Results 1 to 22 of 22
    Jan 2018
    Chain wearing carbon frames - specialized stumpjumper
    Hey everyone
    Would really appreciate your insights here. I've got myself a shiny specialized stumpjumper 2019 12 speed carbon, and I love it. It's an XL frame
    It's not done a huge amount of millage but it has done some long hard routes, did the whole enchilada in Utah. I've noticed that the chain slap has actually managed to dig in and wear the tiniest bit of the rear triangle paint and into the carbon.... Not deep, but present after not long.
    I've taken it to the store and they're saying it is ultimately just something you need to deal with when you've got carbon. Now this is my first carbon and I feel for brand new that's just not right.
    Anyone else had something similar?
    Anyone got any advice?
    It's currently in the shop getting a couple of things looked at and I'm not sure if I should accept this.
    Note, no other mechanical faults exist
    Photo here
    https://drive.google.com/folderview?...e3XdxtwEvTp_za
    Appreciated!!
    Thinking about riding.
    Dec 2014
    I wrap my chainstay in an old tube cut in half. Some buy 'helicopter tape' and cover their frame.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    metal chainstay protector that overlaps that area
    thin aluminum disk bent and glued down with flexible adhesive like lexel
    (flexible so if the chain eats it it won't torque chainstay apart)
    get the aluminum pieces or stainless steel
    https://www.google.com/search?q=meta...w=1920&bih=943
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Reputation: In2falling's Avatar
    Jan 2005
    Scott 2228 at Home Depot and wrap the areas you want to protect.
    Here, diagonally!
    Reputation: JACKL's Avatar
    Fancy! I use Gorilla tape, but whatever.
    Regardless of what you use, get something on there asap.
    Jan 2018
    Thanks guys, clearly a common issue and not one to cause hell over!
    Apr 2017
    Rear derailleur with a clutch (Shimano Shadow Plus) also helps minimizing chain slap.
    Reputation: vikb's Avatar
    OP while you are at it I would apply some clear protective tape [many options available] to any areas where damage to your frame is likely. It will keep the bike looking nice and if you use the right product adds a lot of protection to a carbon frame from point load impacts which are the ones that will kill a frame.
    When I got a carbon frame it's the first thing I did so I could ride it hard and worry about landing on the rocks.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: Thrashbarg's Avatar
    Mar 2017
    Quote Originally Posted by Gumby_rider View Post
    The real issue here is that his lbs sold him a 2019 carbon bike with a 7 year old derailleur on it!
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Quote Originally Posted by Thrashbarg View Post
    WTF are you guys on about? He's got Eagle 12spd on there. Even if it were the NX version, it has a clutch.
    The problem isn't going to be fixed by switching to Shimano. That's just for SRAM brakes.
    Reputation: 006_007's Avatar
    I use a long piece of velcro with the adhesive backing along the chainstay. Really helps quiet things right down as well.
    +1 on the Scotch 2228.
    Mar 2017
    Quote Originally Posted by noapathy View Post
    Insert swoosh sound here.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I hate when bike companies don't fully test and engineer their products. Not including something like a downtube protector or chainstay protector when it's clearly needed is stupid.
    Reputation: JoePAz's Avatar
    May 2012
    The 2019 Stumpjumper has an intergrated chainstay protector.
    Specialized introduced a new chainstay protector that is designed to interrupt chain slap, and well… it works. There doesn’t seem to be any real performance benefit; after all, narrow-wide chainrings and clutch-style derailleurs have all but eliminated dropped chains. Still, a quiet bike is a happy bike, and makes for a happy rider.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
    Feb 2018
    Wrap an old inner tube around it. It’s free, works perfectly and makes you bike look good.
    Reputation: plummet's Avatar
    As others have said. Wrap it and move on. Job done, problem solved.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by Alexe17 View Post
    That's the WRONG attitude. It's BS and has nothing to do with carbon.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    @2whlfun
    Did anyone actually look at the picture? It’s way up next to the chain ring in a tough place to wrap or even stick anything to.
    I’d be miffed, too. for that much damage in that short of time, the area should have been protected by default. all the more so if it is really “carbon is as carbon does” like shop told you.
    Reputation: twd953's Avatar
    Quote Originally Posted by twowheelfunman View Post
    I use the 3M 2228 tape posted above on all my bikes, and I've gotten it to stick to the exact spot shown in that photo on a couple different frames (every bit as tight). I've even tucked it up behind the chainring where you get gouges from chain suck.
    It conforms really well to curves. You just have to clean the area well first with some alcohol, and cut it to whatever shape works best and press it on very firmly. Sticks better when applying it when warm vs cold, so if you're working in a cold garage, hit the area with a hair dryer or heat gun before sticking it on (don't overdo and melt your frame, you just want it warm to the touch).
    Ideally, the frame protection provided by the manufacturer would cover all the high wear/damage areas, but in my experience it seldom covers everything. In the case above, it looks like the chain slap is chewing off the edge of the factory chain stay protection.
    I agree with Cleared2Land, if the shop just said "deal with it" without offering any solutions, that is poor customer service. At least offer the OP some suggestions of how to deal with it if nothing else.
    No dig no whine
    Sep 2018
    Ive got the same bike and as yet ive not had the same issue. However thast rubbish.
    if you look at this its been smashed off as well.
    https://www.youtube.com/watch?v=LvfATSFDCrQ
    my view is to ride it and if it breaks (ive already gone through one seatstay)then youve informed them of the issue
  1. Replies: 32
    Last Post: 03-19-2015, 06:57 AM
  2. Replies: 12
    Last Post: 12-31-2013, 08:01 AM
  3. Replies: 3
    Last Post: 11-07-2013, 04:16 PM
  4. Replies: 10
    Last Post: 06-23-2013, 01:08 PM
  5. Replies: 4
    Last Post: 08-13-2008, 02:15 PM
Members who have read this thread: 197
