, has anyone ever brought the fork to 170?
    the handlebar has 20mm, do you recommend 30 or 35? thanks
  138. #538
    Dec 2013
    I haven't seen any Foxy's ran at 170mm.
    I run my stem as low as possible to extend effective top tube length and utilize a 35mm riser bar on a large Foxy.
    Good luck.
  139. #539
    Jul 2019
    Good luck.
    What do u think, upgrade fork 170mm?
  140. #540
    Dec 2013
    Quote Originally Posted by aljocha View Post
    I guess that depends on my goals and body weight.
    My personal opinion is that single crown forks already flex too much at 160mm. And for my needs and usage a 160mm is just fine.
    So 170mm just exacerbates this problem. But also it's damaging to your geo. Seat tube becomes slacker, BB becomes higher, etc... Certainly won't need those tall bars if you go the 170mm single crown fork route.
    If I felt I needed more fork travel on my Foxy I'd either:
    a.) move up to a Superfoxy. Or...
    b.) Purchase a 170mm MRP Bartlett. The Bartlett is dual crown which fixes the flex problem, but also due to the packaging advantages of a DC fork you can keep your Axle to Crown (A2C) measurement very nearly the same as a single crown 160 accomplishes, while getting your 170mm fork travel.
    https://mrpbike.com/products/bartlett
    The Bartlett at 170mm travel has 574mm A2C.
    The Fox 36 at 160 travel has 570mm A2C.
    That's pretty close.
    I've heard rumors, but don't know for a fact, that you can run the 205 x 65mm shock on the Foxy instead of the as speced 205 x 62.5. They are identical shocks of course, just the slightly shorter stroke is obtained using an internal 2.5mm nylon washer. Removing that washer should get you 156mm rear travel.
    Good luck and let us know what you find.
    I really want to speak to one of our Foxy 29 owners about dropping their fork to a 150mm and running a 27.5" rear wheel. Who here is going to try that? I'm mostly trying to go faster/ longer on very rough trails so my goals lean towards that.
  141. #541
    Jul 2019
    in reality it is only to try to raise it and open the degrees of 66.
    I mounted a fox dhx2 205 x65 and it is ok
  142. #542
    Dec 2013
    Run the 40mm rise Renthal bar, install a -1 headset.
    Much better solution. In fact the -1 headset actually steepens your STA and drops your BB, although not by much in either case.
  143. #543
    Gigantic Hawk
    It is a lot cheaper to try a Wolftooth lower headset spacer (10mm) than it is to swap forks.
    https://www.wolftoothcomponents.com/...-zs-zero-stack
  144. #544
    Gigantic Hawk
    So running a 205x65 rear shock is intriguing. At full compression, I have roughly 7 mm between the tire and the seat tube. I know on hard bottom outs that this distance must be smaller. I wonder if the longer stroke will cause the tire to hit the seat tube?
    Aljocha, do you have any pics of your shock aired out with the suspension fully compressed? I'd be interested in seeing just how much space there is between the tire and the seat tube.
  145. #545
    Sep 2018
    PM sent!
  146. #546
    Dec 2013
    PM sent!
    I'd also take one for $25 shipped.
    Sent from my SM-G960U using Tapatalk
  147. #547
    Dec 2013
    I'm effectively running my front fork as a 150mm travel fork as my front fork naturally sags 10mm and I'm not setting sag based on 160 any longer but based on 150 instead.
    I'm an aggressive trail rider and I think I prefer the overall feel of the bike like this. It just seems really responsive and fast with great front end traction.
  148. #548
    Gigantic Hawk
    Does it feel better because the stack is lower? The head angle is steeper? The fork performs better with more sag?
  149. #549
    Dec 2013
    Not sure, heck maybe it's all in my head.
    The bike just feels very sporty, a bit firmer and steeper (even though I have the -1 headset installed), rigid and accurate, less floppy on climbs, and with really good front end traction.
    Not sure if all that is due to this 1 small change or if my entire set up is just now fully dialed for me.
    I know this, a replacement bike isn't even being considered, this one feels so right.
  150. #550
    Jul 2016
    I am having near perfect setup, but in the very steep rolls the front end seems to disappear in to the distance what should I do to this? body position? more stack height? already have a 35mm riser. More volume spacers in the fork? 0 atm because I feel like it works the best in the flatter rooty trails for me.
  151. #551
    Dec 2013
    I personally think the 30mm stem is a no go. It's not about bike fit, it's about front end feel. 45-50mm stem is the sweet spot.
  152. #552
    Gigantic Hawk
    A bigger rise bar helps to keep the front end pointed straight on the climbs. Suns-PSD may be right in that a longer stem may be the way to go. Currently, I have a 50mm rise bar that rides quite nicely, but I prefer a higher stack.
  153. #553
    Dec 2013
    I run a 35mm rise Oneup bar at 5'11" on a Large with 1 small spacer underneath. I'd run a 40mm rise bar if Oneup made one.
    I tried all the stem lengths from 30 to 60mm. I ended up keeping the 45 as my ideal. Comparatively the 30-35 length stems are pretty bad. The front of the bike (any bike really) won't stay in place and the bike understeers. Stem length is NOT just a fitment issue, it's much more than that.
  154. #554
    Gigantic Hawk
    I have no idea how anybody was able to control the earlier Mondraker bikes that came with a 10mm stem.
  155. #555
    wuss
    Anyone have opinions on wheels? Was thinking of saving some weight by replacing the E1700’s with a custom DT180/XM481 setup... With light spokes that ends up somewhere around 1650g.
  156. #556
    Dec 2013
    I ordered hoops from Carbon Fan, P321 hubs, and then had them built up using Berd spokes.
    I did this because I was able to select every facet of the wheels from width, number of spokes, and lay up. And I made decisions separately for the front and rear based on this. They also came out extremely light, I forget how light but even with a rear downhill layup it was under 1450 as I recall.
    My total cost was right at $1500.
  157. #557
    wuss
    I’m in Europe so slightly different market, but the basics probably are similar. I would be ordering the build from a shop known for doing good builds.
    I was considering aluminium as I don’t really want to be thinking of my rims when I should be thinking of my lines. I don’t do too much big jumps or drops, though there are some small ones here and there. I’m generally also quite light on my my wheels, never broke a set. But my trails are really rocky and I frequently scratch my rims, I assumed carbon might not like that?
    I did find a set of 2020 DT Swiss XRC 1200 for a really good price. Those are only 25mm internal width, but could be strong enough for me (I noticed DT has bumped them up to ATSM3 and at the same time moved XMC1200 to ATSM4 so they might have more trust in them).
  158. #558
    wuss
    What’s that brake adapter in the back? Has anyone put a 160 disc on the rear, is it possible?
  159. #559
    Dec 2013
    The Foxy's arrive with a specific brake adaptor. 180mm is the only rear choice and appropriate for this application.
  160. #560
    Gigantic Hawk
    Spank and Newman make some of the lightest and strongest aluminum rims that you can affordably buy.
  161. #561
    Sep 2017
    In Europe you can look for bargains at rczbikeshop. Bought xmc1200 (30mm) for my Foxy from there. But they are not really a shop, availability is sporadic and delivery may take 90 days..
  162. #562
    wuss
    Thanks, I actually subscribe to their newsletter but have missed the XMC1200 every time. I also find the newsletter annoying, I ordered DT carbon wheels for my roadbike from them. Great price, but I still don’t have them almost 2 months later...
    I’m currently contemplating between EXC and XMC.
  163. #563
    Sep 2017
    Make sure to subscribe to the French newsletter. It arrives always 1-2hours before the English one
    I sort of wish I would have gone with XRC1200, then the bike should have been just below 13kg. Now it is 13.2kg. Well, it is just a number
  164. #564
    wuss
    If I had the XRC series I think it would affect my riding. I was contemplating for long, and decided on the EXC 1200. I think it’s likely overkill, but still very light and should be ok even if I pick bad lines.
  1. Need Help Choosing a Mondraker Foxy! Carbon or Alloy?
    By krylon1892 in forum All Mountain
    Last Post: 12-30-2017, 07:05 PM
  2. Opinions on Mondraker foxy carbon
    By abalu16 in forum 27.5
    Last Post: 10-29-2015, 10:16 AM
  3. switch to mondraker foxy rr carbon 2016?
    By abalu16 in forum General Discussion
    Last Post: 10-28-2015, 02:58 AM
  4. Replies: 5
    Last Post: 10-30-2014, 03:58 AM
  5. Mondraker Foxy...
    By djayuk in forum All Mountain
    Last Post: 04-09-2011, 10:38 PM
Members who have read this thread: 161
