Snow rims- Mtbr.com
Results 1 to 17 of 17
Thread: Snow rims
    Reputation: pbasinger's Avatar
    Dec 2004
    Snow rims
    Little nicer construction than the Snowcats. I also have black and silver ones.
    Awesome a nice alternative to Snowcats and DX32's. Those look sweet Pete, do you have a weight on them?
    Dec 2004
    They're double wall and seem really stout, so a little porky at 850g. You could probably cut the inner wall out for some weight savings.
    But they're pretty
    Caveman
    Reputation: Bearbait's Avatar
    who makes them?
    are they Trials rims?
    Dec 2004
    yeah, intended for trials
    Ride da mOOn Moderator
    Reputation: NEPMTBA's Avatar
    Looks like a Trials Rim......
    Reputation: slabhand's Avatar
    and the 29er option is?
    Dec 2004
    Quote Originally Posted by slabhand
    Good question.
    HowtoOverthrowtheSystem
    Will they work with tubeless?
    Quote Originally Posted by daveIT
    SurDave! As long as you run them with a set of................ Tire Balls
    Reputation: mtbike_AK's Avatar
    How much $$$?
    Save the Trails: http://www.imba.com
    Time to go farther
    And what's the width?
    On-One Lurcher SS
    Speedway Cycles Fatback Ti SS
    1984 Trek 560
    http://slipangles.blogspot.com/ - It's supposed to be fun
    Dec 2004
    ~46mm
    Time to go farther
    Pete,
    Honest question. Why would you go narrower than Large Marges other than maybe weight? All I heard last year was, I wish I could get 80 or 100mm rims from the majority of people.
    My only personal experience is Endo's on LM's.
    On-One Lurcher SS
    1984 Trek 560
    Dec 2004
    If you don't have a bike to accommodate bigger. That's the only reason I'd run the Echos or snowcats.
    I think the 80mm is just about perfect, just not available at the moment.
    Wood chips are stupid
    Reputation: akdeluxe's Avatar
    wishy washy
    I ran Endos on Snocats last year...on a Pugs. Weight concerns. It worked just fine until you lowered the pressure below 15lbs for soft conditions. Then you had very little stability. The tail and nose became squishy and wagged around. I also had a feeling the tire was going to come off the rim. Going with LMs this year.
    akdeluxe
    "Trust me,you don't want a big baby."
    JT
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    Any 29er option on those? Wishful thinking, probably, since I doubt any trials riders are using big hoops.
    Edit: Nevermind, I just noticed it was asked earlier.
