[Frame protection]- Mtbr.com
Results 1 to 21 of 21
    Tin Man
    Reputation: L8str's Avatar
    Dec 2012
    [Frame protection]
    While the Spider frame is out for powder coat I want look at other options for frame protection. These are the down tube and chain stay pieces that came with the frame. They look like synthetic leather. Is there something better in the aftermarket?
    Why do women have boobs? So you got something to look at while you're talking to them. -peter griffin
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Something that I have been looking at lately is Shelter Tape, which is similar to helicopter tape but more impact resistant apparently. Vikb showed me this stuff.
    Other option is that you can do your own hard protector like that with Kydex, there is a thread over on Pinkbike that shows how a guy just basically heated a sheet of Kydex in his oven then just laid it over the part that needed the protection and let it mold and cool on its own.
    EDIT: found the article, see link
    Tin Man
    Dec 2012
    Since Kydex is hard I think the chain will make noise when contacting it so I won't use it on the chain stay. However, I think it will be perfect for the downtube. The piece for the spider will be simpler than the on pictured. I purchased a sheet of .080 on ebay. Thanks for the tip. -ted
    Jan 2014
    How does that guard stay attached to the downtube? Do you use two sided tape, or does it stay in place because it is Moldau to the bike frame?
    2016 Rocky Mountain Thunderbolt BC Edition
    2017 Rocky Mountain Blizzard -50
    2015 Giant Fastroad
    Jan 2018
    Quote Originally Posted by gregnash View Post
    Something that I have been looking at lately is Shelter Tape, which is similar to helicopter tape but more impact resistant apparently....
    I use Helicopter Tape now. I need to read about Shelter Tape.... Thanks.
    Tin Man
    Dec 2012
    The Kydex guard will "snap" on so not much is needed to secure it. I plan on using thin 2 sided carpet tape (not the foam stuff).
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Quote Originally Posted by j102 View Post
    There are two different varieties. One has Shelter written all over it. The other one does not. You may wish to ensure you are getting the latter, especially if you order online.
    I just bought a bunch with the shitty Shelter logo all over it, that I am returning.
    Jan 2018
    Quote Originally Posted by mtnbkrmike View Post
    Yeah, I wouldn’t want the one with the logo all over it. Thanks.
    Short-Change-Hero
    Where did you buy said version with the logo on it?
    Live Free & Ride
    Reputation: NH Mtbiker's Avatar
    I have used Shelter in the past, but it did have the logos and has started to peel up on the edges after 3 years....so it is good stuff.
    I am now starting to look at 3M clear adhesives, like this one...
    https://www.amazon.com/Scotchgard-Cl...omotive&sr=1-4
    -Check out the 4th review down for application.
    17 Fuel EX 9.9 (in progress)
    19 FM 279 carbon gravel
    17 Stache 29+
    14 GT Zaskar 100 9r
    https://kettleheadbrewing.com/
    Mar 2015
    MEC in Canada. The equivalent of REI in the US.
    Reputation: aliikane's Avatar
    Quote Originally Posted by L8str View Post
    That looks super clean. What thickness did you use? How did you press it onto the frame to get the shape? Seems difficult because there is so much area to press.
    I have used Lizards Skins Frame Protection and it works well for the downtube. Also, I have used Gorilla Grip Tape or Helicopter tape on the frame but it leaves so much adhesive residue that is difficult to remove. I am going to try car vinyl clear bra sheets this time around to see how well that works.
    Short-Change-Hero
    Quote Originally Posted by aliikane View Post
    If you read the pinkbike link the guy uses .08" thickness kydex. Basically with kydex, once it heats to over 200*F it becomes pliable. The OP in the PB thread heated it in his oven so the sheet became somewhat floppy then placed over the frame letting it fall and mold itself to the bike. Probably used a heat gun to warm it up and do further pressing into areas to get it to make the more complex bends.
    Thanks. I didn't see that link because I didn't read the entire thread. Lol.
    Tin Man
    Dec 2012
    Tin Man
    Dec 2012
    My Kydex sheets arrived yesterday. I will be using the procedure gregn described to work it.
    Undercaffienated
    Reputation: hmorsi's Avatar
    Please share your end result with us! I am looking into making something similar for my carbon frame.
    Oct 2015
    I made a kydex protector and it works a treat. I also use All Mountain Style frame skin elsewhere and it's been the best of many I've tried over the years, not cheap though.
    Found this Kydex like material called Boltaron 4332 on Amazon as well with a carbon look. Second link is a good deal for 4 sheets of the Kydex.
    https://www.amazon.com/dp/B00N34OD4E...04_03_t_img_lh
    https://www.amazon.com/dp/B06X9BVY4G...02_03_t_img_lh
    2019 Rocky Mountain Altitude C70 Custom
    2018 Pivot Mach 5.5 Custom
    2018 Orange Alpine 6 Custom
    2017 Knolly Warden Custom
    Tin Man
    Dec 2012
    Got the down tube protector done for the Spider. Kydex is very easy to work with. Band sawed to size, a little filing and sanding and it was ready to heat. A friend told me not to use a good toaster oven because the Kydex would stink it up. Looked at the local thrift stores for an old one but no luck so I used our good one and there was absolutely no odor left behind. I installed it with carpet tape.
  1. Continental Race King Protection & X King Protection
    By Richard36 in forum Wheels and Tires
    Last Post: 11-04-2017, 03:50 PM
  2. Frame protection and fork protection tape
    By Roadking1962 in forum Pivot Cycles
    Last Post: 09-10-2013, 07:53 PM
  3. Replies: 12
    Last Post: 05-01-2012, 08:28 AM
  4. Protection... Bike Protection that is..
    By go1d1e in forum 29er Bikes
    Last Post: 04-30-2011, 01:41 AM
  5. Leg protection or Arm protection?
    By misctwo in forum Downhill - Freeride
    Last Post: 04-03-2006, 04:23 PM
Members who have read this thread: 71
