Patching bunny boots
Printable View
  • 12-15-2008
    anthony.delorenzo
    I was on a long ride yesterday and my right foot was really cold, felt like it was freezing up. Anyways, I looked when I got home and there is a small hole in the side of my bunny boot. There must be some moisture in there that is freezing up.
    So, I have two questions:
    1. How do I dry out the lining? Just leave it in front of the heater for a few days?
    2. How should I patch it? I was thinking about just using a bicycle patch kit if it would work.
    Any advice would be much appreciated.
  • 12-15-2008
    Valhalla
    That is the big prob with bunny boots, if moisture gets into the air reservoir they will not keep you warm. I had to toss out a pair because I could never find the hole. In my case the air valve was open and moisture got in and I could never get the right one dry again. Be careful in front of the heater, but aqua seal should work fine or a combo of aqua seal and those adhesive tire patches. just wait as long as you can before patching - can you blow some air into the hole?
