I love flat pedals, but....- Mtbr.com
Results 1 to 158 of 158
    Reputation: Ze_Zaskar's Avatar
    Hi all,
    Just for context, was a clipless user for 10 years or so, current bike is a Bird Aeris AM9 enduro 29er (long wheelbase, 500mm reach at size L).
    Decided to try flat pedals one or two months ago, Nukeproof Horizons Sam Hill edition with Shimano GR7 shoes.
    Had lots of trouble at first with feet coming off in jumps and drops. Then ended up improving mid foot pedal, heels down thing, along with better weight distribution and learning to work with the bike Vs fighting it.
    So, right now, have no problems with jumps, drops or corners or flow style trails in general. In fact, 1 month of flat pedals made me a much better rider in these conditions.
    But, big but, I still struggle at high speed rough sections. I used to be the absolute king of charging through stuff in my group, but with flat pedals I slow down considerably on rock gardens or generally fast, rough sections. I'm speaking about proper enduro and DH tracks.
    It seems no matter how hard I try to move rearwards to put weight in my feet they are still not loaded enough to stay put. Also, by then I start to have too little weight in the front end, causing traction and stability issues.
    Have a race in 2 weeks so need to sort this out.
    Anyone experiences the same? Any tips regarding suspension setup?
    Mind my bikes very long geometry proposes a "weight forward" riding style. Can this be a source of the issues?
    Thanks in advance
    Aug 2015
    Probably just need more time. I dont even think about it anymore so i cant tell you what i do but i think i have heels down and absorb the bumps with my knees. I think you will naturally be stable in the attack position. Need decent shoes though. Something like 5.10s
    Sent from my SM-G930V using Tapatalk
    I'm on Shimano GR7s, supposedly are good shoes.
    Then I find myself thinking, all the pros are on clipless (except that alien Sam Hill) so why bother?
    Reputation: Sesostris's Avatar
    Jan 2016
    It just takes time to adjust back to flats. I grew up riding flats then switched all my bikes over to clipless pedals for 8 years. Had no issues with them but I have more fun riding aggressive with flats and 5.10 freeriders.
    Anyways 2 years ago I switched back to flats including my road bike just because. At first I would randomly have a foot blow off the pedals but it was just bad form from riding clipless for so long. It stopped happening after a few months of adjustment. Just stick with it and you will get used to it. For reference my main bike is a YT Capra 29 and ride some steep rocky trails in SoCal and occasional bike park (Mammoth and NorthStar)
    Apr 2014
    Have you adjusted your suspension setup?
    https://youtu.be/v9K0cj7UeA8
    I like bikes
    Feb 2014
    I give it another 3-4 hours before someone tells you that your technique is obviously poor and that's the source of your problem......
    Quote Originally Posted by Ze_Zaskar View Post
    There's a reason that everyone except Sam Hill is using clipless, it's faster on the rough stuff unless you have exceptionally good flat pedal technique. Unless you've spent years & years practising and mastering flat pedal riding, you're not going to be as fast on flats as you are on clipless.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by aerius View Post
    I don't think that is necessarily it. I have and use both pedals. I don't ride with clipless pedals in races because they are inherently faster. I use clipless pedals in races because i don't have to think about foot placement. The one drawback to platform pedals is that you have to think about foot position a LOT and frequently adjust foot position. With clipless, once you are attached, you don't have to think about it anymore, leaving more bandwidth to think about other things you need to keep in mind during a race.
    Sent from my VS995 using Tapatalk
    jcd's best friend
    Reputation: Battery's Avatar
    May 2016
    I use both too. I picked up a set of Crank Brothers Mallet E pedals and I like them. I also have a set of Shimano M520 pedals on my road bike. Additionally, I have 2 sets of flats in my garage. I think Iím a pedalholic and need an intervention.
    Cannondale Synapse Neo | Salsa Timberjack
    Reputation: plummet's Avatar
    Go faster do you skip over the top of all the bumps!
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Quote Originally Posted by UtahJohn View Post
    Ha!
    Here it goes... In the really rough I lock my feet in.
    Heel down toe up on lead foot. Back foot has the toe slightly down, heel slightly up.
    By pushing your feet apart you can do what you want with the bike. Imagine a big pipe standing on end. Stick your hands inside. Now grip and pick up the pipe by pushing hands apart.
    Maybe speed up the rebound.
    Give it time.
    Overall, I still prefer clips and I think they are faster.
    WillWorkForTrail
    Jun 2012
    Just out of curiosity, have you tried grabbing a harder gear when you get ready to charge the rough stuff on flats?
    Aug 2015
    If you're referring to pedal kickback, isn't it better to be in a lower gear or easier gear to minimize anti squat?
    Oct 2015
    By any chance does your bike happen to have high antisqaut and you're getting a lot of pedal kickback that you're only noticing now on flats?
    Reputation: vikb's Avatar
    I have been riding flats for nearly 10yrs with the 15yrs before that on clipless. I have not ever wanted to be clipped in again and have not had any issues with my feet coming off the pedals in rough terrain [coastal BC, SW desert].
    I'm not familiar with your shoe & pedal combo, but that's my first thought. If you don't have pedals with sharp pins and a shoe with sticky rubber your feet will have a hard time staying on the pedals.
    I've run 5.10 shoes the whole time I've been on flats and I know they work well. I've never tried Shimano shoes, but just from reading reviews it seems like nobody has the same level of grip as 5.10 so that could be your problem.
    Checking how sharp your pedal pins are is easy. If they don't feel a bit dangerous to your shins they are too dull. You should be able to replace the pins on most quality pedals.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: Lone Rager's Avatar
    Dec 2013
    Any moron can ride clipless. It takes a special kind of moron to ride flats. I rode clipless exclusively since the late nineties before switching to flats on mtbs ~2 years ago. It was a steep and painful learning curve but I'm OK at it now.
    Of course, no clipless riding motos but motos are different mainly due to being a lot heavier, not to mention no pedaling.
    What, me worry?
    Reputation: In2falling's Avatar
    Jan 2005
    11mm monster/terror pins with 5-10 shoes is almost like being clipped in. Have to literally peel my shoes from the pedals.
    Like others have said, takes longer to learn to ride/master flat pedals but its worth it.
    ZEN RIDER!
    Reputation: Mt.Biker E's Avatar
    Mar 2006
    Rough sections try dropping your heels pressing down. Just have to build muscle memory.
    I haven't ridden spd's in 6 yrs after using them for 15, and when I am exhausted I still try to pull up on the pedals when going up and over things. I laugh every time I do it.
    Life in every breath
    You are not going to be a guru in 2 weeks. Revert back to spd's for the race or accept that you will go slower for a while until your used to flats.
    Thanks for all the answers
    On suspension setup, I might try to speed up rebound a little. I was, perhaps wrongly, convinced that I needed to slow down rebound to calm down the rear.
    Interesting comment on the suspension kinematics. The Bird Aeris happens to have a fairly high anti squat, around or a little over 100% AFAIK.
    Vikb, my pedals are the same model as used by Sam Hill, they are all the rage here in EU
    Apr 2014
    Iíve been riding for five years, only on flats, never tried clipless. I canít remember the last time Iíve beed bounced off or slipped a pedal.
    Your pedals look fine, but like vikb I am not sure about the shoes. Iíve only ever used 5.10s and they are fantastic.
    How stiff are you when you ride? When I ride rough sections I tend to ride very actively. Heels general down, but I am actively absorbing the rocks through my legs (legs compressing and extending just as a shock would)
    Second, I tend to ride with the heavy feet light hands philosophy. If my feet are heavy and my hands light my weight is typically well centered on the bike.
    Aug 2014
    FYI, I read a couple of user reviews saying those gr7s aren't as grippy as 510s. Something to consider.
    Reputation: jeremy3220's Avatar
    Jul 2017
    I just got a hardtail after not riding one for a couple months. I've only ever rode flats but my feet got bounced off a bit a couple times on smaller rough sections. I realized I didn't have to be as active on the FS over small stuff and I had gotten lazy and let the suspension soak it up. On the big stuff I had no problem on the hardtail cause I was aware I needed to be active.
    My guess is you're experiencing something similar going to flats, where before you didn't have to actively keep your feet on the pedals. You probably need to make sure you're actively controlling how the bike tracks over rough terrain. I think you just need more time on the flats. Practice staying active and keeping your head level.
    Revalve the suspensions in your legs
    Gotta agree it's the shoe pedal interface. What you have is good up to a point of speed/roughness. Beyond that you need longer and/or sharper pins combined with stickier soled shoes. And maybe technique can offset some of that. Sam Hill pedals may need a little more development to get his technique. Plus his pins may be tuned based on his experience. Same with shoes. Keep pedaling.
    Reputation: cookieMonster's Avatar
    I've been running both types of pedals for close to 30 years, platforms a little longer of the two. I am just as fast on platforms, and prefer them in nasty conditions. And when I say nasty conditions, I mean North Shore, Red Bull Rampage, and World Cup caliber DH courses. The pedals I currently use have not only long pins, but they are pointed and threaded all the way to those points. There is no such thing as slipping off them with 510 shoes.
    I don't think about staying on them, regardless of trail conditions. When descending my dropper is slammed all the way down and my rebound speed at both ends of the bike is matched, and on the faster side. Even though I run 180mm at both ends, my greatest suspension is my arms and legs. Though it is important to ride loose and as if your arms and legs are your greatest assets with both pedal styles, clipless pedals allow you to be a little lazier.
    I think this is almost purely a technique issue, but possibly a little bit of a tuning issue. A month or two isn't enough time to become 100% proficient with platforms. You will discover subtle changes as you spend more time with them.
    For your race, I'd stick with clipless for now. But stick with platforms, they're amazing once you master them.
    OP, what are you trying to gain with flats? It sounds like you're all fighting them just for the sake of being on flats?
    I tried switching back to flats. There's very few sections where I felt it gave any sort of advantage, so I stopped fighting my pedals and went back to spd.
    I'll speed up rebound in the rear a bit and see what happens
    One Pivot,
    I'm quite a bit faster on corners with flat pedals, and feel much more comfortable jumping and dropping on them as well. Also climb better, go figure...
    My only issue is really high speed charging through stuff
    One Pivot,
    If your quite a bit faster cornering on flats it means you're not commiting to the corner in spds.
    That's possible.
    It feels much more natural to me to corner with flats. I think my past on dirt bikes has something to do with it. I also have the awkward habit of twisting my feet quite a bit when doing the body english on tight repeated corners, which leads to some unwanted unclippings
    Oct 2015
    Also I've seen a bike review of Sam Hill's Mega and he doesn't run the stock short pins. His pedal pins are massive and scary.
    WillWorkForTrail
    Jun 2012
    Quote Originally Posted by jacksonlui View Post
    Nothing to do with anti-squat. It's about being able to let your legs stabilize on the pedals a little better because they're turning slower for the same ground speed. I discovered this was a thing for me switching between my geared bike and my single speed on flats.
    Oct 2018
    i ride flats only...for AM/DH and XC/trail biking. i'll get a good shin wack about once every 6 months at the most but i ride flats on everything and run Vans shoes. the waffle pattern is like glue to flat pins.
    It sounds like you understand the fundamentals, it's just a matter of time to dial it all in. Regardless of technique and experience, you can get bounced, or worse blow off in the rough. Pedal/shoe combo is huge. Longer pins will make any pedal better in the rough. As far as shoes go, I've strayed from 5.10 twice and found traction was perfect 90% of the time then all of a sudden in the rough, or in a g out I nearly blew off my pedals a few times.
    5.10 S1 rubber has been the standard since the early 2000's for a reason. No company has been able to match their compounds. I'm not a 5.10 fan boy, I've wanted alternatives to their over priced and sometimes less than durable shoes but they don't exist.
    Quote Originally Posted by mannyfnz View Post
    That's the case with every flat shoe it seems. Every flat shoe review reads the same: traction is great but not 5.10 sticky.
    Well, I believe the GR7s are not in the exact same level as the 510s in absolute stickiness.
    My problem with flats is not the shoe slipping from the pedal, is more like the pedal running away from me with the bike's movement. Sometimes it's hard to keep the body english at the same rhythm as the trail
    Aug 2015
    I think getting good flat pedals is important. Ive initially gone with light weight pedals but in the end after a lot of money through trial and error, I'd rather go with a heavier pedal which feels good. Something like a oneup, tmac, vault, etc.. a good shoe is only part of the equation.
    Reputation: GearTech's Avatar
    10+ years ago I was really into the DH/Freeride scene and only rode flats. Then I moved far enough away from good DH trails to force a switch to more XC/Trail riding. I switched to clipless then for the added power. It took me awhile to get used to clipless.
    I've moved again about 2 years ago and have started riding more aggressive trails again. I decided to try flats again (oneup AL pedals and 5.10 freerider contacts). Man was I surprised how detached from the bike I had become with clipless. It took me a good month of 3 rides per week to get fully comfortable on flats again but now I feel much more connected to the bike. It takes time and practice.
    Both types have their pros and cons. Like you I feel better in corners on flats because i also twist my feed and legs which did cause unwanted unclipping. If I'm really hauling the mail through the super chunder I still get a little bouncing off the pedals but that's happening less and less now.
    Did some rig worthy fast chunk last night. Infact I was the only rider not on a rig. There are some shutes that are full on matted with leg thickness roots for 100m or so. I discovered on those shutes that are likely to bounce a foot off I used quite a bit of heel down technique.
    So much so that my heels of my feet would occasionally tag the roots. I didn't have any foot bouncing issues.
    Try some more heel down.
    Reputation: rynomx785's Avatar
    Jul 2018
    I would say that means that you just need to spend some more time getting used to riding flats.
    Rides all the bikes!
    Reputation: Sidewalk's Avatar
    May 2015
    Personal guess, I think along with the heels thing, you are also tensing up too much. Your legs are the biggest source of suspension. If they are too tense, it is like running too much spring, you just can't use all the suspension. Relax more and flow with it.
    Quote Originally Posted by plummet View Post
    I agree with this.
    You obviously need to work on your technique still with flats. Pick the pedal system you are more comfortable with for your race.
    I personally ride flats on my enduro bike that I prefer big chunk on, I RARELY lose bite on the pedals (510's and Chesters). But everything else I have I am clipped in to.
    J:
    Reputation: Deerhill's Avatar
    Dec 2009
    Sounds like you want @half inch less reach..& 510freerider soles, nothing cheaper
    video=youtube;][/video]...
    Jan 2018
    I'm 47 and have ridden bmx from a young age, racing and street.
    And mtb's for the last 25, i've never tried clips, and so can't comment on there benefits im afraid.
    But flats are just something i've grown up with, so for me climbing, jumping, downhill or xc doesn't make any difference.
    Ive seen in bmx racing the very young kids, the under 10's that clip in. That pretty much can't even preform a simple bunnyhop because there so used to being clipped in. And can't get the technique of doing it in flats.
    So i think a lot of the problems today are kids/adults see other people clipped in, and think "i need to be as well". When they don't, and most would actually benefit from learning proper technique before moving onto clips if they choose.
    Flats are just pure, and you get the satisfaction of knowing what ever you do you've done it, not just got through by the skin of your teeth by being attached too your bike.
    So for me 5.10 impact pros teamed with Sam Hill Nukeproof pedals, trusted enough combo for me to enter a EWS qualifying event this weekend. And not think twice about my feet.
    So practice practice practice.
    Sorry for a bit of a rant.
    Quote Originally Posted by Roba1 View Post
    I agree that good flat riding ability is a skill worth learning
    There is also satisfaction charging hard on clips too. Infact you have to be more committed and more skilled on spd's to charge technical chunk as fast as flats. Flats do not require full commitment to the corner without dabbing. At any stage you can dab and correct an error. Spd's have a delay clipping out and in so when you hit that feature at full pace you are fully committed.
    Its the reason op can go faster on flats he isnt committing fully on his spd's.
    Saying that flats are pure and guys using spds just got through because they wore spd's shows a bit of ignorance to be honest.
    Aug 2015
    After trying so many different types of flat pedals, initially going for the lighter ones, i can't seem to find anything better feeling than the tmacs. It has a real concave feel. It provides more confidence and a good platform for your feet. The pins arent thin and i like that they arent too sticky. It lets you adjust your foot position but doesnt lack traction with my 510. Its definitely worth the extra 100 grams. Ive stopped counting grams on saddles and pedals and grips.
    So today, my flat pedal shoes were not dry yet from the last ride.
    I decided to put on the SPDs (Saints) for my 35km commuting/training loop.
    It was enough to make my mind. It's incredible how much slower I am climbing with the clipless pedals, flats just feel so much more natural and comfortable to put the power down.
    Also, my dreaded lowerback pain of which I was free since switching to flats came back today.
    I found myself missing the flats for the whole ride.
    I realize now, for me, I prefer to be on flats which are better in 80% or so of situations and just work to improve the remaining 20%
    Aug 2015
    U should be faster in your spd's. You can pull up on tech climbs.
    Reputation: Gman086's Avatar
    I can't believe no one has mentioned foot position! On spd's you clip in with the ball of your foot over the pedal spindle. On flats that is a recipe for feet coming off in rough sections. I rode clipless for about 15 years before going to flats. My shins were getting pretty chewed up until a BMX buddy asked why in the hell my feet weren't more centered on the flat pedals... LOL, no problems since.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Oct 2015
    Quote Originally Posted by Gman086 View Post
    Have FUN!
    G MAN
    This
    I have Flat Pedal shame.
    Reputation: Thustlewhumber's Avatar
    Life is easy. Figure out the price of whatever it is you want to do, then pay that price.
    Have FUN!
    G MAN
    I have been riding clipless pedals since they came out decades ago, used them for XC/DH/Enduro, everything.
    BUT, in August, for the first time, I found a good reason to dump them. I cased a jump so hard at Winter Park that the heel of my rear foot was forced down so far by the landing that I suffered a severe high ankle sprain. It still hasn't healed completely (I'm 58, so things take a long time to heal).
    Of course when I clipped in, the ball of my foot was over the pedal axle, I have now moved the cleats on my shoes as far back as possible, but there is no way to get the middle of your foot over the axle with normal clipless pedals and shoes.
    I don't know if this old dog can learn how to ride on flats. I'm actually thinking about modding a pair of shoes to put the cleat under the center of my foot, and seeing how well that works.
    Dec 2013
    You can make the switch to flats. I did it at 63.
    What, me worry?
    You also pull up with flat pedals, but in a sort of "scraping" motion.
    I find this feels much more natural than having my feet attached to the pedals. Pushing the pedal down on the big platform and pins feels much more like running or doing a squat rather then stepping on a bearing.
    But this is strictly personal
    Reputation: jupiter58's Avatar
    Jan 2016
    Interesting subject. I will stay clipless since they are perfect for my type of riding.....not very aggressive at my age with 13 screws holding my foot and lower back together. True that vast majority of downhill pros use clipless?
    Quote Originally Posted by jupiter58 View Post
    Most of them are playing the game of marginal gains, would likely be only marginally slower with flats, but that edge is relevant in the context of 0,1s
    Yep. Every style of bicycle racing is dominated by clips. Occasionally there are anomolies like Sam Hill. The fact is clips are faster when you commit fully.
    Have FUN!
    G MAN
    Great point. Centering your foot over a platform pedal also has the effect of your foot flexing over the pedal a little and helping lock the shoes onto the pins better.
    I began "centering" my feet over the pedal axle as I started jumping and hucking bigger and bigger drops years ago. Occasionally in freeride/DH you misjudge a landing and land HARD, or you case a landing. If you do that in clipless pedals or have the balls of your feet over the axle, you're going to tear your Achilles tendon or break your ankle.
    With my clipless shoes, I've got the cleats set as far back on the shoes as possible, but it's still not enough to make me comfortable doing big jumps and drops.
    With my feet centered over the axles, I can take a massive hit and my ankles are fine.
    Bikes belong in Wilderness areas.:)
    Jul 2018
    Quote Originally Posted by Thustlewhumber View Post
    "By switching from clipless pedals to flat pedals and following this program, you will improve your riding skills more than with any other method I know of - though not without some challenge and perhaps frustration.
    Riding with flat pedals reveals inefficiencies in your riding technique and forces you to learn and relearn skills in the most effective way. Many skills developed while on clipless pedals are compromised and therefore very limiting for long term skill progression. Our bike and body need to move as one cohesive and connected unit, and flat pedals inspire this.
    This integrated movement is also related to style - riders who have spent time developing their skills on flat pedals simply look good when mountain biking!
    Iím not trying to convert you into a die-hard flat pedal rider however, clipless pedals do have benefits too. Though if you havenít paid your dues on flats, youíre missing out on some major mountain biking benefits! After this challenge you can then translate these skills and style back to your clipless pedalsÖ or continue on with your feet free.
    This course provides enough structure, instruction, drills, theory, and support so that you can gain the incredible benefits that flat pedals give, which requires a dozen rides!
    Ride ON!
    Ryan Leech
    Reputation: s0ckeyeus's Avatar
    When I rode clipless, I tended to let just my legs/feet go loose over rough stuff, which works OK when your pedals are fastening you to the bike but not so well when they're not. Staying centered on the bike with all your weight in your feet and pumping the terrain tends to alleviate this and can actually gain some speed when you get it right.
    And as was mentioned above, sometimes the best way isn't through but over. If you pump the big shapes you can glide over a lot of the other chunk that would normally slow you down. Jumping over stuff is also a good option sometimes.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    yes they do. but their using a combo platform/SPD pedal so having the platform could be insurance or it allows them to use both features on different sections.
    NWS
    NWS is offline
    Jun 2010
    Quote Originally Posted by cookieMonster View Post
    I started shifting my foot forward for all of the same reasons, and liked it, but wasn't quite committed to it. Then one of my pedals lost a bearing I switched to these...
    https://pedalinginnovations.com/
    ...and now I'm committed. They're huge, so they look funny, but they're perfect.
    Reputation: hairymuffin's Avatar
    Nov 2018
    For shoes, I like the specialized 2fo. Never had 510ís to compare, but the 2fo is dialed
    Aug 2015
    I have both 2fo and 510. 510 is a little bit stickier but the 2fo sheds water much better. Both are great shoes.
    Aug 2015
    Anyone compare the tmac to the new anvl3 pedals?
    https://www.jensonusa.com/Kona-Wah-Wah-Plastic-Pedals
    Here's a bigger composite pedal at a good price.
    Keep on Rockin...
    Nov 2003
    Quote Originally Posted by rynomx785 View Post
    Iím not trying to convert you into a die-hard flat pedal rider however, clipless pedals do have benefits too. Though if you havenít paid your dues on flats, youíre missing out on some major mountain biking benefits! After this challenge you can then translate these skills and style back to your clipless pedalsÖ or continue on with your feet....
    ...Ride ON!
    Ryan Leech
    Very true. Great advice.
    A clippy rider spending at least a dozen rides on flats on techy trails will be forced to really clean up his/her technique.
  67. #67
    change is good
    Sep 2004
    A skills coach recommended that I switch to flats. He said it would take 3 months to acclimate and he was right. The biggest issue I had was bringing the rear pedal up when trying to ride up ledges.
    I feel more comfy going down steeps. Learned that I i my weight too far rearward, but I suspect I could of tuned out that bad habit with clipless
    Big feet require big pedals. Now thereís a good selection out. However, I lost clearance in chutes.
    I have less foot and knee pain.
    Not a clipless hater, will continue to use on road bikes. It takes a big commitment to change to flats and obviously there are extremely good riders rocking with clipless.
    Sent from my iPad using Tapatalk Pro
  68. #68
    Jul 2018
    Quote Originally Posted by Miker J View Post
    That is what I was getting at originally and I got harped on for saying that flats took proper form.
  69. #69
    379172
    Guest
    I didn't like flats until I tried 510 shoes... big, big difference for me.
  70. #70
    Reputation: clintj's Avatar
    Nov 2018
    To the OP, I'm in the same boat. Or was, anyway. I switched to flats beginning of the season, and there's totally a learning curve. I had to learn proper foot technique, when to go heel up vs heel down, and even had a couple of times where reflex kicked in and I tried to pivot a foot to release when stopping. Losing a pedal on the upstroke because I was used to being able to pedal full circle cost me some blood, too.
    Things that helped me:
    Session small, easy rock gardens, concentrating on riding heavy feet/light hands and letting my legs help float the bike over. Let the knees and hips work. I did end up quickening rebound on my bike a click or two to help keep good ground contact.
    Session riding up curbs, emphasis on going toe down to help lift the rear wheel over.
    Session American bunny hops. I used the English bunny hop for years because, well, clipless. That was a hard one to relearn, but has saved my butt countless times on drops and jumps. I ended up wearing hockey shin guards for this after a couple of Band-Aid moments.
    It took most of this season, but I've gone from being a bit of a spaz on flats to ripping bike park stuff and riding Moab with confidence.
    The right shoes are a must. I'm using 510 Freeriders and Deity Black Kat pedals.
    Sent from my Pixel 2 using Tapatalk
  71. #71
    heel down
  72. #72
    Dec 2018
    relatively new rider, learning on flats, and loving it
    I ride FBM N!ce nylon pedals, that don't exactly have very good pins (just nylon protrusions). I also ride on running shoes, so that might not help things much. I have nothing else to compare to, other than walking shoes and restaurant quality boots (those boots really stuck like glue on everything they came in contact with, other than loose on hardpack).
    TBH, I enjoy riding with non-mtb kit, because it makes me really have to learn how to keep myself planted on the bike, but remain light. I've only been riding a MTB off-road about 7 months now, and am quickly approaching a skill level 7, and a fitness level 5 according to Sacred Rides:
    https://sacredrides.com/skill-and-fitness-ratings
    If you're curious as to what bike I ride, it is posted here: https://forums.mtbr.com/all-mountain...l#post13919830
    I should note that I have replaced every non-frame component on that bike (including rear shock), minus the front wheel (hub, rim, tire, 9mm skewer), headset, rear rim, seatpost, and saddle. Stock, it is an atrocious ride, like a super short travel hardtail, and noise central.
  73. #73
    Rider at the season opening enduro in N England.
    Zoom in on the pedals and shoes.
  74. #74
    Im 35. I've been riding since I was a little kid racing bmx.
    I dont think I care about technique and skillbuilding anymore. It seems like nearly every thread breaks down like everything is a training ride, like everything is race prep or "practice".
    Sure, I could work on my foot position and heels down and etc etc, or just stay on SPD's and have a blast. I know other people feel the same way but with flats instead of spd and they shouldnt change either.
    If you really are on a hardcore training ride and you do have that big event coming up... seems like those guys who take it seriously are on spds anyway!
  75. #75
    Not really getting all the love for flats. Grew up riding them but been in clips for years. I don't have a problem if you want to ride flats but I don't get the theme of riding in clips means you aren't as skilled or as developed. I guess if you never started or learned on flats there could be something to that, ie you've never learned some techniques. To me it seems like you can do everything in clips that you can do on flats but in addition you also have the option of more control over your bike. I disagree with this whole idea that using the clips to pull the bike upwards is bad form. Being attached to the bike gives you more not less methods to manipulate the bike. And of course more power/efficiency.
    I see the primary advantages to flats being confidence to dab in the gnar and being able to drop a foot in tight high speed turns and loose terrain. Or if you are doing can-cans and one footers etc. LOL. I would love to be able to do this on certain types of turns but am not willing to give up all the advantages of clips.
  76. #76
    Quote Originally Posted by Preston67 View Post
    I agree that a person's skill is not tied to their choice of pedals, but people who bunny hop by yanking up on their pedals are not being more powerful or efficient. Being attached to your bike does have certain advantages, but that connection can also stunt a person's development as a rider. I know it did mine.
  77. #77
    Jul 2017
    The issue is, pulling the bike up isn't what adds height to the bunny hop. That's not the hard part, that's just a preliminary skill.
  78. #78
    This...The flat pedal love seems to go hand in hand with new trends like super long reach and 30mm stems, etc. Not to say these things aren't better, but they're marketable as mt. bikes become more "capable". Just for context I ride flat pedals on my all mountain bike (if that's still a thing) and on my bmx bike (poorly). But I also ride clips on my xc, cx and road bikes and sometimes even on my AM bike (gasp!) and i think the advantages/disadvantages are overblown.
    For the OP, I currently ride the GR7's and have previously owned 510's and even Tevas. Sure the 510's are definitely the grippiest, but they're all pretty good and provide plenty of grip. So i suspect it's a little bit of technique and a little bit of just getting used to the feel of the flats in rough terrain.
  79. #79
    Jul 2018
    I have always been pretty firmly in flats camp but after riding Sedona for the first time and doing my best to keep up with riders that are stronger than me on the technical climb sections, I am considering a set of clipless pedals to add to the stable. I have preached for a long time that with proper form that clipless isn't necessary and I still believe that but, when my heart rate is above 170 and my legs feel like wet noodles, proper form is nowhere to be found. LOL
  80. #80
    I hate to start a 2nd debate, but for full on tech climbing clips are a big advantage. As in technique not just because more efficient cardio wise.
    Again, IMO.
  81. #81
    Oct 2018
    I love flat petals but...... I don't know why. haha
    Kidding. I do enjoy them. I have clipless for road bike but I don't have confidence with MTB clips for the stupid crap I'm always doing. My nickname should be 'dab'.
    Generally I don't leg out, but I wheelie and am not super good at it. I like to do silly tricks but am not good at it.
    When I'm actually riding though, my feet seem to stay on the pedals just fine through all conditions.
    I'm not here to say that flats are best or safe or fast or anything really. I haven't MTB'd on clips so really I can't say why flats are better (for me).
    My take on clips and my mental capacity is "I guess clips would be good if I felt like having a boring ride."
    I've done miles and miles of non-techy stuff that I could experiment with, just no desire because I have zero issues on flats.
  82. #82
    Jul 2017
    I started on flat pedals in the 90s on a bmx bike...I knew one day it would be trendy in mtb and I had to stay ahead.
  83. #83
    Reputation: targnik's Avatar
    Jan 2014
    Love the xxxx vs xxxx debate...
    True, most EWS riders run clipless... but, a lot of them have eaten sh!t & ended up broken/out of the game for extended periods.
    How many times has Sam eaten sh!t & broken himself!? (in EWS)
    Sure, I think he's had one or two crashes... but, the bike hasn't dragged him to his doom i.e. he can step off & salvage the most important bit - himself.
    Personally I ride both... If it's going to be a slog fest w/ the main focus being on turning the cranks - I'll go clipless every time.
    If it's super gnarly & bailing is a high probability, I'll defer to flats.
    5.10's plus pins w/ spacers removed & you're golden.
    Feet further forward & heel down... & shred it!!
    NB, you do get more pedal strikes on flats... just sayin'
    'Born to ride!'
    "Mountain biking: the under-rated and drug-free antidepressant"
  84. #84
    That's totally what im saying! A few hours into a ride, Im trying to save energy, not be at peak form and all that. I can fly into a rock garden and there's really no form or foot technique to worry about, im just glued in.
  85. #85
    Nov 2018
    Quote Originally Posted by targnik View Post
    Roger that 200%.
    I ride both, but when going into something unknown - I usually use flats, when going over something I've already ridden and know - I usually go clip-less. Crashed on both
  86. #86
    Jan 2014
    Quote Originally Posted by borisotto View Post
    Roger that 200%.
    Quick release pedals...?? (+Batman shoes)
    You might be onto something!
    'Born to ride!'
  87. #87
    Nov 2018
    I use SPD cleats with side release only, ones you are talking about (if I understood you correctly) do not help on long steep climbs when you not only push pedal down, but also pull another one up. Not pure DH stuff, but I like when things do get tough.
    'Born to ride!'
    And to ski too ;-P
  88. #88
    Mar 2018
    I really want to know if the average rider is any faster on anything other the smoothest XC trails on clipless then flats.
    Ragley Big Wig, Sunday Soundwave (BMX), 91 Schwinn High Plain (single speed "gravel" bike), Nashbar CXSS (on trainer)
  89. #89
    Quote Originally Posted by 93EXCivic View Post
    It's funny, clipless seems to have benefits on two opposing sides of the riding spectrum. They help with pedaling efficiency by keep feet fixed and giving a rigid attachment from shoe to pedal (the big XC advantage), but they also help a lot in maintaining bike control when riding at super high speed through super rough terrain (the big DH advantage). A lot of pro riders on the gravity side of things actually do the majority of their training on flats to support proper riding form, and then will switch to clips for racing. Ultimately, the decision to race in flats vs. clips is all about which you're comfortable going faster with.
    I'm a mountain bike instructor and we require that all students use flats in class. There are often a couple riders who throw a bit of a fit, or blame difficulties at the beginning of class on not being in their clips, but in reality, clips just mask bad habits for a lot of riders. Making sure heels are down and pedal axle is just behind the ball of your foot are key tips for keep flats locked to your shoes, but there are bigger lessons to be learned around using your legs to control the bike, dialing in proper cornering form, and using your legs as suspension to ride faster and with more control.
    If you're having trouble with flats, watch some YouTube videos from Fluidride and GMBN. There are some good principles in there that can help a lot. If you're still struggling, I'd recommend a class with a local instructor who teaches on flats - there's a ton to learn riding flats, and all of it will benefit your on-trail riding form regardless of which type of pedals you choose to ride most of the time.
  90. #90
    Oct 2018
    I am pretty confident in saying I would not be faster on clips.
    I once left my house in a hurry to meet my road bike friends. In my rush I forgot the shoes and helmet. I rode my SPD MTB pedals with my beat up running shoes. Aside from slipping a foot of the pedal just a few times, I rode just the same as if I were connected. It was an easy ride on a paved bike path but was 20 miles.
    Clarification, the road bike has MTB pedals installed.
    I'd love to see the scientific proof that clips are this efficient wonder of the world.
    Nobody can ever seem to explain why it is 'efficient'. Yes, people say "because of the pull" but I could make up something that sounds convincing too with nothing to back it up and get people to believe.
    I'm not knocking clipless or the technology. They are neat. I enjoy them on my road bike. But the whole "efficient' thing is lost on me.
  91. #91
    I'm not going to do the search for you but they've done scientific measurements and showed that the "average" expert cyclist is more efficient clipped in - ie more watts to the wheel per period of time. Actually maybe I will go do that search as I'm curious what type of percentages we're talking about. But in the world of cycling even 1% would be huge.
  92. #92
    Formerly of Kent
    Reputation: Le Duke's Avatar
    They are faster on rough trails, too. Imagine that.
    Death from Below.
  93. #93
    Apr 2018
    Faster on clipless funner on flats.
  94. #94
    Jul 2018
    Quote Originally Posted by karthur View Post
    *more fun
    For the sake of being argumentative like a lot of people are when clipless vs. flats comes up.
  95. #95
    Aug 2015
    This topic comes up every year.
  96. #96
    I do not seem to be faster on clipless according to Strava. After riding platforms for over 10 yrs, I bought a road bike and some SPD MTB pedals and shoes thinking I could experiment with them on the MTB too, hoping that I would be a little faster with them. For me, the only advantage was in fast chunky sections where my foot might occasionally slip some with platforms - it never slips off but just enough where I have to readjust. But, we don't have prolonged sections like that on trails I ride and the added confidence of platforms in other places made up for the small benefit of clipless. After maybe 10 MTB rides with clipless, I pretty much left them on the road bike, only going back to the clipless if I'm having an issue with my flat pedals/shoes.
    Sent from my SM-G955U1 using Tapatalk
  97. #97
    Quote Originally Posted by Le Duke View Post
    In my experience they are only faster on rough trails. And then, it still depends on conditions. If it's steep, fall-line DH, then it doesn't matter, because you're not pedaling through it. "Slipping" off the pedals (on dual suspension bikes at least) only happens to people who are not used to flats and/or using sub-par shoes and pins.
    The advantage clips have on really technical terrain is not an obvious one. They are smaller, so you can get a few more pedal strokes in without hitting them on rocks and roots. It's not a huge difference.
    Also, Sam Hill.
  98. #98
    Quote Originally Posted by tarheel03 View Post
    Same. I've compared the two head to head on the same trails that I ride all the time. I haven't done truly scientific tests such as measuring watts, etc. -- but just giving it 110% effort on segments, the only difference being flats vs. clipless, it's a crapshoot. I've had many a time where my flat pedal time was faster than my clipless time. But sometimes I'm faster on clipless too. At the end of the day, it really doesn't make any difference. This is mostly on smooth trails, but with some tech.
    All of my KOMs on downhill segments were done with platform pedals.
  99. #99
    Nov 2018
    Quote Originally Posted by Forest Rider View Post
    I can clear some long exhausting gravel/tech climbs clipless because on less steeper sections I can switch to 'pull' mechanics and get some rest before attacking much steeper sections with 'push' pedalling. Have never been able to clear these on flats. Not too relevant to DH or regular XC trail riding I guess.
  100. #100
    Jan 2019
    I enjoy flats more. And I feel just as fast. Mostly. I feel much more solid in corners on flats. I also have a different max seat height and riding style with flats. Lower seat, more centered pedal, lower gear. How different is your seat position when switching?
  101. #101
    ^^^I find that I can have a significantly higher seat with clips than platforms. I mean, I still prefer it lower when descending technical terrain, but it doesnít have to be as low.
    I feel like the main adaptation one must make when riding flats is to keep your center of gravity lower and in more of a crouched, athletic stance. That way, no matter what you encounter on the trail, your arms and legs can maintain that connection to the pedals. Thatís hard to accomplish when your seat is in the way, and riding with your hips behind the saddle because itís too high is poor form.
    Clipped in, the seat can be higher because even if your body doesnít absorb a hit fully, and the seat bottoms out on your crotch, the pedals and bike are still going to come with your feet.
  102. #102
    Oct 2018
    I've noticed I need to change my seat height on the road bike depending n which shoes I wear. Obviously one of my clipless shoes is taller than the other.
    This has noting to do with flats, I am a flat rider on MTB whole-heatedly.
    But to answer the question about seat height, I think it has more to do with the shoe and pedal height than it does with just clipless vs. flat.
  103. #103
    Several months have passed and I guess I can now firmly say I'm a flat pedal rider, if such thing exists.
    To make long story short:
    Climbing:
    I know it sounds weird, but I really prefer to power up climbs on flats Vs on clips. Stepping and pushing on the large platform feels more natural, more like a squat.
    I can also keep climbing for longer periods and stay fresh and comfortable. This is likely related to the fact that with clipless pedals I end up doing movements and efforts I'm not supposed to, resulting in knee, ankle and lower back pain.
    Some argue about the efficiency of clipless, but if you look into the actual studies you'll know this is a tricky area. Ok, it's clear a stand up power sprint over a rock garden will be better clipped in, but in normal pedaling conditions this is not so obvious. You can also "round" your pedal stroke with a sort of scraping motion, which I use not for extra power but to smooth the torque delivery on low traction climbs
    Downhill:
    There are two specific situations where I feel better with clipless.
    One is high speed rock gardens and such. I'm way better now than I was when started the thread, much more relaxed and less stressed about weighting my feet. However I'm still a little faster charging through the really rough stuff clipped in. This is not such a bad thing, as it keeps me realistic about my skills and makes me stay within my capabilities envelope. But I'm getting better at it.
    The other situation is when I do a high speed first run of certain trails with lots of surprise 3 or 4' drops. When you get out of flow with the trail you end up not doing the proper stance and preload before getting air it's easy to feel the bike getting away from you.
    Also getting better at it by the week.
    Every where else I prefer to descend on flats. I'm way more relaxed, no surprise unclips, easy to bail and try new stuff every ride. If I was a pro I'd be much more competent and confident to commit as much with clipless as with flats, so I'd be mostly certainly clipped in. But I'm no Pro, and end up being faster and more commited on flats.
    About seat height, I'm about 15mm lower with Nukeproof Horizons SH and GR7s than with Saint SPDs and AM7 shoes
  104. #104
    Jan 2005
    Climbing:
    Should try an oval chainring. I just switched both of my bikes over to oval rings and really liking the way the oval smooths out the power on climbs. I am finding my self in a high gear climbing and climbing in same gear seems easier. Large flats and a oval chainring are a nice match for climbing.
  105. #105
    Actually I'm already using an oval chainring, might be a reason why I enjoy climbing
  106. #106
    I rode flats tonight. 500m of vertical descent in gnarly as natural mountain trail.
    Sunday i rode clips round the local bike park
    Saturday was flats up the mountain again.
    Last Tuesday, clips in the bike park again,
    Ahhh. Both pedal types suited the riding I was doing.
    I guess i'm just a pedal slut that swings both ways.
  107. #107
    Oct 2016
    I've been on flat pedals for a few months now since I'm concentrating on improving my cornering (especially flat and loose-over-hard). As my speeds increase and I try new techniques, it's been really helpful. One thing I've noticed is I do like how SPDs just snap me into my "ideal" spot when I put my foot down, whereas sometimes on flat pedals, I need to make adjustments mid-pedalling.
    Has anyone here tried the crank bros mallet e pedals? From what I'm reading, these seem like they could be a best of both worlds pedal. Good amount of float, clips aren't as tight so making a dab is easier, also have a decent amount of control even when the cleat isn't engaged yet. Thoughts?
  108. #108
    Quote Originally Posted by jasonp22 View Post
    I've always experienced the same thing. Clips are easier to post a foot in the corners and get back to the perfect position. I never ran the E mallets but ran mallets dating back to the first models in the early 2000's. Personally I don't recommend any of the mallets because the clip mechanism is more prone to releasing when you don't want. I would go with one of the other platform clips. I always liked Time, and shimano, though I will give the nod to mallets when talking about platform feel which still falls woefully short of flats.
  109. #109
    Aug 2015
    Tmac pedals has a really good platform. Well worth the weight. Interested to try the Anvl3 tilts as well which is quite a bit cheaper. Platform feel gives you a bit more confidence as well.
  110. #110
    Reputation: RS VR6's Avatar
    I've run the Mallets (non E) before...and what I don't like are the pins. One of the things I like about clip in pedals is the float. With the pins...the sole of my shoes keep catching...and I get reduced amounts float. I turned my pins all the way in. I use the XT trail now. What I've found is that if you use a shoe with a fairly stiff sole...the "platform" of the pedal won't matter as much since the shoes will be supporting your foot.
  111. #111
    One thing I never see mentioned, which happens to be one of te few things I dislike about flats, is their durability.
    I was spoiled by years of Shimano SPD (M540) usage, no matter how hard I smacked them (lots of granite here) they stayed together as did feet retention. Flats seem to be more fragile in that regard. Today I had to redo a couple of pins for the third time in 4 months or so on my Nukeproof Horizons. Also two of the grub screw holes were completely striped and I don't plan to helicoil them or recut bigger threads. Never had the need to touch my M540s except for an annual bearing adjustment.
    I'm curious about the new Shimano Saint M828 flat pedals. Shimano bearings and seals and the pins, while not being bolt through, have huge threads
  112. #112
    Feb 2019
    Please help me identify these pedals? Thank you!
    Hello, is it possible for you to help identify these pedals? They worked wonderful for 10 years till I broke one yesterday
    Attached Thumbnails Attached Thumbnails I love flat pedals, but....-img_9368.jpg
  113. #113
    Quote Originally Posted by Blackpanther310 View Post
    Hard to say, but Wellgo makes pedals that look a lot like that. Consider getting some with reusable pins so you can replace the pins when they get rounded.
  114. #114
    Jul 2018
    Finding that exact pedal will probably be a tall order.
    If you are looking for an inexpensive flat pedal with good grip, check out the One Up Components Composite pedals. Hard to beat for $50. I have tried the Deity Compounds, Chromag Synth, Raceface Chesters, and One Ups. As far as $50 pedals go, the One Ups have been my favorite with the Chesters a distant second. The One Ups have bigger platform and taller pins. They grip really well.
  115. #115
    Feb 2019
    I only started riding about a year ago. I had ridden bmxs about 20 years ago but it has been ages since I jumped on a bike.
    Anyways after two rides through some single track with some simple drops berms etc I went straight to clips. I was always intrigued about it. They helped me immensely to simply stay 'on the bike'.
    Since then I've been riding a mix of technical single tracks and fire roads and was quite happyily improving my abilities until my first black diamond. I got through it just fine but I was acutely aware of the fact I could not bail if I needed to. This got me thinking and analysing the rest of my riding.
    I honestly feel that for me the clips were holding me back. I am less inclined to test the limits of my abilities on clips, I'm less inclined to try out new skills or attack features aggressively.
    I recently decided to buy a decent set of flats and shoes to test my theory, Ive never ridden flat pedals this grippy. I agree that I had come to rely on the clips holding me down and being able to pull up on the pedals, but I suspect that jumping into clips not having built the skills on flats was probably not the best move.
    In summary, I like clips and there are a few things I miss using them, but I'm much more confident on flats which in turn allows me to try new things and attack the trail more aggressively. Strava shows that I'm no faster on clips than flats even though it sometimes feels like I need more physical effort to ride flats. I converted my cx bike to flats as well and again I can get super aggressive through turns because I'm less worried about wiping out.
    I'd say use whatever you feel confident in. For some it will be flats for some clips. I'd recommend inexperienced riders like me give flats a good try before clipping in.
  116. #116
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Recovering from foot surgery my dog said "flats", well, he was only talking about one foot, but the idea of using flats on both feet was out of the question, I was basically pedaling with only one leg for a few weeks and unable to push-against my other foot, you simply won't go anywhere with the slightest uphill. So clipless on one side and flat on the other was what I rocked for a few weeks and it was much more bearable. Still a b*tch to get up some stuff, but flats require balancing out the pedaling force by pushing on the other side and it was absolutely apparent to me for a few weeks.
  117. #117
    Always wise to listen to your dog!
  118. #118
    Quote Originally Posted by attaboy View Post
    Was thinking precisely the same.
    On the other hand, my cat generally just says "SEND IT"
  119. #119
    Feb 2019
    Thank you, brother!
  120. #120
    Feb 2019
    I took a look at the One's. I may give them a go. THanks, brother!
  121. #121
    Jun 2016
    Those look a lot to like Specialized Bennies. I had pair for a while until one of them got bent. I replaced them Chesters and haven't looked back.
  122. #122
    Aug 2013
    cookieMonster is talking about out of the saddle riding, not getting the right saddle height for pedalling.
    You can use a shorter dropper (or no dropper) much more easily when clipped in.
  123. #123
    Reputation: Rngspnr's Avatar
    Feb 2016
    I have these on both my bikes. Two years on my FS and lots of rock bashing. Still tight with no play and holding up really well.
    https://www.dmrbikes.com/Catalogue/P...lt-2/Vault-NEW
    2016 Evil Following V1
    2016 Dartmoor Primal+
  124. #124
    Reputation: Pedalon2018's Avatar
    Apr 2018
    After riding toe clips for years and switched to clipless for decades till recently. I needed to ride my fat back from where my truck was being repaired. Had to stay unclipped for several miles due to ice. So I switched to Crank Brothers Doubleshot 3. Flat with eight adjustable pins on one side, clipless on the other side. Works better than I expected. May put them on the HT when the snow goes away. Do not try the 1 or 2 models as they have no pins, just molded bumps. Crank Brothers recently updated their pedals. Needle bearings are gone replaced with a lube impregnated sleeve, more robust seals and a new end cap. They rock. Just another choice.
  125. #125
    Have it both ways...
    Years ago I drilled, tapped and pinned a set of Shimano A-530 pedals, which are SPD on one side and flat on the other. Turned the flat side into a useable MTB pedal. This helped me transition from a flats-only trail rider, mostly full rigid at the time, to a more conventional XC racer. Needed to, as I was (and am) coaching HS kids in the SoCal league.
    I found that I automatically flipped the pedals to the flat side entering the rocky, steep, exposed, technical trails -- El Prieto, Middle Sam, etc. -- mainly so I could get a foot down faster if needed.
    Now with more time riding clipless, and more time on more varied terrain, I tend to ride the clipless side way more. You can see in the photos below that I've hit the pedal in this configuration more than the other way. The clipless side really helps me at race pace, especially pushing and pulling hard out of the saddle. On long days I alternate both sides, give the knees a rest.
    The combo pedals gave me an easy way to transition to clipless, and still give really useful real-time options, so I still ride them hard. There are ready-made combo pedals out there now, but I like these -- lighter, with real pins, where you really want them.
    If you do this, make sure you use thread locker on the pins...
  126. #126
    May 2018
    Quote Originally Posted by crembz View Post
    I grew up riding and racing bmx. So much of my riding is second nature to me and so is knowing when Iím going to truly need to come off the pedal...typically a soft fast corner, dabbing or when I know a get-off is coming. I have zero problems coming out of my clips, except for the brutal pedal strike catapult...but flats wouldnít have helped. Crashes will happen. But that little twist at my ankle is also second nature. Once you donít let them hold you back, they wonít. If youíre a rider that never sees the get-offs coming, then itís probably better to stay on flats until you can. Donít get me wrong, I enjoy flats and do mix it up, but they definitely donít hold me back. I think Iím faster and more connected when clipped. For the record, I use XT with and without the platform (8020 & 8000ís). To each his/her own but getting over the apprehension with clips should be a goal, and then you can truly decide if you prefer them or not. Just my take anyway. Whatever you do, enjoy It!
  127. #127
    Little thread necromancy here, but since I'm the OP I feel entitled.
    So, a status update on my relationship with flat pedals:
    -Rock gardens and overall rough stuff - check, no more problems
    - Drops and jumps - check, no issues
    - Really really step stuff with consecutive chutes or similar - I still have some issues on very steep and rough chutes, but getting better and the flat pedals force me to maintain my composure
    - climbing - I can't generate as much torque on very rocky technical climbs as with clipless, as expected, but overall I prefer to climb on flats
    - cornering - I used to be pretty adamant about dropping my outside foot on corners, which led to some issues with the inside (up) foot being unweighted and losing traction with the pedal. I've since heard several pros stating they tend to keep the pedals level on corners and began trying the same with success
    Now, I'm having an issue I never heard anyone else having. Dropping my heels pretty deep is now instinctive and I stay that way most of the time. However the prolonged dorsiflexion of the ankles is causing me pain, specially on my left ankle after rough and fast dh rund.
    I sometimes stay sore for one or two days after the ride. I have a hard time having two shuttle days in a row.
    This alone is making me consider to go back to clipless, regretfully.
    Anyone else ever had this issue?
  128. #128
    Jul 2017
    Where is the pedal spindle in relation to your foot? If it's too far forward I think that could cause issues. The only other thing I can think of is if you're maybe constantly trying to drop your heels all the time to the point of straining.
  129. #129
    The pedal is at the only place it feels comfortable, quite centered in the foot.
    It might be that may heel drop is exaggerated, but I never felt safe if the drop is not pronounced
  130. #130
    What are you using for shoes?
  131. #131
    The same as at the beginning of the thread, Shimano GR7
  132. #132
    Aug 2015
    Maybe with 5.10's, you wont feel the need to exaggerate the heel drop.
    Sent from my SM-G973U using Tapatalk
  133. #133
    be1
    be1 is offline
    the beat goes on
    Reputation: be1's Avatar
    Sep 2013
    the late great Sheldon Brown had a similar complaint IIRC. he called it "ankling".
    https://www.sheldonbrown.com/gloss_an-z.html#ankling
  134. #134
    This^^^ Before trying out 5.10's I used to use the same heel drop tactic you describe out of fear of slipping a pedal. Now with 5.10's there is no fear and my feet are now parallel to planet earth.
    Not sure how tacky your current shoes are, but if you are experiencing any unwanted movement, give some 5.10's a whirl.
  135. #135
    Jul 2017
    I really only drop my heels coming down through really rough rock gardens and maybe roots. Otherwise they're level.
  136. #136
    Jul 2018
    I have been riding flat pedals for 30 years and don't ever even think about whether my heels are up, down, or level. Makes me glad I never went down the clipless path any further than falling over in my front yard for 20 minutes. LOL
  137. #137
    Reputation: Ze_Zaskar's Avatar
    May I add that this is all on rough natural trails, not manmade flowy ones, which might be a strong factor.
    In fact I was contemplating to get some Five Tens, looking specially at the Sam Hills
  138. #138
    Jul 2017
    Yeah, even riding DH bike park tech I'm not thinking about my heels much.
  139. #139
    You guys are tempting me to get some 5.10s. My fear is to spend a lot of money and then having to move on due to my ankle.
    The Freerider Pros look great but keep reading about durability issues. The Impact Pro and Sam Hill sound like more durable alternatives. However, my wife refuses to buy me the Pros due to how ugly she thinks they are and I'm not sure about pedaling 30 mile 4000ft gain days on the Sam Hills
  140. #140
    Professional Slacker
    Sounds like your ankles are relaxed but your knees aren't. At least not relaxed enough. Pedal type probably doesn't have anything to do with it.
    Try keeping your legs a little more supple, to allow your knees and thigh muscles to absorb more of the impacts instead of having it focused down at your ankles...which really aren't supposed to take that sort of abuse with the heel unsupported.
  141. #141
    Get some 510s. I can angle my pedals vertical and it is impossible to slip off. Use very spikey Twenty6 pedals though. They could be used as murder weapons. Still, Iíve never thought twice about slipping on them. Impossible with 510s.
  142. #142
    Quote Originally Posted by richde View Post
    Good advice
    Sent from my Armor_3 using Tapatalk
  143. #143
    Thanks, that sounds like great advice.
    It's funny how when I was riding clipless, even with more ankle leverage due to the cleat being much more forward I never got that sort of ankle pain. I guess I was more relaxed overall.
    Regarding shoes, anyone here can compare the Freerider Pros, Impact Pros and Sam Hills?
  144. #144
    Jul 2018
    I got a new pair of Freerider Pros about a month ago. They are a pretty solid shoe and I am really happy with them. Perfect balance of stiffness/support and pedal feel IMO. I started on regular Freeriders which were way too flimsy and not supportive enough and I had a pair of Ride Concepts Hellions after that. The Hellions were nice but they were a little too stiff and they started to get uncomfortable on longer rides. Only a month in I know but the Pros seem like they are built pretty well to me. Both my wife and I got a pair at the same time and the quality of hers is good too. I think like with anything on the internet, all you hear is bad stuff that happens. 5.10 sells a lot of of shoes and you don't hear about all the happy people that didn't have any issues with quality.
    If you do decide you want to go another route, the new Ride Concepts Powerline has a less stiff sole than the Hellions do. I just wasn't sure about the higher midcut design. As far as pedal grip the RCs are right there with the 5.10s in my experience.
  145. #145
    beater
    Reputation: evasive's Avatar
    Feb 2005
    I havenít tried the Freerider Pros but Iíve had Freeriders, Impacts, and Ann now on my 2nd pair of Impact Pros. I think theyíre the best compromise of weight and stiffness. Freeriders are too floppy for trail riding. My only issue with the Impact Pros is longevity. I get about 2 seasons out of a pair.
    If you want longevity, get the Impacts. You canít kill them. They just look goofy. But youíre already wearing a MTB kit, so whatís the difference.
  146. #146
    Aug 2015
    The newer freerider pros seem to be an improvement over their older versions where the sole would fall apart. The new ones last a lot longer and i havent had any issues. Expect to replace shoes every year or two as the soles will get worn. Its $150 every year or two, not that bad.
  147. #147
    Thanks all
    And between the Impact Pro and the Sam Hill?
  148. #148
    Quote Originally Posted by evasive View Post
    The new Adidas era Impacts are not the same shoe as the early 2000's era Impact High/Low shoes. The new version isn't nearly as well made...unfortunately.
    See post #4 at this link: https://forums.mtbr.com/apparel-prot...w-1099813.html
    Safe riding,
    Vik
    www.vikapproved.com
  149. #149
    beater
    Feb 2005
    Quote Originally Posted by vikb View Post
    Thatís a shame. I rode mine for five 120+ day seasons, and only replaced them because I wanted a change. I still have them at my office as a lunch ride contingency. They outlived a couple bikes.
  150. #150
    Jul 2017
    I like the Freerider Pro's but I could see how they could be too stiff for some. I've gotten two seasons out of them so far which is pretty good considering my basketball shoes didn't even last that long. My Fivetens usually go bad by wearing a hole in the rubber sole. I think that's the best you can hope for given their grip.
  151. #151
    Yes it is too bad. Mine lasted a long long time as well. A bulky heavy shoe, but protective and durable. It's possible the Sam Hill version is the same as the old Impacts, but I don't know. I'd want to check them out in person to be sure.
    I've heard the 5.10 Impact Pros [totally new shoe] are decent. I haven't tried a pair yet, but I probably will one of these days when I find some on sale. Up here in Canada they are $$$$$$$$.
    Safe riding,
    Vik
    www.vikapproved.com
  152. #152
    Feb 2019
    I wear Ride Concept shoes. They are awesome shoes with lots of grip.
    They are in Truckee, CA so they are an American company, not a big company from Germany (5.10's/Adidas) and a lot of the employees used to work at 5.10 (when the shoes were the best) before they were bought out by Adidas (have gone downhill since) so they know what they are doing.
  153. #153
    Reputation: vikb's Avatar
    To date nobody has rubber as sticky as 5.10 if that is the OP's top priority. There are some user reviews of RC shoes in the apparel section [I've got a pair as well as 5.10s].
    Safe riding,
    Vik
    www.vikapproved.com
  154. #154
    Thinking about riding.
    Dec 2014
    Ha!
    Here it goes... In the really rough I lock my feet in.
    Heel down toe up on lead foot. Back foot has the toe slightly down, heel slightly up.
    By pushing your feet apart you can do what you want with the bike. Imagine a big pipe standing on end. Stick your hands inside. Now grip and pick up the pipe by pushing hands apart.
    Maybe speed up the rebound.
    Give it time.
    Overall, I still prefer clips and I think they are faster.
    As someone in pretty much the OP's exact position (ten+ years clipless, switched to flat a couple months ago, learned drops and jumps right away, chunk took longer) I think this is the best answer in here. I definitely feel like I'm 'pulling tension' between the two pedals to help stay on.
  155. #155
    So today, instead of bitching about it online, I went for some testing on the ground. Installed the Saint SPDs and went for a close by training loop. 10 miles, quite steep, passes through a very fun and technical Olympic style XC track and a really step and rough mini DH track.
    Guess what... Still got ankle pain. Seems like the problem is not the pedals
  156. #156
    Quote Originally Posted by Ze_Zaskar View Post
    Some good stuff in this thread, drew me to read most of it, thx for bringing it back to life.
    2 thoughts I had, I saw you still had pain on spd's, thinking ankle pain, have you checked your alignment side to side? I know in big vert, that can be an issue.
    I went back to clips this summer due to pain as well, after mixing it up, mostly riding flats for a handful of years. Long climbing days were tweaking my knee, went back to clips and it was gone...!
    Also, your assessment of pros/cons matches mine, besides the knee issue, th only place I prefered clips over flats for my riding is techy difficult climbs, the extra clearance and power of clips wins for sure, but if you have to come off, easier to step out w/ flats of course.
    speaking of that, on this skills thing, I think way to much emphasis is put on this last point, escaping. Just like all the skills w/ flats to ride well and fast, getting out of clips is a skill that becomes automatic as well. Only time people who have that skill dialed struggle to get out is if the cleat or pedal is worn/tweaked imo.
    I would get a good pair of 5 10s too, and be able to mix it up.
    Good luck with that ankle!
  157. #157
    So I ended up being offered a pair of Five Ten Impact Sam Hills by Christmas.
    After 5 rides over the last 2 weeks, my comments:
    - they run small, like a full size smaller than Shimanos, which are already on the small side, had to jump to size 12
    - they are very big relative to normal trainers, look and feel much more akin to approach shoes. Given they are to be used on the hills rather than the gym or the mall, this is fine for me
    - out of the box they are super stiff, even for walking. Break in took about 2 rides and now they are miles better than any other MTB shoe I ever tried for walking on the steps and rocks
    - now the important part, they are indeed ridiculously grippy. I never imagined how much more grip they would have vs the Shimano GR7s. Combined with the Horizon pedals, I don't have to think about my feet anymore, they are just stuck there as if in SPDs.
    Rode a very rocky, rough, fast track yesterday, totally forgot about my feet, but still had all the freedom and options provided by flat pedals. Blew my mind.
    Big thanks to everyone who recommended me the Five Tens
  158. #158
    Oct 2018
    Question for you regarding sizing.
    What are the metric sizes listed for the two pair of shoes.
    I've found shoes vary in size too in U.S. sizing.
    A shop sales person suggested to go by the metric sizing as they tend to be more consistently sized among brands.
    Each of the manufacturers using a differing conversion table to display the U.S. sizing, but builds a show on the metric such as, each shoe could be size 45 but they convert it to 10.5 or 11 (or whatever the equivalent should be-I don't have shoes in front of me to determine).
    This is somewhat evidend when purchases shoes online as there are sizing charts. Look at one size chart vs. another and you'll see a different EU size representing the same U.S. sizing.
    I purchased a show for the girlfriend a couple years ago, shouldn't get her feet in them despite the U.S. size being same as other shoes. The metric size listed was as a different size.
  1. clydes on flat pedals / ethirtenn lg1 pedals
    By DABIGSEAT in forum Clydesdales/Tall Riders
    Last Post: 07-09-2015, 02:11 AM
  2. Replies: 34
    Last Post: 01-28-2014, 07:25 AM
  3. Replies: 7
    Last Post: 08-15-2013, 05:22 PM
  4. i wanna feel flat pedals but with some support
    By akiracornell in forum Apparel and Protection
    Last Post: 02-17-2012, 08:27 AM
  5. Flat pedals that grip but don't murder shins - do they exist?
    By surfingpl in forum General Discussion
    Last Post: 10-05-2007, 10:11 PM
Members who have read this thread: 77
