Fitting Tips Between Bikes (Calf vs. Knee Pain)- Mtbr.com
Results 1 to 8 of 8
    Reputation: ekraft84's Avatar
    Apr 2013
    Hey Guys,
    I've got a Trek ProCal and a Trek TopFuel. Both are identical models (9.9RSL's), minus of course one being a HT and the other FS.
    I had a fitting done on the HT a couple years back with good results. However now, I'm finding that on the HT - I get calf and back pain on longer rides, where on the FS - I feel great, but get knee pain on longer rides.
    I've matched saddle to crank height on both bikes. Have also matched handlebar to saddle (length) on both bikes. Same stems, same saddles, etc.
    My question - what is a better/more accurate measurement to make? While the bikes are similar, the geometry, top tube length, etc. are not the same. I'm trying to find the best way to make measurements for comfort, that I can equate/make relative to both bikes.
    Thanks.
    Reputation: minimusprime's Avatar
    Quote Originally Posted by ekraft84 View Post
    Hey Guys,
    Thanks.
    I can't answer your question as I've struggled with this in the past. I've also struggled with certain bike fit results like you have where what seemed comfortable for a 2 hour ride, wasn't comfortable for a 4 hour ride.
    A few things to consider as you work through this process:
    -FS bikes have sag you need to factor into their geo numbers. This will shorten the reach while maintaining ETT.
    -Not sure about your age, but at my age (near as makes no difference, 40) and after back surgery, hard tails are out of the question for the exact reasons you are stating. I can put power down better, I'm more efficient for sure and faster for the first 2 hours of the ride, but after that, my low back starts limiting me. All of the micro adjustments that I am making to absorb the impacts to my low back and the increased reliance on a good hip hinge that hard tails require, leaves me toast after 3+ hours. On rides over 2 hours, I'm for sure better off on a FS.
    If I had to guess, this is a combo of factors. On the HT, you have zero sag so your bar to saddle offset is going to stay consistent while just riding along. On the FS, with sag and rear suspension, your actual bar to saddle offset is less due to the suspension. Regarding the knee pain, knee pain is always a factor of saddle height, knee to pedal spindle relationship (cleat position) and saddle location.
    Where is your knee pain, front back or side?
    Apr 2013
    Quote Originally Posted by minimusprime View Post
    Thanks. And agreed. Although with the HT providing calf (and back) pain, and the FS having knee pain (and with the FS having suspension/added sag as you mentioned), part of me thinks lowering the saddle on the HT could help.
    Sides generally. Outer side, more than inner.
    WillWorkForTrail
    Jun 2012
    Same pedals on both bikes?
    Apr 2013
    Quote Originally Posted by Cotharyus View Post
    Yep, egg beaters on both.
    Oct 2016
    Check out the book “dialed”?
    $title
    Reputation: s0ckeyeus's Avatar
    Quote Originally Posted by Zlorfik View Post
    $title
    Lee McCormack's system is the best one I've found for making bikes feel optimal while standing. Getting the RAD and RAAD right is awesome. I don't know whether or not Dialed goes into saddle position, but treating saddle position mostly independent of bar position is where it's at.
    Apr 2014
    Obviously not quite the direction of advise you're asking for, but I've found that strengthening my core has really helped me with back pain while/after riding. Similarly, standing more at work and stretching/yoga has helped both that and my knee pain.
    Now, if you're getting the knee pain during rides, it might be a bit harder to rectify with preventative measures, but they can't hurt. I've found what I do off the bike really has a big effect on how I feel on it.
  1. Pain, top of my calf?
    By Odii in forum Rider Down, injuries and recovery
    Last Post: 01-31-2012, 11:26 AM
  2. Back of knee/Top of calf pain
    By AllOver in forum General Discussion
    Last Post: 07-10-2011, 08:31 PM
  3. Had knee pain, then refitted, now new knee pain somewhere else!
    By AMEXPERT in forum Rider Down, injuries and recovery
    Last Post: 01-07-2009, 08:20 PM
  4. Knee pain, fitting question.
    By FlynG in forum Rider Down, injuries and recovery
    Last Post: 10-03-2006, 07:31 AM
  5. Er..Knee Pain, anyone know anything about knee pain
    By SheSpeedsNotSingleSpeed in forum Women's Lounge
    Last Post: 05-03-2004, 09:58 AM
