Can I convert an e13 DRS to a single ring guide??- Mtbr.com
Results 1 to 6 of 6
    Aug 2005
    I'm sick of my front derailleur. I f'n hate it. Its hard for me to express how much I've always hated front derailleurs.
    I'm going with a 1x9 with a 32 front ring. I currently have a e13 DRS. I was hoping I could swap out the two step roller on the DRS for a jockey wheel or something similar to make it into a single ring chain guide. Can this be done? Has anyone tried this?
    Input is appreciated. Thank you.
    Vermonter - bikes, beers and skis.
    meow meow
    Reputation: b-kul's Avatar
    i did it. didnt even swap out the roller. worked fine.
    Aug 2005
    Quote Originally Posted by b-kul View Post
    Did switch to a single speed chain ring in the front? I'm concerned about the chain flopping off the chainring to the inside.
    meow meow
    nope, chain came off on a really rough downhill but that will happen regardless of the ring is there is no top retention.
    Aug 2005
    Thanks man, I pulled off my front derailleur and shifter. We'll see if the chain stays where it should.
    Aug 2005
    I had a drs when I first went to a 1x9 Didn't change the roller or anything and it worked fine. I did notice that without a upper guide the chain would fall off and I had to put my front derailuer back on just to hold the chain on. I do ride a lot of downhill so maybe if you're just riding xc u won't have a problem. I now have a mrp mini g that I like a thousand times better
  1. Single ring guide for an Uzzi VP
    By Jon Edwards in forum Intense
    Last Post: 06-03-2011, 01:08 PM
  2. Demo 7 - which single ring guide?
    By honourablegeorge in forum Specialized
    Last Post: 01-13-2011, 04:05 AM
  3. single ring guide
    By sparkjr200 in forum Downhill - Freeride
    Last Post: 04-18-2010, 02:27 PM
  4. Single Ring Chain Guide
    By Ivan the Terrible in forum All Mountain
    Last Post: 09-11-2009, 11:22 AM
  5. Can you go single ring without a box guide?
    By sodak in forum Downhill - Freeride
    Last Post: 01-09-2008, 12:06 PM
