Leaking fork on a new DB Hook- Mtbr.com
Results 1 to 6 of 6
    May 2019
    New question here. Leaking fork on a new DB Hook
    Hey I'm new to the forums and I just want to hi.
    I just got a diamondback hook and I noticed that both my front forks are leaking.. I come from a motorcycle background so usually a oil ring around the fork that comes back after wiping it off means it's leaking. Is this the same with mnt bike forks? And will DB just send me a new fork or do I have to ship my hole bike back to them??
    Aug 2014
    Normal especially with a new fork. Just wipe it down after your ride. Enjoy your new DB!
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Need more specifics, typically, oil doesn't come out of the stanchion fork seals, but some very inexpensive suspension forks may not really be sealed and some grease may come up. Post some pictures of the oil ring. Rear shocks do this more IME, as they tend to push out a bit of excess lubrication oil/grease after service. Is there a loss of damping? Are the adjusters effective (does it have adjusters?). Possibilities include: it's just purging a bit of lubrication oil/grease, it's leaking lubrication oil, it's leaking damping fluid into the fork, seals are bad/not seated.
    May 2019
    Here is a photo.. I do have adjusters on the top of the forks
    Attached Thumbnails Attached Thumbnails Leaking fork on a new DB Hook-img_20190518_184115.jpg
    Reputation: Lone Rager's Avatar
    Dec 2013
    Normal on new forks. It will decrease over time...until it starts increasing significantly if not serviced at appropriate intervals.
    Do the math.
    SR Suntour XCM 120mm appears to be the spec fork. This is designed as a bike path smooth trail piece of kit by Suntour. It's main purpose for bike manufacturers is to look like a mtbike fork. Inside are plastic bushings instead of metal. It also lacks adjustable rebound damping. Suntour has set up a program to allow you to get a real fork if you ride trails with bumps.
    https://www.srsuntour.us/pages/upgrade
    A Raidon air fork with the grease in the air side changed to oil is a decent choice.
  1. New Diamondback Hook
    By brandonmcnasty in forum Diamondback
    Last Post: 07-24-2018, 12:26 PM
  2. New here...DB Hook on its way...
    By Supernoob2011 in forum General Discussion
    Last Post: 07-28-2017, 07:10 PM
  3. Need help finding a new front wheel for a 2016 Diamondback Hook
    By Mad_Maxxis in forum Wheels and Tires
    Last Post: 07-25-2017, 08:00 PM
  4. Fork upgrade for Diamondback Hook
    By jr22 in forum Shocks and Suspension
    Last Post: 09-09-2015, 12:49 PM
  5. New Specialized carbon hoops with no bead hook
    By mattgVT in forum Wheels and Tires
    Last Post: 09-25-2012, 05:57 PM
Members who have read this thread: 38
