    Apr 2005
    Maxxi DHF 2 rear
    How good is this tire for 26"?
    Sent from my SM-G965W using Tapatalk
    Nobody knows. Maxxis doesn't make a DHF 2.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    the DHR 2 is a great rear tire!
    ninjichor.com
    Reputation: ninjichor's Avatar
    Jul 2018
    Need to be more specific, as there's a ton of variations:
    General Tread Pattern: Minion DHR 2, Minion DHR 2 WT, Minion DHR 2 Plus, Minion FBR (sorted from narrowest to widest)
    Tread Compound: Single Compound, Dual Compound, 3C MaxxTerra, 3C MaxxGrip, SuperTacky (sorted from least slowest/tackiest to to most)
    Casing: Standard, DD, Dual Ply (sorted from lighter duty to heavier duty)
    Reinforcement: Standard, EXO (sidewall slash reinforcement)
    Carcass/Bead Lining: Standard, TR (tubeless)
    Width/size: "2.3" (58-559), "2.4" (61-559) (in DHR 2 and DHR 2 WT)
    Generally, the tire has relatively low rolling resistance*, only slightly more than an Ardent, and has consistent dependable all-around handling characteristics. It also works on the front, instead of the Minion DHF, if you prioritize low rolling resistance* over cornering. Weights are average starting at under 800g, very competitive in the trail/AM market. It won a few awards as best all-around tire from a number of publications. You can modify the tire to have cornering traits similar to the DHF with some labor-intensive knob trimming of the wider set blocks, to create a gap between center paddles and shoulder knobs.
    * DHR2 generally tests around ~30W depending on wheel size, compound, carcass, and pressure (combined resistance of 49W, with MaxxTerra front and DC rear in 27.5 EXO, for reference). DHF and High Roller 2 in 3C MaxxTerra are ~45W and up (their testing rig maxes out at 45W, but the HR2 rolls slower than the DHF). High end road tires are ~10W and XC tires range from 20-30W.
  1. Replies: 9
    Last Post: 02-13-2018, 02:06 PM
  2. Replies: 6
    Last Post: 07-28-2016, 09:04 PM
  3. Maxxi High Roller 2.35 vs 2.10?
    By ithacking in forum Wheels and Tires
    Last Post: 08-08-2014, 08:33 PM
  4. Dhf ust or standard dhf 2 ply for tubeless
    By trap121 in forum Downhill - Freeride
    Last Post: 06-04-2013, 10:08 PM
  5. Minion DHF/DHF or DHF/DHR for Downieville?
    By Taz8 in forum California - Norcal
    Last Post: 07-13-2007, 02:22 PM
Members who have read this thread: 95
