fixing flats- Mtbr.com
Results 1 to 3 of 3
Thread: fixing flats
    fixing flats
    What brand/style of pump do you carry on winter rides? Any that should be avoided?
    Ologist
    Reputation: Valhalla's Avatar
    Crank brothers seems to work ok. For fatties use high volume not high pressure to fill them up.
    keep it warm
    just about any pump will work if you keep it warm, so a smaller one like the Crank Bros is good cause it's easy to stash in my pocket when the temps drop.
    If you can't keep it warm, use a pump with a metal head to keep from snapping off in cold temps.
    Your best bet if you're riding at 20 above or colder is to just keep it warm.
    Pat
